Question about Saeco Talea Giro Espresso Maker - Titanium/Silver
Motor rotates in wrong direction and resets in wrong position
Switched on and off to reset when the brew group removed.
  • 55 Answers
There is micro switches on the gear wheel, the motor will move forward and hit a micro switch to stop to brew and then back to hit a switch to stop at park, it is not finding one of the positions so keeps turning, ohm to test switches or replace both
Posted on Dec 30, 2014
JohnnyBeans
  • 223 Answers
SOURCE: vienna deluxe can't get dump box back in - brew group flap in the way
Leave the dump box out. Use a spoon to hit the switch where the dump box would normally hit. Hold the switch until the flap is no longer in the way then replace the dump box.
Espresso Machine Service
www.cerinicoffee.com
Posted on Nov 24, 2007
JohnnyBeans
  • 223 Answers
SOURCE: removing the brew group
Directions on how to remove a jammed brew group: http://cerinicoffee.com/Saeco_technical_documents.asp
Shop for Saeco parts and cleaning supplies: www.cerinicoffee.com
Posted on Jun 02, 2008
mirran
  • 515 Answers
SOURCE: Brew Group will not reset
Hi Neil,
Try to put the dregsbox and driptray on place, close the door and turn on the machine.
When the machine stop again, open the door and put the brewing unit on place.
Best regards
/Mirran
Posted on Sep 25, 2008
EsWorld
  • 1618 Answers
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
Posted on Jul 02, 2009
SOURCE: Saeco Odea: The brew group
I had the same problem. I got around it by inserting just the grounds container (which sits inside the dregs drawer) and powering the machine on. Then the machine reset itself to the home position. It wouldn't do this with the dregs drawer removed, but putting in just the grounds container fooled it into thinking the dregs drawer was inserted. Hope this helps. JRP
Posted on Jan 17, 2011
Disconnect it from power, press the power button for 10 seconds to discharge it. Now reconnect to power and switch back on.
Nov 21, 2014 | Saeco Talea Touch Plus Espresso Machine
I have a segafredo zanetti vienna de luxe. I have had this problem before and the the guy(unfortunately they are closed today) where I bought it talked me through a re-set with the buttons. The problem is...
Read through this until you find how to reset the brw unit thyen follow the directions.
Remove the dredge drawer. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide that piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. (You can insert your key into the hole in the front and twist the key to return the brew unit to the center. Line up the 2 diamonds and it centered) If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Feb 05, 2011 | Saeco Vienna De Luxe Espresso Machine
Unable to reassemble. The removable brewing mechanism is out of synch with the motor. How do you reset the motor to the starting position so that I can reasemble it?
These are the directions for removing a stuck brew group. If the brew unit is ready to go back in the directions for resetting the drive gears is at the end.
Feb 01, 2011 | Saeco Vienna De Luxe Espresso Machine
I can't get the brew group out of the machine. It seems to be jammed.
Brew group stuck?
Close service door and insert only the tall grounds container. Tilt it so it fits in under the flat coffee pat rejection scoop on the left hand side of the brew group as this is likely to be sticking out. The grounds container has a metal bit in the back that affects a magnet reed sensor.
We are trying to fool the machine into stopping at the correct location. Turn the machine on. The drive spindle should rotate. As soon as you can easily remove the grounds container, turn the machine off. You should be able to remove the brew group. The idea is to get the drive spindle (part 22 in the parts diagram) in the correct position so the water inlet in the rear of the brew group can clear the pin boiler (part 10).
How to realign/reset the machine - is another problem i am working on.
Jan 17, 2011 | Saeco Odea Go
Spidem brew group stuck in machine in wrong position.
Hi
Remove the dredge drawer as far as you can. Open the door. On the left side of the brewing unit, and towards the back of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly with a quick ****. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out please give us a call.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit,(it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First you must close the door and turn on the machine without having the brew group in, but you must have your drip tray and dredge drawer in. Turn the machine on. You will hear the motor turn on and when it stops completely, open the door and remove the tray, now insert the brew group and replace the tray.
Jan 09, 2010 | Spidem Cappuccino Instantly Espresso...
Saeco Magic Roma - Steam & Water OK, no Coffee
Remove brew unit and push on bottom end shaft you will hear a snap then turn and lift small bar lever ( if you are holding unit with handle towards you it will be on the right side), this will help you see if there is an obstruction.
Sep 13, 2009 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Gaggia Synchrony Brew Unit Block
You have got the gears out of alignment. You don't really want to take out brew group unless at end of cycle. You can fool machine to get brew group back in.
Here is how :
BREW GROUP REMOVAL AND DRIVE GEARS ADJUSTMENT
FOR AUTOMATIC MACHINES
If you ever find yourself in need of removing a Brew Group that has jammed. This will assist you in doing so correctly.
To fix this problem follow these simple steps:
You will need a #1 Philips screwdriver
1.) First, open the door on the machine and remove the drip tray and dredge drawer
2.) Locate the nickel size hole in the brew group. It will have an "N" next to it. At the 9 o'clock position, you will see another hole about 1/3 of the size of the first. Directly behind this hole, or about an inch up depending on the position the machine was stopped in you will see a single philips head screw. You may have to look around the side of the brew group to locate the screw as it is not always visible from the smaller hole. Remove this screw; it holds a small coupling water inlet (it is similar looking to a tobacco pipe) to the brew group.
3.) Remove the brew group by pressing/pushing (depending on your machine) on the part that says “Press" or "Push”. Pull firmly and straight out. Be cautious to not break the brew unit. Also be aware of the door of your machine as it can break as well.
4.) With the brew group out, remove the small coupling water inlet (tobacco pipe) that is probably still stuck to your machine and reinstall it in the brew group as it was before. Make sure the screw is installed snugly but not too tight.
5.) Turn the brew group around so you are facing the back. Now imagine what a check mark looks like, the top we will call position A (longer part of the checkmark) and where the checkmark ends (the smaller portion) is point B. You will notice what looks like a large checkmark where the coupling water inlet is located. The water coupling can slide up and down in this checkmark opening. The water coupling should be in the B position.
REINSTALLING THE BREW GROUP
To do this, the gears will have to be reset to the start position. In order to do so, you will have to bypass the three micro-switches (Brew Group, Dump Box and the Door switch).
Bypassing the micro switches:
1.) Looking at the back-side of the brew group, not the side that says "Push" or "Press," you will notice something fin-like or nose shaped. This piece fits into a keyhole or coin slot looking slot in the machine and that is where the brew unit micro-switch is located. Take something like an index card, envelope, or folded up piece of paper, and insert it into that keyhole so that it will trick the machine into thinking that the brew unit is installed. Start the piece of paper at the top of the slot and slide it to the bottom of the slot. The paper should be thick enough so you can let go and it will remain in place. Leave this object in there until the following steps are complete.
2.) WITHOUT putting the brew group back into the machine, reinstall the drip-tray and dredge drawer and close the door.
3.) After doing so you can then turn the machine ON. At this time the gears will begin moving until they return to the correct start position. At this point remove the object from the keyhole position and you can now reinstall the brew group. If the brew group does not go back in correctly, try a few more times. The machine will return to its home position. Note: The two large spokes of The brew drive shaft should in the Up position
At times, the gears in the brew drive assembly will not complete the cycle to the proper
start position for different reasons. Some of the reasons are:
• Brew group jammed or blocked
• Either one of the micro switches in the brew drive have gone bad.
• Brew drive motor Failure.
• Broken teeth on either of the brew drive gears.
• Dirty brew group, covered by coffee grinds.
• Brew group or gears not lubricated.
• Connections to the board from brew drive assy., or motor have gone bad.
A jammed or blocked brew group happens when the brew group starts the cycle but doesn’t finish it.
Dec 21, 2008 | Gaggia Super Automatic Espresso Machine...
The brew unit cannot be removed
I had the same problem. I apparently turned it off mid-cycle. The upper-left portion of the brew group stopped higher than it should have. I had to force the brew group out, breaking a small plastic cover in the process. I don't think that part's too important. Then I observed the orientation of the gears and visualized what orientation they needed to be in to re-install the brew group. I pressed all the sensors to trick the machine into thinking the brew group was installed and started the brew process. I released the sensors once the gears were in the necessary orientation. I re-installed the brew group and was back in buisiness.
Feb 17, 2008 | Saeco Incanto Classic Espresso Machine
Wate coffee container removed for cleaning, the machine was accidently switched back on. Now the container will not slide back into the machine, it looks like the coffee maker portion needs to be re
You can remove the brew unit and cycle it manually back to the neutral position. There is an arrow and letter "N" that will align when the unit is properly positioned.
Jan 08, 2008 | Solis Master 5000 Espresso Machine
Saeco Vienna gear jammed
This has happened to me. If the problem is the brew group gear is in the wrong position, you can manipulate the brew group until it matches up with the drive gear in the machine. You'll know it matches if you can insert the brew group back in the machine full until it clicks.
Nov 07, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Talea Giro Espresso Maker - Titanium/Silver Logo
87 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
