Question about Western Digital Computers & Internet
My external hard drive won't copy and it came with this error 0x80071A3
  • OHare Nov 26, 2014
    Hi Shamsonise , I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What exactly did you do when you tried to copy?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 131 Answers
May be your files get damaged. Do not use External hard drive as only storage for files because it always happen.
Posted on Nov 28, 2014
micromaster
  • 3614 Answers
SOURCE: error copying file or folder
One of the most important yet overlooked elements of PC maintenance is data backup. If you do not perform regular backups, chances are your productivity will eventually suffer from data losses or a failed Windows installation.
All versions of Windows after 3.1 ship with a free backup utility called Microsoft Backup. It is not the best backup program available, but it may be sufficient for your needs. (Backup is better in later versions of Windows. Microsoft recommends Win98/Me users purchase a third-party utility.) If you want more control over your backups, consider purchasing a third-party program.
Backup is part of the System Tools utility. However, Setup does not install it by default in Win98/Me/XP Home. If you cannot locate Backup, visit the Microsoft support site and query for article No. 152561 (Win98), No. 264541 (WinMe), or No. 302894 (WinXP Home).
In Win98/Me, click Start, select Programs, Accessories, System Tools, and click Backup. To create and run a backup, click the Create A New Backup Job radio button and click OK. Follow the prompts to create a full or partial backup. If you want to create a backup set and run it later or run an existing backup set, open Backup and click the Open An Existing Backup Job radio button and click OK. You can now access the main Backup dialog box.
In Win2000/XP, navigate to the System Tools utility and select Backup. Click the Backup Wizard button. If you do not see a Backup Wizard button, click the Welcome tab. In WinXP, the wizard will start automatically if you are in wizard mode. Follow the prompts to create your backup set.
When you reach the last dialog box, Completing The Backup Wizard, you can click the Advanced button to create a backup schedule (this option is not available in Win98/Me). When you reach the When To Back Up dialog box, select the Later radio button and click the Set Schedule button. Perform data backups on a schedule that is appropriate to the importance of your files (once a week is a common timeframe). You should also perform a system backup at least once a month.
If you do not want to use the wizard, or you are working with an existing backup, open Backup and click the Backup tab to access the main Backup dialog box.
Posted on Feb 11, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Copying music cd to external hard drive for ipod
ok...you are connect via usb? when using limewire, window media or itunes,,,,go to options on all them and change the directory where you like to store and retrieve files from...now for the files that you already have on the primary hard drive....go to my computer..you see both drives internal (is your c) and the external is ?) find the music on the c drive ..open it..cut & paste (or click & drag) to the new drive ....to copy this music onto your ipod...make sure you have the latest itunes version (WWW.APPLE.COM) once you have this on the desktop let it scan for all the music on pc....now plug ipod to pc...20-30 seconds your ipod will show up on itunes...look on the bottom of itunes left side (u see the ur ipod)...look up and click on the music folder on pc drive and all the music should now be showing too...click on that same folder drag down to the ipods music folder.......let it load up...it might take awile depending on how much you got .....not never ever pull ipod out always eject the ipod .......then unplug it............................
Posted on Jul 09, 2009
  • 1015 Answers
SOURCE: drive will not copy files to it
The Macintosh OS may not work with the drive due to the file system on the drive was created with windows. The drive may have to be re-formatted with the Mac to work on it. Now I don't use a Mac so I assuming the OS will have a problem with FAT32 or NTFS format that windows uses....I could be wrong.
Posted on Sep 10, 2009
pankaj_dic
  • 1250 Answers
SOURCE: my samsung 500gb external hdd is niether copying nor being format
you can do one thing remove the hard drive from the casing and put on some other casing then check, if the problem is the same then its the problem of hard disk
Posted on Oct 09, 2009
bronk50
  • 27725 Answers
SOURCE: i/o error in external hard
make sure all the connections USB, sata and electrical are secure and working properly
Posted on Jul 20, 2010
I have a Seagate 2TB external hard drive... I am trying to rip and store karaoke cd&g disks to this external hard drive and it is not allowing me to store there.. says an error with not reading the...
Try to copy something else to it, if that does not work you have something wrong with the computer or drive. If so rip to your hard drive then move over to the external drive.
May 07, 2014 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Error
If you have an external hard drive, you can use software such as Acronis, to make a copy of that drive to save everything in an image. Get a new drive to install in place of the old one. Next you can use Acronis to copy the image on the external hard drive, back to the computer, onto the new hard disk in your computer.
Jul 19, 2013 | Microsoft Windows Vista Ultimate Edition
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Hi,\r\n When i plug in my Western Hard Disk WD4000ME, its detected by the system and all files are shown, but I cannot copy those files back to the system. It gives the following error:- "The requst could...
An I/O error indicates an issue with the device driver(s) that handle input/output processes such as copying files to/from hard drives, data in resident memory (RAM) waiting to be processed by the CPU or the controller chipset that handles the primary calls to/from the subsystems or a faulty hard drive.
Below are a few solutions that may help resolve the issue and allow you to transfer your files:
Before proceeding, you will need the following:
A. Computer B. External USB Hard Drive C. USB Cable D. RAM Module (Replacement, if necessary) E. Hard Drive (Replacement, if necessary) F. USB Hard Drive Enclosure (Replacement, if necessary) G. USB Cable (Replacement, if necessary)
Note: Solutions B/C apply only to Windows OS.
Solution A. Faulty USB Cable
1. Replace the USB cable. 2. Connect USB hard drive to the computer. 3. Attempt to copy a file from the drive. 4. If successful, copy additional files, as needed. If not successful, skip down to Solution B, step #1.
Solution B. Locked I/O Processes
1. Press and hold the power button on your desktop/laptop for about 10 seconds (or until the system has powered off completely). Then release the power button. 2. Make sure the USB drive is plugged in. 3. Wait another 10 seconds and press the button once again to power on the computer. 4. Once logged in, attempt to copy a single file from the drive 5. If successful, go to step #6. If not successful, skip down to Solution C, step #1. 6. Continue to copy files from the drive. Make sure to pay attention to what files (if any) prompt the I/O error message. If you receive an I/O error, skip down to Solution C, step #1.
Solution C. Motherboard Device Driver Installation/Update
1. Click on the "Start" menu and click on "Control Panel". 2. A new window will open, double-click on "System". 3. A new window will open, click on "Device Manager". 4. A new window will open, listed in the hierarchy are all the hardware components installed on the desktop/laptop. Look for any devices that display either a red "X", yellow "!" or yellow "?". These devices have either incorrect, incomplete or missing drivers/software and need to be installed, as they might be the root cause of the trouble. 5. If any of the above icons are present, perform a Windows Update by visiting the site below:
http://update.microsoft.com
Perform any updates available on the software and hardware side. 6. Restart your computer. 7. Follow Solution C, steps #1-4 to determine if any drivers still need updates. 8a. If updates are not needed, attempt to copy files from the hard drive. If successful, go to step #9. If not successful, skip down to Solution D, step #1. 8b. If updates are needed, you may need to visit the support site for your desktop/laptop's make/model and download any missing drivers. 9. Continue copying files, as needed.
Solution D. Faulty RAM
1. Power off the desktop/laptop and disconnect all cables. 2. Open the desktop/laptop. 3. Remove all the existing RAM. 4. Install the replacement RAM. 5. Power on the desktop/laptop. 6. Connect USB hard drive. 7. Test by copying some files from your hard drive. 8. If successful, close your desktop/laptop and continue copying files, as needed. If not successful, remove replacement RAM and reinstall previous RAM and skip down to Solution E, step #1.
Solution E. USB Hard Drive Case Faulty I/O Board
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install hard drive into replacement USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, skip down to Solution F, step #1.
F. Hard Drive Malfunction
1. Power off computer/desktop and disconnect all cables. 2. Open your USB external case. 3. Remove your existing hard drive. 4. Install replacement hard drive into USB case. 5. Power on your computer. 6. Connect your USB external drive. 7. Copy files from your external USB hard drive. 8. If successful, continue to copy files, as needed. If not successful, this could be an indiction of a much larger problem in the form of a Motherboard issue.
If the motherboard is malfunctioning, this is a sign of bigger things to come and will require a replacement board in order to correct.
In the event that the motherboard needs replacement, depending on the make/model of the desktop/laptop, the cost could range from $35-120 for 3rd-party boards or $85-300+ for consumer-level systems from manufacturers such as HP, Dell, etc. and $350-1000 from Apple.
If your desktop/laptop is still covered by the manufacturer's warranty or 3rd-party extended warranty, any hardware component that needs replacement should be covered at little to no out of pocket expense to the end-user. This also includes the external USB hard drive, as well.
Aug 15, 2010 | Western Digital Passport 320GB External...
I/o error in external hard
Jul 20, 2010 | Seagate FreeAgent Pro 1TB External USB...
Hard drive crashed
you may try to insert your hard drive to an external hard drive casing then plug it to a pc as an external drive then check if it can still be detected. From there you can copy the files to the computer.
hope this helps . . .
Apr 05, 2010 | Gateway (M520HD80G) Hard Drive
Error while recording
ok when you say it doesn't copy completely you mean
the only folders that are need for back up copied ?
the only folder that ever is copied for back up is your
documents folder , one other folder that should be
copied as well is the folder that contains your
executable programs , everything else on the
computer belongs to Windows your OS and can
not be copied , everything that runs through the OS
registry can not be copied as it was already copied
when you installed your OS . allot of external HDD
enclosures have a one button back up I suggest
not using it and manually back up what is needed
software is required to run an automated one touch
back up and this software's firmware is always out
dated , and external HDDs should always be turned
off except when entering backed data , they should
never have operating systems installed on them
and sometimes if they are on while the computer is booting errors can be applied from the C: drive which
will contaminate the static HDD (external) and cause
it to malfunction
Jan 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My samsung 500gb external hdd is niether copying nor being format
Oct 09, 2009 | Samsung 500GB, 7200RPM, Internal, 16MB,...
Computers & Internet Logo
219 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
