Question about Panasonic Office Equipment & Supplies
My Panasonic laser printer no. KX-FL8801 appears not to be printing and telling me that the drum life is complete. How do I correct this
    Sergeant:
    Champion:
  • 246 Answers
Try to reinstall the printer driver or reset the printer by ejecting the power and data cable for a one miniute
Posted on Nov 27, 2014
osiriscompu
  • 16 Answers
SOURCE: Problem with the printer drum?
Sounds like the toner isn't sticking to the paper.
Open the top cover of the printer. You will see two yellow felt stickers with a black triangle on them. On either side of those stickers you will see two gray or green tabs. If the tabs are sitting up pull them down towards you so you can see the picture of the envelope on top. Close the cover and try to print.
Posted on Jul 19, 2008
jtuminaro
  • 56 Answers
SOURCE: RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
Posted on Jan 15, 2009
HobbesVT
  • 3 Answers
SOURCE: Panasonic KX-MB781 drum reset
I already answered this at some other place her - but here I go again: There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner mixing assy - and you can rotate it in counterclockwise all the way back. This should reset the drum counter - worked for me - I hope it also does the trick for you ;-)
Posted on May 04, 2009
SOURCE: reset drum
I think this machine does not have a reset option instead you can reset manually.All you have to do is on the right side of drum unit there exist a white + type notch,rotate it clockwise till it allows.Put back drum unit into machine.Switch on and see replace drum and supplies message will disappear.In my case it worked.Hope this is the best solution.All the best
Posted on Oct 26, 2009
  • 8404 Answers
SOURCE: I WANT FREE DRIVER FOR Panasonic KX-FLB802 Laser
Look at www.panasonic.com/support for your driver.
Posted on Jun 07, 2010
Panasonic kx-mb1500 drum life over reset code
There is a screw on the side of the cartridge that you have to screw in to reset the drum life timer. With the cartridge flat side toward you, the screw is on the right side.
Aug 30, 2013 | Panasonic KX-MB781 All-In-One Laser...
Drum life over in panasonic kx-mb1500
how reset panasonic kx-mb1500 drum life over
Jan 11, 2013 | Panasonic KX-MB781 All-In-One Laser...
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Have a Panasonic KX FL 511 it it printing very light can even read the text. Replaced the Drum and Cartridge still prints the same?
I made this suggestion to a person who's printer wouldn't recognize his new cartridges: Reconnect the printer to the computer as if it was for the first time. Complete every step as it is written.
Printers are indeed very finicky devices and sometimes they are just not any good any more. New printers are as cheap as the two new cartridges, which makes it just as cheap to upgrade to a newer printer. Good luck!
Feb 19, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Replacement of drum unit in Panasonic KX-MB272 printer
Here is a link to the manual:
KX-MB271 Manual
Refer to Page 81 for removal and to Page 9 and 10 for installation.
Thanks for using Fixya.
Sep 01, 2009 | Panasonic KX-MB781 All-In-One Laser...
Error Message Drum Life Over, Replace Drum
The "drum" referred to is the imaging drum which is replaced separately from the toner cartridge. The drum life is rated for a certain number of copies, and the printer is telling you it's time. Replacement drums are available at big-box office places and from many online sources. Just do a Google search for "kx-fl511 drum". The new drum just slides in much like the toner cartridge, so replacing it isn't difficult.
Apr 08, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
"DRUM LIFE OVER" KX-FL511
just change with new drum and toner.after replacing when msg gone just press start.u will receive ur faxes in memory.MIAN AKHLAQ
Dec 31, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Drum life over
have u changed it with new one or used .process in fax when we replace it with new one it take some time for running .when it complete his circle error finishes from memory .if machine is off in this time or any other trouble it will create the problem .just take a drum from any same fax and put this in fax after running i think error will disapeear.
Dec 16, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Print is obliterated with 4 broad hoziontal strips on paper
The green roller is the OPC drum, and as with many panasonic laser printers the cleaning mechanism doesn't work properly. The only way to solve this is to replace the unit.
Jun 19, 2008 | Panasonic KX-P6500 Laser Printer
83 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
