Question about Sony Black Virtual 51 Sound Bar HTCT150
Sony sound bar system model SA-WTC150. Will not turn on.
Will not turn on while plugged in no lights etc
2 Suggested Answers
  • 13 Answers
SOURCE: I have a Sony sound bar mod# sa-32se1 connected to
I had the same problem. I found that my sound bar can't be too close to the TV. I have my samsung TV on a platform ( not mounted) and the sound bar in front of it. In this configuration, the sound bar kept shutting off. I returned it as a faulty unit and the second one did the same thing. By chance I happened to move the sound bar off of the tv platform and the problem ceased.
Posted on Dec 18, 2011
I have a Sony sound bar Model CT380. It has HDMI ARC and optical digital connections. The TV does not have these connections. What can I do to work around this?
How to connect a TV Sound Bar system to a television. - SONY
https://us.en.kb.sony.com/.../how-to-connect-a-tv-sound-bar-system-to-a...
Jump to If your TV has an HDMI terminal (without ARC) and an ... - Then connect theTV's Optical digital ... If your TV does not have HDMI input ...
2.1 ch Soundbar with Bluetooth ' HT-CT380 ' Sony US
www.sony.com/electronics/sound-bars/ht-ct380
Sony Corporation
Rating: 4.1 - ‎9 reviews - ‎$249.99
Discover the 2.1 ch Soundbar with Bluetooth from Sony & explore all the Sound Barsfeatures. ... filter higher frequencies to distribute audio smoothly around the room. ...against the sound bar to make an instant Bluetooth connection. No NFC? ... the HT-CT380 to allow data to pass through the sound bar straight to your TV ...
Dec 28, 2015 | Sony Audio Players & Recorders
How do I attach my i phone music to sony DAV SA 30?
There are iPhone cradles available that you set your Phone into, and I believe(don't hold be to it, as I haven't looked specifically for them) have RCA analog outputs, with charging available in the cradle. Have a look on Google. I'm sure you'll find hundreds of them. Those RCA cables, can plug into any high level(no phono inputs anymore) input, such as CD, DVD, TV, etc.
Sep 19, 2014 | Sony DAV-SA30 System
Flashing blue light on sound bar. No sound
Double check to make sure you don't have the "mute" on. Usually a flashing light indicates that the volume has been muted.
Mar 08, 2014 | Sony HT-CT100 Theater System
Sony sa ct60
My sound bar, just stopped working - when I push the power button on. It makes the red light go on for a mili second and then goes off again.
Any Ideas?
Jan 04, 2014 | Sony Audio Players & Recorders
I have a Sony sound bar mod# sa-32se1 connected to my Sony 32 in bravos, sounds great but shuts down after a few minutes of use what might be the problem
Dec 18, 2011 | Sony Televison & Video
Sony SA-VA10 Shelf System Powered Monitor Speakers. Constant Buzz .. around 1K . .sounds like power supply. Not attenuated by increase in amp volume. Help
Secondly sounds like the power supply filter capacitor has gone bad. Write down the value off the label and purchase one at your local electronics parts place. It will only be two solder leads to unsolder and solder back. But first check the other place for that symptom, an open ground near the input jack going into the amplifier, or broken input wire/plug.
May 19, 2010 | Sony SA-VA10 Shelf System
No sound from Sony SA2500 subwoofer
Please intimate exact model number written on sticker pasted at back of Sony subwoofer to provide you help.
Aug 01, 2009 | Sony SA-WX700 Subwoofer
Sony SA-VA10
Hi, Have you been able to locate the cable for your Sony speaker system? Thats a shame that they would take just the cable. Anyways, I have the sa-va10 model just like you. I just upgraded to a new sound system. And I have the cable. Tho, I m sure somewhere on the net, like ebay, amazon or even Sony should be able to help you. I would call them. Those speakers are not that old, and maybe Sony still has a ton of those cables in stock. Esp. since the system is only around 14 years old. Relatively thats still pretty new.
Jan 02, 2009 | Sony SA-VA10 System
Dvd totv
IF you have a cable running from the tv to your system from the audio output you may have to turn on or turn up the output in the tv menu,some SONY tv s are like this. If you have done this and are useing a amp like a ONKYO or YAMAHA etc you will have to go to the input assign in the setup menu and tell the amp were the cable is pluged in and which type.
hope this helps.
CABLE GUY.
Jul 03, 2008 | Sony SA-VD900 DVD SolutionHome Theatre...
Sony Black Virtual 51 Sound Bar HTCT150 Logo
96 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
