Question about Dryers
Allen + Roth ceiling fan with remote Model #: LP8242LCH. The light randomly turns on. Not touching remote. Any ideas how to fix it?
    Genius:
  • 1,617 Answers
Change the frequency in the receiver & transmitter. Also, stay away from store brand fans.
Posted on Nov 24, 2014
SOURCE: Ceiling fan does not reverse with remote
Just reporting that I called Hampton Bay about the remote not working to reverse the fan. I was told that I needed to have the fan running on low and then press reverse on the remote control. If that doesn't work, customer service told me to press reverse while running the fan on medium. (Some fans are set to reverse on low and others on medium.) Nowhere in the manual is this addressed. I had been pressing reverse with the fan turned off, which seemed to me a logical thing to do. Live and learn.
Posted on Sep 05, 2007
  • 10 Answers
SOURCE: Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Posted on Oct 24, 2008
johnny5846
  • 379 Answers
SOURCE: ceiling fan remote will not turn on light
common problem , i went to home depot and bought a new remote for my hunter fan , and it worked again , salesman was very knowledgeable and helpful . thanks. explain the problem to him , he can help .
Posted on Dec 30, 2008
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
  • 3640 Answers
SOURCE: The light on my hunter ceiling fan flashes on and
remove watt governor for lights. ( little black box). and wire lights direct. this is your problem.watt governors are used to reduce light output or energy. just remove it.
Posted on Jan 24, 2011
Allen + roth santa ana ceiling fan manual
What kind of wiring diagram are you looking for? fanman9952@aol.com
Mar 10, 2016 | Dryers
Allen & Roth Eastview ceiling fan. How do I reverse to pull up warm air instead of blowing air down?
Look for a slide switch on the side of the housing beneath the motor. If the manufacturer wired it correctly, the up position will pull up warm air and the down position will blow air down.
Jan 09, 2014 | Dryers
Trying to install an Allen & Roth Ceiling Fan Model#LP8062 Help it doesnt seeem like the light open to change a bulb and the blades dont come off Help?
That's just a CHEAP store brand fan. Take it back and go to a real fan store and get a fan with at least a 13 degree blade pitch or at least 5500 CFM's
Nov 03, 2013 | Dryers
I have a Allen and Roth double ceiling fan and now the light will not turn off by the pull string, so we can not have the fans on with the light off-- ANY HELP?? Its only a year old ;(
The light switch may have failed. They tend to do that.
You don't say whether your fan has a remote control, but that could be the source of your light problem as well
Jul 09, 2013 | Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Jul 26, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
We have a Milano Model No. F527 fan. The light comes on spontaneously at random times and the fan can only be turned on and off sometimes. Other times it works perfectly. The remote control batteries are...
Get in touch with Minka group Mr. Minka who will assist. I'm working on my same problem right now. You need to reset the dip switch in your remote or wall switch and also the same setting on the fan.
Jun 29, 2009 | Minka Aire Ceiling Fan
Dryers Logo
519 people viewed this question
Top Dryers Experts
