Question about Garden
Which wires connect to Black and Decker GT650 Electric Motor
  • Garden Master
  • 2,478 Answers
Most motors,on plate that covered the wires coming from motor. One side or another, tells you where the wires go
Posted on Nov 23, 2014
  • 313 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER
the pic says the connection are not right.all left side connection are for brake which is the red & white wire. all right side connection are two black wire.
Posted on May 31, 2008
SOURCE: need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Posted on Jun 22, 2009
  • 4 Answers
SOURCE: Black and Decker Electric Lawn Mower MM850 wiring diagram
I have repaired mines. It was found in the trash dump, just before street curb side trash collection. It is a very sophisticated lawn mower. It taken me a month to restore it. The problem is the housing is poor design and does not hold the pin switch securely. This is not a simple on/off switch. It is switch module with two momentary switches built in to it to work simultaneously. The hot is a normally open momentary switch and the neutral is a normally closed momentary switch. Two things must occurred simultaneously for the lawn mower to work. The AC hot has to close and the neutral to open. This is a split phase AC motor. The switch has four connectors to it. The first two has black wires to it, for the hot, that is normally open. The second two has a white wire and red wire to it for the motor's start up winding. The orange connects with the plug's white, neutral. A new substitute switch will be two individual momentary switch, one for the two black wires will be normally open and the two for the red and white wires from the motor start coil will be normally close. It will take two fingers to operate the lawn mower. I recommend you to buy a new and each switch from Black and Decker.
The problem with the system is not the switch, but the poorly designed switch box housing. Often, there is nothing wrong with the switch. I tested mines and it works fine. The problem is the switch box housing does not keep the switch in the correct position for the higher tension spring lever to press against it to operate. I use small washers to stack between the rear of the switch inside and reassembled the switch box upside down by turning the handle upside down, so the washers and switch do not fall out. Once I am finished assembling the switch box and position it on the handle, then I position the handle back to the normal top side and attach the handle back to the lawn mower. I am finished.
http://en.wikipedia.org/wiki/AC_motor#Split-phase_induction_motor
"Split Phase Motors
Split phase ac motors are widely used for low power applications as for example in oil burners, furnace blowers, garage door openers and major appliances. Such motors employ separate run and start windings connected in parallel across the acpower source. When the motor is initially energized both windings are energized, and when the rotor speed reaches about eighty-five percent of the normal running speed the start winding is disconnected from the circuit. Various devices are utilized forthis latter purpose and include centrifugal switches and current and voltage relays.
A problem which is characteristic of these motors is that they have a relatively short operating life. The principal reason for this is the failure of the switching devices used to cut out the start windings when the rotors approach the normalrunning speeds.Failure of these switching devices in turn cause the start windings to burn out.
One of the reasons for the failure of these switching devices is the high currents which they are carrying at the time the contacts open. Attempts to increase contact life by use of improved designs and materials have not been altogethersuccessful. Another disadvantage associated with these switching devices is that they are necessarily quite large and occupy a substantial space in the motor housing." -from another web site.
Posted on Sep 08, 2009
  • 23 Answers
SOURCE: WIRING DIAGRAM? FOR BLACK AND DECKER ELECTRIC LAWN MOWER MM 850
looking down at the terminals, rotate push-button to the right. the wiring sequence is R, W at the top, then Black (in, from power source) , Black (out, to motor).
Posted on Sep 27, 2009
  • 52 Answers
SOURCE: Electric Lawn Mower Doesn't start - Pwr supply ok - No burnt Moto
this mower has a dc motor and the brush on the black wire to the motor usally wears down
Posted on Mar 03, 2010
Where can I get a electric motor p/n 90520850
250 MPH Electric Blower Vac Mulcher ' BV5600 ' BLACK+ ...
www.blackanddecker.com/.../blower...blowervacuummu...
Black & DeckerThe High Performance 12 amp motor 3-in-1 blower, vacuum, and mulcher keeps ....blower I was using and I let him use it and he liked it alot said he'd never buy the ... So thanks again Black & Decker for making a safe usable product that will ...
Black and Decker BV3600 12 Amp Blower Vac - Amazon.com
www.amazon.com > ... > Leaf Blowers & Vacuums
Amazon.com, Inc. Rating: 4 - ‎138 reviews
Greenworks 24012 7 Amp Single Speed Electric 160 MPH Blower B0030BG1CC ...The Black & Decker BV3600 Blower Vac has a powerful 12 amp motor. .... really well, so that I had about 4 bags of debris to empty, and I have a big lawn.
Oct 23, 2015 | Black and Decker USA Black & Decker...
Corded elec mower wont start. Extension cord is new
Is there power going to the extension cord? If so, is the power reaching the electric motor? If not check the on/off switch and connections.
Jun 28, 2015 | Black & Decker Black Decker 18" Lawnhog...
I have Black Decker electric Edge Hog, does not turn on anymore. Is there a fuse or power reset switch?
I have a black & Decker Electric Edge Hog, does not turn on anymore. Is there a fuse or power reset switch?
Jun 13, 2010 | Black & Decker Le750 Lawn Edger
19" black and decker electric mower just quit!
check the brush on the motor the one with the black wire usally wears first
Mar 21, 2010 | Black & Decker 19" Electric Lawnhog...
Mar 03, 2010 | Black & Decker 19" Electric Lawnhog...
Sep 27, 2009 | Black & Decker 19" Electric Lawnhog...
Wiring problem
its unsafe to hot wire the switch. contact me at 204-783-7294 i will send you a wiring diagram ask for dennis
May 05, 2008 | Black & Decker 19" Electric Lawnhog...
Feb 06, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
