Question about Samsung CLX-2160N All-In-One Printer
Ghosting when printing
Which part need to be changed to fix ghosting?
    New Friend:
  • 79 Answers
Try taking out the cartridge(s) and clean the Photoconductor drum with Isopropyl alcohol
WARNING do not expose the drum on the direct light of a lamp or of the sun, the drum is photosensitive
Posted on Nov 27, 2014
2 Suggested Answers
  • 220 Answers
SOURCE: Samsung SCX4200 ghosting and very unclear print
fuser and possibly laser scanner faulty
Posted on Jul 08, 2009
Ghosting
Normally ghosting is caused by a bad fuser.
Put paper in the manual feed tray(tray 1)
Print something. As the paper gets 1/2 way into the printer, open the cover..
Look at the paper. If there is no ghosting, the fuser is bad. If there is ghosting, could be a cartridge drum.
Follow these steps print a Print quality troubleshooting page to identify which print cartridge is causing the issue.
  1. Open Toolbox .
  2. Click the Help folder, and then click the Troubleshooting page.
  3. Click Print , to print the page. The page prints five bands of color, which are divided into four overlapping sections. By examining each section, you can isolate the problem to a particular print cartridge. Figure 4: Print quality troubleshooting page bandsc01417618.gif 1 - Yellow 2 - Cyan 3 - Black 4 - Magenta
May 01, 2011 | HP LaserJet CP1215 Color Printer
Tip
The ghost image of the print is printing on the paper with the orignal print ?
Ghosting is a condition where theimage prints properly, but a much lighter copy of the image also printselsewhere. This can be due to a problem with the power outlet that is supplyingpower to the printer. Check the power outlet by plugging in a different printerto see if the same results occur. Ghosting can also be caused when consumableprinter parts (such as the drum or imaging kit) are near the end of their life.All of the consumable parts in a printer are rated for a certain number ofpages. Once a printer gets near that magic number, you'll need to replace thoseparts to eliminate ghosting.
This will help. good luck.
on Mar 05, 2010 | Office Equipment & Supplies
Oki C5500 printer has ghosting on most of the prints. After making a number of copies, the ghosting is greatly diminished and the copies are OK but not great. Started a couple of weeks ago. I have refilled...
This type of print problem associated with laser printers is due to the corono wire needing to be changed. The wire is not fully pulling the toner off of the drum completely. If you can access it, cleaning it may help (usually a lever that you are supposed to run back and forth a few times that wipes the corona wire). If the cleaning doesn't help, then it probably needs replacing.
Feb 08, 2010 | OKI C5500n Printer
Only on color printing am I getting ghosting of the images. How can I adjust this?
hello,when i see one color dusting, ghosting i usually change that color drum unit.If multi color ghosting probably the transfer belt cleaner blade.thanks don
Nov 10, 2009 | Canon imageRUNNER C3200 Copier
Ghosting when using HP CP2025N
Bad drum unit poor fusing or paper type try to print paper type cardstock as type, this increases fuser temp and slows printer for better quality.
-Carl, please let me know if this helps.
Jun 25, 2009 | HP Laserjet Cp2025n Printer
Ghosting on prints
Wrong paper type can cause this, also if it is damp or too thick. Also check that you have the correct type of paper (thickness) selected in the driver. Ghosting can also be caused by a faulty drum unit, since you just replaced it maybe there is warranty left on it?.
May 24, 2009 | Brother HL 5140 Laser Printer
Text is "ghosting" when using card stock
I sort of solved my ghosting problem by selecting print, set up, and then under media type selected thicker paper. This apparently pulls the card stock through at a slower rate which helped tremendously. One of my documents turned out perfect and the other "ghosted" just a little.
Dec 17, 2008 | Brother HL-2070N Laser Printer
GHOSTING
go to image revison in menu and try. auto, 0, 1, 2, or 3 for best picture
Jul 05, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Brother MFC-210C is ghosting!
Hiya,
I had the same problem this evening, so I went onto the Brother support site.
This link solved my problem:
"How can I improve poor print quality?"
http://tinyurl.com/27xv4r
Hope that helps.
-areacode514
Feb 23, 2008 | Brother MFC 210C All-In-One InkJet Printer
Samsung CLX-2160N All-In-One Printer Logo
122 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
