Question about Blackberry Cell Phones
How to restore blackberry z10
It says connect to wi-fi
    Problem Solver:
  • 7 Answers
If you went to Settings, Security and Privacy then Security Wipe. The Balckberry will reload and reboot itself, but you will have to set up the wifi again as you will have wiped out the wifi settings and your Blackberry ID. You need to treat the Balckberry as a new unit and set up both. You can use the ID you set up originally. If you are not the original owner you will need to set up a Blackberry ID.
Posted on Nov 25, 2014
Testimonial: "it give me the pin of the router to insert"
  • Isabel Winstanley Nov 27, 2014
    If the Blackberry is asking for a password it is the one you used to set up your wifi system at home. If you did not set the wifi system up to use a passowrd but want to now you need to go into your router settings and change them. Please post exactly what it says on the Blackberry screen when it asks for a pin or password.
SOURCE: itouch wi-fi connection problem
Try this one : http://wiredforgadgets.com/?p=743. It worked for me.
Posted on Apr 18, 2008
tinualbinale
  • 436 Answers
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
Posted on Sep 12, 2009
gomartymo
  • 20 Answers
SOURCE: could not connect to the internet using wi-fi connection
need to configure modem/router. just put ip address off modem into address bar on web browser. use admin as name and password for password. Check out portforward.com and all info will be easily found to solve problem.
Posted on Oct 26, 2009
darkpain
  • 316 Answers
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Posted on Jan 08, 2010
gaganddun
  • 114 Answers
SOURCE: I had recently purchased Samsung
Dear Meghna you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup thankyou and take care Gagan Gupta
Posted on Mar 15, 2011
Want to get on wi fi
Here's how you turn wifi on and off on your playbook:
http://helpblog.blackberry.com/2012/08/turn-wi-fi-on-off/
If it is on and you can see the wifi network you want to connect to, but still cannot connect. You need to contact the owner of the wireless network and have them provide you with their wireless password or passphrase.
I hope this helps.
Jul 09, 2016 | RIM Blackberry Playbook with 64GB Internal...
Wi-fi won't turn on
Hi, go into manage connections,
then wifi network,
then search for your wireless,enter pass key if needed,
then save.
Your phone will automatically connect to your Wifi any time you are in range.
My son has a blackberry and thats how I connected his.
Hope this helps.
Mar 08, 2012 | RIM Blackberry Curve 8900
Connected to wifi but cant browse internet on my blackberry 8520.
Solution:-
Disconnect from all connected network & then Reconnect to wi -fi.
Restart & configure your Wi-Fi- Router.
Thanks.
Happy to help you.
Apr 25, 2010 | RIM BlackBerry Curve 8520 Smartphone
Blackberry Bold use Wi-Fi network or mobile first
Yes, the Bold 9700 will use wi-fi in preference to the mobile network whenever both are available. I had one for a month, it was my primary means of internet access and I didn't get charged a penny for any data usage. I used it on both my home wireless network and in many public hotspots.
In any case, it's easy to check: the top of the screen will show the wi-fi logo in white when connected and greyed out when wi-fi is switched on but not connected.
I hope that this answers your question, if so then please take a moment to rate my reply. If not, then please add a comment and I shall expand upon my answer to suit your needs.
Mar 31, 2010 | RIM BlackBerry Bold 9700 Smartphone
WIFI
connect to wifi using my blackberry curve 8520 1. Click icon Manage Connection
2. Check/click on Wi-Fi ON
3. Scroll down and see “Set Up Wi-Fi Network”, click Next
4. And now click Scan For Networks.
On this step BlackBerry will scan all of the Wi-Fi around you. Find the Wi-Fi that you want it and save if needed.
5. If you know the SSID network, you can Manually Add Network. And now click theBlackBerry menu and click Connect.
6. If you ask for password, fill it. Usually in free Wi-Fi hotspot there’s no password needed.
7. The next step is fill the name for the Wi-Fi connection to save on Wi-Fi profie or you can just click to Connect. Click Next to continue..
8. The Menu will be back to Manage Connection. Check the Wi-Fi Options to set the UP address is it using DHCP (on BlackBerry it will said “Automatically obtain IP address and DNS”) or using static IP address. If using DHCP you can browsing to Internet but you must change the setting at the browser on the Main Menu -> Options -> Advance Options -> Browser. Change the default browser configuration with the HotspotBrowser. Good luck to surf on the net!
9. But if it’s need manually fill the IP address. You can go to Wi-Fi Options, Hightlight Wi-Fi profile which you already save previously, click the BlackBerry Menu, Edit, Highlight the text “Automatically obtain IP Address and DNS”, click BlackBerry Menu, Change Option, fill the IP one by one (default is 0.0.0.0). And click Save. And don’t forget to change the browser by follow the step on number 8.
Happy surfing on the internet using Blackberry!! But do not forget turn-off the Wi-Fi to save the battery lifetime.
Mar 26, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do I get connected to the wifi ?
First you need to check you have wireless network working fine.Try connecting your laptop.
If yes then scan the wireles network From the list of available Wi-Fi networks, click the appropriate Wi-Fi network in your BlackBerry and type in valid network key (WEP OR WPA).
Nov 10, 2009 | RIM BlackBerry Pearl Smartphone
Permanently remove aim and yahoo off of my blackberry curve 8330
Before I got my BlackBerry Bold I was a BlackBerry Curve user. I had a T-Mobile BlackBerry Curve 8320. The 8320 has Wi-Fi and supports Unlicensed Mobile Access (UMA). The other Curve models were 8300, and 8310. The 8310 has GPS but no Wi-Fi. The 8300 has neither GPS nor Wi-Fi. I chose the 8320 so I could make use of the free calling on UMA.
The original Curve is a great BlackBerry. It fits in your hand well, it is light, the keyboard is great, and the screen is beautiful. When you made the choice on which Curve to buy however, you had to decide whether you wanted Wi-Fi or GPS. Wi-Fi allows for UMA (translation free calling) and super fast Wi-Fi browsing if you associate with a HotSpot. GPS allows for location based services (LBS). Sometimes it became a tough choice because after all, wouldn't we all rather have it all?
Well when RIM sent me the new BlackBerry Curve 8900 to review I was excited. This new Curve doesn't make you have to choose. On top of that, it is a jump forward in technology and features that are very welcomed indeed.
Sep 11, 2009 | Cell Phones
I cannot make a wi-fi connection
are you that ******* stupid that you think that blackberrys have wifi you ignorant lowlife ***** you cheap ***** blackberrys do not have wi fi you better go to a low quality iphone with that **** you have been dismissed wiht your stale ***
Jun 17, 2009 | RIM BlackBerry Storm 9530 Smartphone
Failure of wi fi connection
Go to manage connections and check wi fi is turned on and scan for the available network.and connect to your net work.(also make sure your wireless router is working fine)
Feb 27, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
Cell Phones Logo
65 people viewed this question
Top Blackberry Cell Phones Experts
raysaw
Computer Repairing
Computer Repairing
aliasger yq
Are you a Blackberry Cell Phone Expert? Answer questions, earn points and help others
