Question about AEM 2000 Ford Explorer - Sport, 4.0L V6 - Brute Force Air Intakes
After replacing neutral safety switch, I lost reverse... what happened?
Checking that the bands and seals are good.
    Sergeant:
  • 299 Answers
Make sure you pluged all wires back in and vacuum hoses
Posted on Nov 22, 2014
Reverse light not working what to do
If bulbs are good then you need to check the switch that powers them when you put the car into reverse.
FYI - Neutral safety switch prevents car from starting unless it is in neutral transmission position only.
Oct 05, 2015 | Cars & Trucks
Reverse lights not working
Neutral safety switch control the reverse light.
Check for moisture damage in neutral safety switch.
Jan 13, 2014 | Dodge Grand Caravan Cars & Trucks
I have a 94 yukon that I need to know where the neutral saftey switch is located at. The reverse lights stay on in park but not in reverse this happened after I, let someone replace the brake booster and I...
Neutral Safety Switch
Print
REMOVAL & INSTALLATION
The back-up light switch is incorporated into the neutral/park safety switch. The neutral safety switch on 1988-94 models is mounted in the steering column.
Nov 16, 2013 | Cars & Trucks
2003dodge caravan neutral safty switch
Test/Service/Replace Neutral Safety Switch
Most neutral safety switches are combinations of a neutral safety switch and a backup lamp switch. Others have separate units for these two distinct functions. When the reverse light switch is not part of the neutral safety switch, it seldom needs adjustment, as it is directly activated by the transmission or the gear selector linkage.
f_ttat_t3.20.jpg Typical location of a neutral safety switch on a transaxle. Reprinted with permission of Ford Motor Company. A neutral safety switch allows current to pass from the starter switch to the starter when the lever is placed in the P or N position. Some neutral safety switches are nonadjustable. If these prevent starting in the P or N position and the gear selector linkage is correctly adjusted, they should be replaced.
To adjust a typical neutral safety switch:
  • Place the shift lever in neutral.
  • Loosen the attaching bolts for the switch.
  • Using the angling pin, move the switch until the pin falls into the hole in its rotor.
  • Tighten the attaching bolts.
  • Recheck the switch for continuity. If no voltage is present, replace the switch.
  • The switch sometimes controls the operation of the back-up lights also. With the engine off and the key on, put the selector in reverse position. Check the back-up lights to see that they are on. Then, check in the drive position to see that they are out.
Aug 15, 2012 | Cars & Trucks
Where is neutral switch on a 92 dodge caravan
Safety Switch Most neutral safety switches are combinations of a neutral safety switch and a backup lamp switch. Others have separate units for these two distinct functions. When the reverse light switch is not part of the neutral safety switch, it seldom needs adjustment, as it is directly activated by the transmission or the gear selector linkage.
May 10, 2012 | 1992 Dodge Caravan
1990 Honda accord exr only clicks when I turn the ignition. Replaced battery, still the same.
Try checking the shift position switch( neutral safety switch). this prevents the car from starting while the transmission is in drive or reverse. Try starting your accord while moving the shift selector around. Also, try looking at your starter. sometimes the wires corrode, and fall off, which would make it click and not start. also, check all of your fuses,
!!GOOD LUCK!!
Matt
Jun 14, 2011 | 1990 Honda Accord
I have a 1995 jeep wrangler and the reverse lights do not work
First thing I would do if you haven't already is replace the bulbs. You may want to have one bulb out and see if anything happens with a multimeter when it's in reverse. You most likely will need two people for this job. Most likely I would guess either a fuse, or your neutral safety switch is to blame. The fuse would most likely be the turn/bu fuse. The neutral safety switch is about a 20$ part and fairly easy to change.
Thanks,
Lee
Feb 21, 2011 | 1995 Jeep Wrangler
I trying to replace the neutral safety switch on my 2000 grand caravan 3.8 L 4 speed transmission. I know that its an internal part just trying to replace it. Thanks for your help. Steve
remove the shift linkage at top of trans. 10 mm pinch bolt. place trans in low gear before removing linkage. this will help later. unplug neutral switch connector. remove bottom transmission pan and and drain fluid. remove all the 10 mm bolts on the valve body. careful when removing vb because 2 sets of springs will fall out. it is important that they go back in the same holes they came from.there are two pistons under the springs. they go in the holes first with the recess towards vb. remove blue seal from vb shaft. its only a dust seal . remove # 25 torqx bolt from sensor and slide off shaft.reverse procedure. if you have doubt about the location of springs look at witness marks on vb. i recomend using factory fluid and have the codes cleared and a quick learn procedure preformed with a scan tool.
Oct 13, 2010 | Dodge Grand Caravan Cars & Trucks
Back up lights don't work and i already changed the light bulbs and the fuses are all fine
If you haven't checked for power going into the socket, or if the ground is good. I'd say you have a faulty neutral safety switch on the transmission. When you shift the gears it keeps the vehicle from starting unless it's in neutral or park. It also senses when you are in reverse and sends power to the reverse lights turning them on.
Mar 22, 2010 | 1998 Jeep Grand Cherokee
1993 FORD CROWN VICTORIA has no reverse gear when engine warm.
No band for reverse,sounds like you have a trans. in need of repair.
Jan 22, 2009 | 1993 Ford Crown Victoria
AEM 2000 Ford Explorer - Sport, 4.0L V6 - Brute Force Air Intakes Logo
55 people viewed this question
Top AEM Tools & Hardware - Others Experts
D. E. Hev
Tom
Are you an AEM Tool and Hardware - Other Expert? Answer questions, earn points and help others
