Question about Shark Sonic DuoTM Carpet & Hard Floor Cleaner
How do I empty out the dirty water?
Where does the dirty water go?S
Why is my clean tank emptying immediately to my dirty water tank?
Hi Medori! It sounds like you have an issue with your pump assembly. We recommend taking your unit in to a Hoover authorized service center. For your convenience I have included a link to our service center locator. Hope this helps!
Service Center Locator
Aug 02, 2014 | Hoover Max Extract Pressure Pro 60 FH50220
Why does red ball stop operation?
Hi there! The red float is there to let you know when your dirty water tank is full and needs to be emptied. If the float is popping up and the dirty water tank is empty or not full this is an indication that the dirty water tank filter is dirty and needs to be cleaned or replaced. Follow the link below to order a replacement filter for you vacuum.
Search Results
Hope this helps!
Jul 28, 2014 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Why is my retrieval tank light on when its empty hoover f8100900
Hi Tara! Try removing the dirty water tank and replacing it. If the dirty water tank is seated properly, you may have an issue with the sensor on the cleaner. We recommend taking the cleaner in to a Hoover authorized service center. Please follow the link to locate the nearest location to you. Thanks!
Jul 15, 2014 | Hoover F8100900 Platinum Carpet Cleaner
Scooba 390 empty dirty tank
it is trash do to the fact that it is not receiving suction to pull the dirty water to the dirty resavore
Mar 24, 2014 | Eureka Atlantis 2590A Wet/Dry Vacuum
Featherlite model 3M-852H
see this instructions:God bless you
Ensure the Dirt Devil is connected to a working power supply if it does not turn on or operate. Check the fuse or breaker and replace or reset as necessary.
  • 2 Empty the dirty water tank if there is little or no suction. Turn off the Dirt Devil and grab the top of the dirty water tank. Push on the latch to release the tank and pull the tank off the base. Remove the lid and empty the dirty water into a sink. Replace the cap and hook the front of the tank onto the machine base. Hook the nozzle on the base so that the nozzle is level with the cleaner base. Push the back of the dirty water tank down and into position.
  • 3 Check the dirty water tank and empty as necessary if there is water leaking from the cleaner. Open the latch on the top of the solution reservoir and pull the reservoir forward. Fill with Dirt Devil brand cleaner to the fill mark. Fill the rest of the reservoir with hot water and close the cap. Replace on the base unit.
  • 4 Make sure the solution reservoir is seated firmly in the base unit if there is no cleaning solution dispensing from the unit. Fill the solution tank with cleaner and water if the level is low.
  • 5 Examine the hose and nozzles for possible obstructions if the carpet cleaner does not seem to be operating correctly. Remove any blockages.
  • Jul 19, 2012 | Vacuums
    Water not emptying
    check if the dishwasher is level. designed to drain correctly under level conditions.
    Apr 21, 2012 | Bosch Dishwashers
    Just got spinscrub this afternoon and worked great until had to empty dirty water. Now there is no suction at all. Have tried to find clogs and nothing to be found. Am about to return the damn thing!!!
    ok 3 things to check before re-boxing it up.
    1) make sure that the lid is on properly. it should go on with the 2 tabs at the front of the machine, then click into place at the back of the machine.
    2) when you emptied it, sometimes the dirt channel will fall out. This allows for the suction to go between the dirty tank and the clear channel for the water to be sucked back up.
    3) when you remove the dirty water tank again, look down inside the machine for a circular hole. there should be a rubber gasket on it to seal up the tank for your suction. If it has come loose or is missing, retrace your steps between the machine where it was last used and the sink or wherever you dumped out the dirty water.
    Good luck,
    Mark
    Nov 11, 2010 | Hoover SteamVac F5914-900 SpinScrub...
    I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
    Suggest that you do the following.
    Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
    Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
    Power the machine on.
    On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
    With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
    Is all of that happening?
    Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
    Dirty water keeps coming out wen steaming , how do i clean it and stop this
    Empty, then fill with vinegar, hold above a towel and let it steam till empty
    Repeat with distilled water.
    Nov 04, 2009 | Tefal UltraGlide Easycord FV4256 Iron
    Emptying the powerbrush
    Gently
    press the Quick Release tabs on the Clean/Solution Tank
    and slide the tank off of the unit.
    Grab the Dirty/Collection Tank and pull to remove.
    While at the sink, remove the Tank Cap by turning
    approximately 1/4 turn counterclockwise and lift
    out the cap.
    Empty the tank. Rinse the Dirty/Collection tank with
    warm water.
    Replace cap and turn approximately 1/4 turn clockwise,
    until snug.
    Slide the Dirty/Collection Tank into the unit. Replace the
    Clean/Solution Tank.
    The tabs on the side is what locks the tank on, if they won't release the tank, then you may have to take apart to get it off and replace the tank.
    Jan 30, 2008 | Bissell SpotLifter 1716 Bagless Handheld...
    Shark Sonic DuoTM Carpet & Hard Floor Cleaner Logo
    59 people viewed this question
    Top Shark Home Experts
    MightyMikeJr
    David Payne
    David Payne
    Are you a Shark Home Expert? Answer questions, earn points and help others
