Question about LG Optimus F3 LS720 VM720 Blue Premium Silicone Case
Cannot pair lg optimus with fitbit keeps saying wrong pin or passkey bought this phone because they told it would work an not happy
Have got dashboard downloaded on phone
SOURCE: Passkey
Passkey is: 0000
Posted on Jan 21, 2008
Tabani
  • 129 Answers
SOURCE: how to get a bluetooth passkey
hi there,
if you are pairing the bluetooth headset device with your cell than the default passkey is 0000 (you can also check the user guide for bluetooth headset). and that will work with your phone.
if your pairing the phone with other phone then you need to create your own passkey to pair it with other device (try 1234) and the same key you have to write on other phone once you will do that your phone will be paired and you are able to use it.
i hope it will help you.
best of luck
Posted on Mar 23, 2009
  • 53 Answers
SOURCE: Passkey wont work with my new Lg xenon
okay your passkey is usually the last four digits of your phone number with your other phone enter the same passkey.This should work if not let me know.
Posted on Aug 25, 2009
  • 127 Answers
SOURCE: don't know pin # to pair my phone with the lg
try 0000 or 000000
Posted on Oct 17, 2009
SOURCE: my mobile made by LG keep saying -invalid USIM card
This has alos happened to me, I put in the wrong pin 3 times, then as it was laste and it was asking for a puk, I turned the phone off to save the battery, when I turned it back on it came up 'Invalid USIM card' is there anything that can be done?
Posted on Jan 12, 2010
I am unable to pair my H720 Bluetooth headset to my LG d500cell phone
Hi Beatrice,
You can check this link H720 Bond Pair for more information about how to pair your Bluetooth device.
Regards,
Maya
Motorola Support
Feb 01, 2016 | Motorola Mobility H720 89382N Bluetooth...
I have an LG Optimus M. It says the SD card is not installed. I have 2 of them. I reformatted both and it's still saying that. My computer recognizes both SD cards but not my phone.
Hi Everyone,
I had the same problem, and fixed it by very gently bending the Micro SD pins up a little. See the picture below, remove battery first, get a very small screw driver or other implement and one at a time bend each of the 8 pins up slightly, you do not have to bend them much so be very careful. Make sure none of the pins are touching when finished. So the cause of the fault in my LG Optimus GT540 phone was the pins had flattened and were not contacting the contacts on the Micro SD Card well enough. Which is a bit of a design fault really because my original card stopped working because of this and ended up fried. I done the fix above when the new card I bought and checked that it worked on my computer, but when I put it in my phone would come up with the message SD Card removed.
Hope this helps!
Regards,
Peter
May 24, 2011 | LG GT540 Cell Phone
I cannot pair my LG phone to my Blueant X3 micro bluetooth headset. The phone recognizes it, but doesn't let me pair. During the attempt, I receive "device pairing incomplete" then I am asked to enter a...
You have to turn off the Dare's autopairing feature. The Dare was designed to autopair with devices using the 0000 code. The Blueant X3 uses the code 1234 so the autopair won't work.
Once you turn the feature off, start the pairing process all over again and it will work.
Unfortunately you'll have to turn the X3 on through the Dare's bluetooth menu every time you want to use it. You can't use the "on" button on the X3.
Sep 26, 2009 | LG Dare VX9700 Cell Phone
How to get a bluetooth passkey
hi there,
best of luck
Mar 23, 2009 | LG RUMOR Cellular Phone
Passkey not working to pair headset to phone
with your phone STILL ON remove the battery, wait 5-10 seconds replace battery..power up phone and try to pair. should work after phone resets itself.
Feb 12, 2009 | Cellular Innovations HFBLU-AX1 Bluetooth...
Bluetooth pairing
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
Nov 25, 2008 | Motorola Mobility HS850 Consumer Headset
Passkey
The passkey is 0000
Dec 25, 2007 | LG HBM-550 Wireless Headset
LG Optimus F3 LS720 VM720 Blue Premium Silicone Case Logo
647 people viewed this question
Top LG Sport & Outdoor - Others Experts
 Brian Main
Brian Main
WILLIAM
WILLIAM
Are you a LG Sport and Outdoor - Other Expert? Answer questions, earn points and help others
