Question about Garden
My 2006 Polaris Ranger 500 EFI will not start. It has good spark on spark plug and it is getting fuel through the injector. What is my next step for trouble shooting?
Checked spark plug and made sure it is getting fuel
    Sergeant:
  • 299 Answers
Are you getting a back fire through the exhaust or the throttle body if so then you may have a stuck valve if not check the connecting boots for air leaks and do a compression test you could have a bad head gasket maybe even a hole in the piston top good luck and feel free to email me back if you need i believe you can reply to the notification email if not then post an answer to this post and ill get a msg in my email good luck
Posted on Nov 22, 2014
Polaris ranger 500 efi 4x4 2012: will not idle when first starting up. I have to give it gas to get it moving. once it warms up it is fine. any thoughts?
Sounds like the jets are cloged up you will need to pull off the bole and clean the pre jet and you shuld be fine
Nov 30, 2015 | Polaris 2012 Ranger 500 EFI
2010 polaris spotsman 500 motor runs rough and backfires.?
firing order is wrong/timing has changed. have you been fiddling with it. otherwise it could be a faulty spark plug.
Sep 02, 2014 | HMF Polaris Ranger 500/800 Efi 2010 Swamp...
. What steps do I need to do before taking it to shop?
Check the battery, fuse and related connections assuming that it has no power.
If the engine will spin over with the starter button and it will not start then the first thing is make sure it has fuel in the tank, second make sure it has spark on the spark plug, compression test next. Also listen to see if you hear the fuel pump running.
Aug 18, 2014 | Polaris 2007 Ranger 4x4 EFI
Shut machine off then go to restart and it wont fire
if thats all the info you have you need to take it to the dealer.
those have way to many possible problems.
1. bad spark plug seal, dirt fills up the entire spark plug hole especially sand.
2. they have fuel pump pressure issues due to poorly constructed fuel pressure regulators.
3. fuel pump itself
4. if intake or exhaust is modified it may overheat after it shuts off (engines get much hotter after they are shut down) will not start if too hot
5. one of the three ignition coil might be failing
6. CDI may have failed
7. Spark plug might be hot fowled.
Mar 03, 2014 | Polaris 2013 Ranger 500 EFI
Ranger hard starting cold 2006
sounds like lack of compression
Jun 07, 2013 | Polaris 2006 Ranger 4x4 EFI
Service manual for a 2006 500 Polaris Sportsman HO
I have a 2006 Sportstman 500HO ATV, EFI. Sometimes it will run 100% correct, other times it will start, idle fine but then when giving it throttle will will start to surge almost like it's hitting a rev limited. Sometimes it will backfire and stall. I already replaced fuel filter, flushed the fuel lines and gave it fresh gas and installed a new spark plug, but no good. I also checked the throttle switch and it's not making contact to stall it. I download the service manaul and tested each sensor and they tested fine which is probablt why I get no check engine light.
This ATV is mainly used to plow snow in my driveway, no salt. It's used around my property but very lightly. It's still as clean as it was when I bought it and it doesn't have but about 40 hours on it.
Polaris 500 HO EFI 4x4 ATV: Vin# 4XAMH50A56B707664 purchased 6-8-2006
gtopercy@comcast.net
May 20, 2010 | Polaris ATV
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
