Question about Home
<!-- from fixya rte -->Clear bosch smoke detector - Home
  • Smoke help
    Smoke help Jun 14, 2015
    Hi Reed Anderson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Which model detector (if possible) and on what kind of system, eg, Radionics 4112, Bosch 9112GV2, etc. Thanks!
I have 6 smoke detectors & two CO2 detectors hardwired in. The smoke detector in the kitchen went off and now all the detectors will not stop alarming. How do I reset?
First of all, you really should not have a smoke detector in the kitchen as it will be far too prone to false alarms, especially since most household smoke alarms are ionization type, which respond to the presence of gases caused by combustion. A proper system as recommended by NFPA will have one detector in each bedroom, one in each bedroom hallway, and recommended one per floor thereafter, with placement being near exit points to help guide you to the exit during an actual fire (by sound, since it's difficult to see through smoke). I would be inclined to remove that device or try to find a heat detector replacement, such as Kidde Model # HD135F. For now I would vacuum out the device or try a can of compressed air to blow it out, but I would not leave that device long term.
Sep 13, 2015 | Home
I have replaced the batteries to the smoke detectors and they keep beeping. What is the problem?
It is possible that the battery is not contacting the metal clips inside. See if the can be adjusted out. More likely the detector is not recognizing the voltage of the new battery. You can try removing the detector from the ac power install the battery and reconnecting it to the ac. It should correct the issue.
Sep 16, 2014 | First Alert SA302 Dual System Smoke...
Nortron smoke detector
It may be urging you to change the battery...
May 09, 2014 | Home
Smoke detector looks burned
Air may flow through the unit if you don't have a vapour barrier wrapped around the electrical box in a ceiling with an attic above. The smoke detector may look smoky and it may have come from cooking grease in the air. This may foul the smoke detector. All smoke detectors have a piece of radioactive americium-241 that creates ions in an ionic chamber. This chamber has to be pristine. That is why smoke detectors have a replacement date on them. It may be time to get another one. Some kits come with a cardboard baffle to stop so much air sucking through the unit.
Nov 07, 2013 | Kidde 1275 Hardwire Smoke Alarm with Hush...
Where should I install a smoke detector?
The National Fire Prevention Association (NFPA) states that the best location for a smoke detector is on the ceiling near a doorway or stairway.You should also have a smoke detector on the hallway ceiling outside of sleeping areas (bedrooms). Put one either inside or just outside the kitchen.
May 09, 2013 | Home
How do you test a Honeywell smoke detector
Home Depot or Lowes sells "smoke in a can". Use it sparingly to test your smoke detector.
Apr 10, 2012 | Honeywell 5808w3 Photoelect. Smoke Heat...
Goes off only at night with NO warning cleaned & changed batt. 4 times so far !!!!
These types of smoke detectors are PHOTOELECTRIC, the way it works, there is a IR transmitter and a IR receiver placed in a dark chamber aligned at a 45degree angle, when smoke enters the chamber IR light bounces of the smoke and than generating an alarm, so in conclusion if there is a lot of DUST in the chamber it reflects the IR light just like smoke, than can generate an alarm, try blowing air in the smoke detector (gentely) if it does not work replace the smoke detector...
Feb 04, 2011 | System Sensor 2100rfadt Wireless Smoke...
Our smoke detector keeps chirping spontaneously. Already replaced the batteries without silencing the chirping. The only way we have found has been to totally unplug it from the unit! What could the...
First try vacuuming out any dust that may be in the unit. If that doesn't work, replace the smoke detector.
Most detectors have an expected life of 10 years but I've seen some fail sooner. There are two types: one uses a beam of light that gets interrupted by particulates. The other uses ionization to interact with and detect the smoke. Ionization ones work with a small amount of radioactive material.
The photoelectric ones are good for identifying smoldering, smoky fires. The ionization type of best for fast flaring fires. For really good protection, get a smoke detector with both methods. (It will be more expensive though.)
I hope this helps.
Nov 26, 2010 | Kidde Smoke Detector
I could not get to battery compartment of the first alert smoke alarm. Please tell me how to replace with new battery.
Hold the entire smoke detector,turn it to the left or right,u will able to take the smoke detector out.The battery compartment is in the back.
Sep 09, 2010 | First Alert SA302 Dual System Smoke...
Smoke alarm/carbon monoxide detector
I have a First Alert Smoke Detector Model SA 86RAC.When I changed the Battery today it beeps.How do I fix this problem?
Sep 22, 2007 | First Alert SA302 Dual System Smoke...
Home Logo
390 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
