Question about Fisher Washing Machines
I have a Fisher Paykel clothes Washer Model WL42T26KW1. It has quit agitating. It spins, and rinses, but does not agitate. None of the lights are blinking and it is not giving any warning beeps. Can y
Unplugging, resetting, remove agitator.
    Scholar:
  • 91 Answers
Push power button and start button together, push water level up than push start button, turn machine off at wall and unplug it, plug back in and start machine as usual, that may fix the problem, if not, suspect the ECU board is faulty
Posted on Nov 27, 2014
Testimonial: "My washer is an aquasmart. It does not have a water level button, it is an automatic function. I think you are talking about a echosmart washer."
fanny
  • 146 Answers
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
jumptrout51
  • 3361 Answers
SOURCE: ge toploading washer will not agitate
Simply pull up on it very hard.
It will come off.
Posted on Mar 15, 2009
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
**** buildup in top load washer. what to do
Unscrew the agitator and wipe out all accumulated muck. Screw agitator back on, and put through a rinse cycle with white vinegar and bicarbonate soda. This will flush any residual scum. You may have to repeat procedure every 6 months.
Dec 03, 2012 | Fisher and Paykel Fisher & Paykel Washer
Fisher Paykel GWL 15 Rotor Position Sensor
Does It just shake bowl left & right, it will soon give you fault code 56.
Well its a board problem you will need to get technician to fix this board, three resistors(R129,R130,R131) need to be changed for a 1MegOhm resistor.
Jul 08, 2012 | Fisher and Paykel GWL11 Top Load Washer
Suddenly stopped when initiating spin and emitted a smell of overheated electric components. This event tripped ground-fault protector outlet. Later discovered a piece of clothing trapped between agitator...
Your problem may be with a couple of components. What is your model number and do you get any error codes (lights on the console) on your washer?
Regards,Richard
Dec 07, 2011 | Fisher and Paykel Washing Machines
I still need help with my previous issue. My F&P
Hello, one off the first things in order to help would be the model number this way we are able to see which type of washher you do have. If this were a smartdrive type unit we could use something like this service manual click this link http://www.docstoc.com/docs/25379715/Fisher-_-Paykel-Washer-Diagnostic-Fault-Codes in which on this type of fisher and paykel washer you would count from left to right the 8 lights and list which led's were lit on the unit. There are of course other service manuals depending on which model you do have. I await your reply to the model number of your machine and if I dont see your response this evening I will look forward to answering any further questions you may have tomorrow. Thanks
Rick
Aug 25, 2011 | Fisher and Paykel Fisher & Paykel Washer
Hi, I have a WA75T65GW1 7.5kg top load washer. I run a favourites program with cold water cycle, auto level and fast spin. The cycle is getting stuck all the time between rinse and spin cycle, bowl is...
This problem will often occur with a light load of clothes. The beeping is usually the unbalanced load alarm. Often, redistributing the clothes around the agitator and moving the agitator manually up and down and side to side to center it again will fix the problem. You may need to advance a new cycle to where it spins out to empty the washer and run the laundry again.
Jul 30, 2011 | Fisher and Paykel Washing Machines
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel ecs washing machine.The agitator dosen`t turn any more so the clothes aren`t getting clean.The spin is working ok.What could the problem be??
This can a problem with the program controller unit as during the cycle there is no power to the motor so as to agitate.
You will need to check the controller , try with another program if not check the output when the wash cycle is on.
Feb 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
It keeps getting stuck on rinse cycle a
Check it out....
Good Luck!!
thanks
Jul 19, 2009 | Fisher and Paykel Washing Machines
Fisher & Paykel WA37T26G Washer
I have one and they are right. Both the drum and the agitator turn so that the clothes are not beaten up.
Also the electronic motor control is fully variable speed. It will go as slow as! Dial up for wollens and it almost massages them. The cycle time is 1/3rd of a front loader.
Jul 20, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
