I need to program my direct TV remote to my sharp TV LC-37G4U.
    New Friend:
  • 76 Answers
Here ya go. The power of a Google search...
https://support.directv.com/app/answers/detail/a_id/4028/related/1/session/L2F2LzEvdGltZS8xNDE2NjIwMzQyL3NpZC9KUUVlRyo3bQ%3D%3D
Posted on Nov 22, 2014
SOURCE: Programming the Acquos Remote
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Posted on Oct 21, 2008
SOURCE: remote control tv codes for sharp lc-32sb24u tv
I need the remote codes for sharp LC-32SB24U tv. Thank you!
Posted on Nov 23, 2008
Input code 0093 into your Comcast remote. Here's a link for the how to: http://www.comcast.com/MediaLibrary/1/2/CM/VanityURL/documents/comcast_dvr_remote_manual.pdf
Posted on Mar 01, 2009
  • 20 Answers
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
Posted on May 30, 2010
SOURCE: i need sky remote code for sharp tv model no lc-32sh7e
Hi there. I hope you will see this reply. I bought one of these TV's yesterday and I've got the code from my dad's website www.satcure.net
If your remote is Version 6 then you will be able to follow the help on the sky box under
Interactive
Customer service
Program Remote
Then follow the steps using code 1221
If you have a Revolution 8 remote then you will have an easier job but with a 3 digit code.
3 digit code is 253
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Hope this helps/works!
Posted on Jun 12, 2010
I have a sharp LC-37G4U and can not get it to load over air channels. this a digital tv but the only way they would load is with a converter. how can I download over the air channels on the tv
Unfortunately, the Sharp Aquos LC-37G4U TV is an HDTV-ready monitor. It does not have an ATSC (digital OTA) tuner. The A/V Center box (TU-GA1U-S) that came with the TV has two NTSC tuners. You'll need the over-the-air ATSC to NTSC (analog) converter box or a stand-alone ATSC tuner DVR set-top box to get most OTA channels. There are only low power NTSC tuners that continue to broadcast; you will only receive those stations if you are close to their transmitters.
Crutchfield has a nice list of the specifications for the TV here: http://www.crutchfield.com/S-4LS7pNsldXK/p_70037G4U/Sharp-LC-37G4U.html . The manual has the full specifications for the TV on page 100. Crutchfield has the manual here: http://pdf.crutchfieldonline.com/ImageBank/v20040615154800/Manuals/700/70032G4U.PDF .
I wish that I had better news for you.
Oct 21, 2016 | Sharp Televison & Video
I bought a sharp TV LC-37G4U off craigslist. I don't have the original remote & i need to get to the menu.
Many universal remotes can be purchased and programmed to get the menu to work on the TV. Many can be bought right down the street at a CVS or Walgreens. Also try Walmart.
Nov 22, 2014 | Televison & Video
How do I stop the CC on my Sharp Aquos
Try the remote.
On the remote is a button labeled CC near the bottom.
Press the button to access a menu to switch off. Each time you press the button it will toggle among the choices.
If the tv has problems, try turning it off and unplugging for a few minutes to reset the EPROMs.
Plug in and turn on. Repeat the above.
If you want to change the size/color of the font you can get into menu mode by pressing the menu botton in the center of remote.
Next use the and > arrows to get to OPTION menu.
Use the ^ and v arrows to get to the Caption Setup menu and press Enter.
Feb 22, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
How to Operate a sharp TV without a remote control
HOW DO I GET A REPLACEMENT REMOTE CONTROL FOR SHARP AQUOS LC37GA4X
Dec 10, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My sharp aquos 37
If it's the LC-37G4U model, double check the System Cable that links the TV to the box. Then, open the front cover of the box; with the TV ON, press the small SYSTEM RESET below the INPUT 3 port.
Let me know if this solution works.
Jun 01, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp Aquous Remote Codes
You can download the manual for the TV. It has all the code for the remote on page 90.
Here's the link:
LC-37G4U | LC-32G4U & AVC System Operation Manual (3900K)
Mar 31, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Tv remote controle codes for starchoice 5-in-1 remote (sharp aquos tv)
you might try unplugging the TV and then plugging in again. It worked for me
Nov 17, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp AQUOS LC-60C52U
hi had same problem easy fix get your sharp remote make sure you are on tv mode by pressing function button tv should light up on remote. then press view mode button(above 3) put setting on s.stretch and thats it bye bye green line.
Sep 08, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Out of sync message
When you first turn on the unit very quickly push the imput button to switch sources.It is stuck on the computer imput.
Feb 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
