Washer stoped and put out code sr will try to run for 3 seconds and stops model 1102506
  • 76 Answers
Post Brand and model number. Or- Google brand and model number with error code. ie.. "Maytag Elite model 12345xyz error code 1102506"
Posted on Nov 22, 2014
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
How to run a diagnostic for washer model MHWE450WW01 Maytag
Starting Error History Software Version and
Diagnostic Test:
NOTE: Washer must be empty and the control must be in the
OFF state.
1. Close the door.
2. Select any one key (except "STOP/CANCEL" and "CONTROL
LOCK" and follow the steps below using the same key:
Press/hold for 2-5 seconds, Release for 2-5 sec, Press/hold for 2-5 sec, Release for 2-5sec, Press/hold for 2-5 sec
3. Upon release, all yellow/green console LED lights will turn ON
for 5 sec.
4. If there are any failure codes stored by the washer, the display
shows them.
Note: The last four errors will be displayed.
5. Press the same key to advance to the next code.
6. After the indication of error codes, the UI, CCU, and MCU SW
version will be displayed.
7. The number of cycles since last clean washer cycle is displayed.
8. All green console LED lights will turn ON for 5 seconds.
9. Next the washer begins the automated diagnostic test.
10.To cancel out of service mode, press the "STOP" button.
Apr 10, 2014 | Maytag Washing Machines
Dishwasher Stuck Mid Cycle
Jiggle the water level float sensor .It is stuck .
May 14, 2012 | Maytag Dishwashers
Kenmore model 8566645 Washer is connected and runs but water flows out of the bottom and not into the tub.
Remove the front and side panels if you haVE TO. Look for a bad water pump most common on older units.
The fill tube to the tub from the fill valve is a second likely problem
I water filter located under the tub and in line with the water pump is also a possibility.
A bad hose is not likely but a connection to a hose could be a problem.
Jul 10, 2009 | Kenmore Washing Machines
Whirlpool Duet makes spinning sound but drum is not spinning.
What is the model number? To get your clothes out and the door open on that model, try unplugging it for awhile and open the door (you probably have tried that already. Some models you can take off the bottom panel and reach up and there is a little ring you can pull to open the door. (most likely) you might be hearing the pump running since it always run when spinning. If you give me the model number I can let you have the test code. You could try Pressing any key (not power or stop) hold it in for 3 seconds let go 3 seconds, press 3 sec, let go 3 sec, hold 3 sec let go. It should come up all lights on. Don't worry you can't damage anything in the test mode. Watch what it says. then press that same key about every 30 seconds to advance it. It's kind of hard to explain but I'm trying my best. It should at least unlock it in the process. Good luck
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool gold dishwasher GU180 wont start
I had the same problem with the exact same model - put your washer on the lowest wash setting - press and hold the start button for about 3 seconds. THe washer will run for about 5 seconds and then turn off (do not have the heated dry setting on when you do this).
Turn it off (turn the dial), and then try to re-wash.
Dec 25, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Kenmore he2plus
Being your local Sears repair man, I feel your pain. I also hate telling people that they will have to replace a very expensive board like that, but unfortunatly, that F1 code is usually a death sentence, especially to that model. try this, sometimes you can get lucky. Unplug the machine for about 10 minutes, then plug it back in. Thats about the only way you can "reset" the unit. You can also try to run a diagnostic test. Push and hold any button (besides the start,power, or cancel) for 3-5 seconds, then let go for 3-5 seconds, then push and hold same button again for 3-5 seconds, repeat this procedure until 88 displays on the control (or all lights come on on non-display models). If you have a display, it will read to you all failure codes (you will have to push the same button you used in the diagnostic start to move through all codes), then unit will start diagnostic tests when all codes have been retrived. If you have a non-display model, you will need the tech sheet (located behind the bottom panel or inside the machine on one side in an envolope). Each light will come on displaying a certian code, which you will then have to read the tech sheet to match the light configuration to its coresponding code. Wow, i think I have a headache, do it a couple times a day. If it is your board, one recomendation, check EBAY or online sales stores. They are a ton cheaper, and you can change the board easily yourself. Remove the top, wire to wire to the new brd, your on your way. Good luck, and let me know how it turns out.
Nov 03, 2008 | Kenmore 43142 Front Load Washer
Error code "sr"
Sr is a stuck relay on your main board.Replace your pc board.
Dec 30, 2007 | Maytag MAH8700A Front Load Washer
F code
I too was getting the f51code. After trying the above remedy, unpugging the power, and disconnecting and reconnecting all other connections,(none of these helped in my problem, however). I took off the back of the washer and manually spun the tub. Lo and behold, a t-shirt had gotten between the tub and the wall, thus creating my error code. It was easily removed with a straighted coat hanger.
Sep 18, 2006 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
