Question about Lenovo IdeaPad K1 10.1 inch Tablet NVIDIA TEGRA 2, 1Gb RAM, 16Gb Storage, WLAN, Android 3.1 - Black
How can i switch on back my lenova k1 android tablet that wont turn on?
I held down the power + volume down button but it dint work
    Master:
  • 193 Answers
Hello Ruth
If you tried the reset and it didnt work then most likely it wont come back to working again. Does it give any sign that it trys to power on?
Chadman
Posted on Nov 22, 2014
Don't have a computer other than my 10.1 Infinity V2 tablet by Android and I'm completely locked out. I forgot my front screen password can I Fix-It from my Android phone. it is in safe mode.
In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
Apr 27, 2016 | Tablets & eReaders
How to reset android Ls660Zv6
  • Hold down on the Volume + button and hold down the Power button at the same time.
  • As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen.
  • At this point you will see a screen with boot options.
  • Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option.
  • On the next screen use the Volume - button again to go down to Yes and use the Power button to select.
  • At this point it will be going through the wiping and resetting process.
  • When it's done you will see the first screen you came to when you first started the setup.
  • Just tap the Power button to select Reboot System Now.
Stuck in Android System Recovery Tips to Fix Recover Lost Data
Nobis nbo7 froze so I pressed reset now it won't power on or do anything
First, turn your tablet off. Then, power the tablet back up by holding down the volume (either + or - ) and power buttons simultaneously. Continue holding the volume button until the screen says "Booting tablet in recovery mode." This will give you a picture of an Android. Tap the android, and you will be given a screen with several options. Move between the options with the + and -, and select with the power button.
Feb 02, 2015 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
I bought the tablet off of face book yard sale and
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
or try this link out.
android man on his back with red triangle on his chest Google Search
Dec 15, 2017 | Tablets & eReaders
Why wont my proscan android tablet turn on ?
If you haven't done so already, try holding the power button down for a long time (30 seconds+) when you switch it on. If no success, try again but hold down the power button *and* the volume-up button when you switch on.
Aug 10, 2014 | Proscan 7-Inch Android Internet Tablet,...
How do i reset my android dragon touch tablet
Try holding power and both volumes if it reboots normally try again but let go of power when the Android pops up
Apr 17, 2014 | Tablets & eReaders
Lenovo IdeaPad K1 10.1 inch Tablet NVIDIA TEGRA 2, 1Gb RAM, 16Gb Storage, WLAN, Android 3.1 - Black Logo
87 people viewed this question
Top Lenovo Tablets & eReaders Experts
vojvodabudva
Are you a Lenovo Tablet and eReader Expert? Answer questions, earn points and help others
