Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
After filling oil tank, turned heater on. does not shut off at 70, keeps running. have to shut heater by emer. shutoff-bad thermostat
Heating only
    Problem Solver:
  • 20 Answers
Here is the user manual for your unit.
https://www.manualowl.com/m/Honeywell/CT87B/Manual/134033
Look at parts 7&8 of the manual. In section 8 there is a notation about the anticipator pointer adjustment that should solve your problem.
Posted on Nov 22, 2014
5 Suggested Answers
SOURCE: oil filled heater wont stay on
I was having the same problem and did a search to find this link. This morning when I turned it on, I backed the temperature down to 66 when it first came on (defaults to 70) and it appears to be working now (it's been on for over 10 minutes)
Posted on Dec 18, 2008
  • 5 Answers
SOURCE: heater won't blow heat and keeps running
first try to pull out the little white button on bottom left side. if it is already pulled out, then take cover off, lightly press on the center dial as you adjust the little adjusters that are in the dial. should be two of them, the first should say off set to 90, second one says on set to 130or 135. these steps may work. if not then one of the wire connections may be loose.
Posted on Apr 26, 2009
  • 5 Answers
SOURCE: day and night heater and a/c unit heater would go
first try to pull the little white button out, it is a manual control button, and the out position is auto. If that does not work try taking off the cover, lightly hold the dial down while you adjust the settings. they are on the side of the dial, first setting is the off pos. set to 90, second is the on pos. set to 125-135. then put cover back on, while being careful not to push the button in.
Therinnaiguy
  • 1420 Answers
SOURCE: the thermostat although programmed to heat to 70
Are you confident that it is the thermostat? I would first try would be to disconnect the wire on the R terminal of the thermostat and see if the heating system stops. If it does, then you have confirmed that the thermostat is in fact the issue. Replace it. If it continues to run on, you have a problem with the wiring or control board of the heater.
Posted on Feb 24, 2010
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
My 2002 buick century is loosing coolant fast. When car isn't running around 60-70 mph is seems to heat up more than normal and no heat or ac will occur. Should I replace the thermostat? I noticed the fan...
it sounds like one of several problems radiator needs flushed , water pump is bad or going, thermostat is bad, pin hole in one of the hoses, cracked head, hole in radiator, hole in heater core.if core is leaking you will notice water on the floor inside the car on pasenger side. if radiator has hole when you fill radiator with coolant it will leak froom fins sometimes only when hot. thermostat bad your car will read hot and or cold always. if stuck open cold, if stuck closed hot, after about 15 20 mins of running engine will cause radiator to boil over to over flow tank.never open radiator cap when engine is hot :) burn hazard.if pump is bad or going will notice gauge reads hot intermittent or always. will boil in to overflow tank. if head is cracked will notice water comming from side of engine block or in oil when you change oil. if radiator needs to be flushed will notice scale or gunk on radiator cap
(if you think you need help or do not have tools to perform please take to a machanic)
Mar 14, 2011 | 2002 Buick Century
The thermostat although programmed to heat to 70 will not shut off and keeps going until ridiculously hot.
Feb 24, 2010 | Honeywell Programmable Thermostat Heater
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
Thermostat set at 74, but air conditioner won't turnoff
Need to reset the lever sensitivitie( behind the cover) to a lower setting.
Jul 22, 2009 | Honeywell Heat/Cool Thermostat
Heat pump works in emergency heat, but not in auxiliary heat
I set the thermostat for 70 degrees. It comes on always in auxillary heat and does not shut off when it reaches 70 degrees. It is a heat pump, I am assuming, it might be the thermostat? But when the air conditioner is on, it turns off when it reaches it's temperature.
Jan 20, 2009 | Amana PTH123B25AJ Heat Pump Air...
Water Heater Replacement
1) After shutting off the water and gas or power supply to the tank, connect a hose to the drain valve at the bottom of the tank, open the valve, and run it to a nearby drain or outdoors. Use two wrenches to unscrew the inlet and outlet fittings from the top of the tank. 2) For a gas water heater, shut off the gas inlet valve and use two wrenches to disconnect the union or flare fitting between the gas supply pipe and the inlet valve. Also remove the flue hat that expels gasses into the flue at the top of the tank. 3) After removing the old unit, set the new one in place with the controls and burner accessible. Allow at least 6 inches of clearance around its perimeter, and keep it away from flammable materials. Use a level to check it for plumb; shim the base with pieces of asphalt shingles or plastic wedges. 4) Wrap the threads of the heat trap fittings with pipe-wrap tape, and screw the fittings into the water heater (blue into the cold water inlet and red into the hotwater outlet). Be sure the arrows marked on the fittings point in the direction of water flow. 5) Install new flexible connectors on the water inlet and outlet pipes. If there is no shutoff valve on the cold water side, install one before connecting the water heater. After all connections are complete, open the shutoff valve to fill the tank. While it is filling, open several hot water faucets in the house to bleed off air in the pipes. 6) Assemble the gas pipes as shown. Spread pipe dope on the threads, and screw together the parts, tightening them with one pipe wrench on the pipe and another on the fitting. Follow the manufacturer's instructions for connecting the unit with gas supply tubing. After turning on the gas, test all connections by brushing soapy water on them and watching for bubbles.
Aug 27, 2008 | Stiebel Eltron Tankless Water Heater
Heating & Cooling Logo
67 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
