Question about Air Tools & Compressors
Hi, I have a paslode im90i nail gun. Problem is it occasionally fires five or six on the bounce then goes back to normal, which is now 90 percent misfires. It cycles, it does everything OK, it fires and it releases/uses gas but produces no nail.. We put it in for a service and it worked for 9 to 12 times then straight back to how it was.. Hope somebody can give some proper advice as this is becoming incredibly frustrating.. Cheers....
    Sergeant:
  • 299 Answers
Go on paslode site there is a video on cleaning also there is lots of talk about expired gas cartridges get new ones it seems once they reach exp date they just don't work worth a darn
Posted on Nov 22, 2014
5 Suggested Answers
  • 24 Answers
SOURCE: Paslode nail gun will not fire
Make sure the spark plug ignites. Take tool apart as in cleaning. Hold micr switch near fan and watch as you pull trigger. you will see a spark. If not check the lead to igniter
Posted on Apr 14, 2009
  • 131 Answers
SOURCE: paslode nail gun not firing
Yes you need to oil driver blade piston.
You need to check for spark. With no nail or gas in it. Take of main cylinder(4bolts on top, 2 bolts on nose. And then put in battery. And then push upper switch(behind roller at top) and the fan will come on. And then pull the trigger. You should have spark.
Thanks,
Jeff
Posted on Jun 23, 2009
  • 24 Answers
SOURCE: NAILER WONT FIRE NAILS
DO NOT USE WD40 . Is The Nailer fireing? If Not check the micro switch by the fan . Make sure it is pushing on the switch.. Otherwise bend it a little
Posted on Jul 07, 2009
SOURCE: Paslode nail gun 325 black not firing
Any time these guns become intermittent or stop firing but the fan still runs, the first the to check is the expiration date on the gas cartridges. The do expire and this will make the gun work inconsistently or not at all.
Posted on Dec 13, 2009
Testimonial: "Thanks for that, i will look into it! Thanks for your time.... Cheers, Steven. ;-)"
My paslode impulse 1m50f18 fires normally but no nail apears with paslode nails?
not sure what you mean" no nail appears with paslode nails" if it fires make sure the nails are correct for your gun
Sep 08, 2015 | Air Tools & Compressors
Looking for the nearest repair shop for paslode nail gun in Northren Va
Have all the nails been cleared out of the tool where they were jammed? If not take the fuel cell out of the tool, and remove the battery before working on it. If still persists come back to this website for further help.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
My paslode model 350s nail gun only shoots every other nail or so. Sometimes it will only fire once every six or seven times I fire it. Any suggestios?
Replace the O rings if its not firing... if its dry firing (firing w/o a nail) check the feeder system/spring
Dec 05, 2012 | Air Tools & Compressors
My paslode im90i nail gun uses loads more gas than calculated nails per gas and is costing me money
are you useing it in the temp range on manual, that will make a diff.
May 20, 2011 | Garden
Paslode im90i fires ok but nail dose not come out but firen pin does
my paslode im90i nail gun uses loads more gas than the calculated nails per gas and is costing me money
Mar 20, 2011 | Craftsman Nailer Kit, Palm Air Driver
Paslode nail guns won't shoot
piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
Feb 18, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Dec 08, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Paslode air framer not sinking some nails
Your air pressure is dropping everytime you fire. It sound like your compressor is not cutting back in untill it to low. Not giving your tool enough continuess pressure. Your compressor cut in pressure should be around 90-100psi no less. and your max. pressure no more then 120psi. (Make sure your regulator is set at 110psi)
good luck...!
Aug 11, 2009 | RTO Paslode #650027 2500CT Placement Nail
Paslode nail gun not firing
Thanks,
Jeff
May 16, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Air Tools & Compressors Logo
201 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
