Question about Bose Acoustimass 5 Series III Speaker System
My son was playing with the speaker cube and the push button, internal springs, and clips fell out. He tried to fix it himself and pushed the button back into position. I need to get the button out a
My son was playing with the speaker cube and the push button, internal springs, and clips fell out. He tried to fix it himself and pushed the button back into position. I need to get the button out and reattach the springs and clip under the push button,and then set the button in position correctly so I can reattach the speaker wires. Please HELP..
    Problem Solver:
  • 8 Answers
Have your son "play" with it again, or at least have him show you what he was doing when it "fell" out, he may have stumbled on the technique, but chances are a tab has broken off meaning it should be easier to remove now. Good Luck!
Posted on Dec 10, 2014
4 Suggested Answers
  • 1257 Answers
SOURCE: bose acoustimas double cube speaker
Try to see the 2 ends at the speaker you have open and arrange that 2 springs and 2 metal clip to that 2 ends to reconfigure it properly...
Posted on Jun 17, 2008
SOURCE: Double cube fell and separated
Use a Flat blade screw driver to take off both grills. Take both speakers out use a phillips screw driver. Put your fingers in the cube with the protruding grommet, turn the object until you see it protruding its maximum. Next align it with the opening in the other cube and press until you here it click back together. re-attach speakers and put grills back on ..Whala!!!
Posted on Oct 03, 2009
SOURCE: detached cube speaker
I had the same problem.
Step one: pop of the grille with a screwdriver or knife inserted from the bottom so that any marks will be hidden when you get the two halves back together.
Step two: If the speaker is held in by screws, you are lucky. Just unscrew the speaker and remove it. If the speaker isn't held into the case by screws, it is a newer model that is glued to the back cover / box. You can separate the glue with a bread knife or thin screwdriver (I used a paint scraper and thin screwdriver). Be careful to work around all four sides. Also, there is a small (about 1/4" long) plastic bump in the center of each of the four sides that clips into a matching groove in the speaker, so you will have to spring apart at least two adjacent sides at the same time to release the speaker from the cover easily.
Step 3: Once you have the speaker out, remove the acoustic sponge, and sit the bottom half on a solid table. Make sure the rubber gasket between the speakers is seated properly and note the position of the 3 notches in the hole of the bottom speaker cover. Place the top speaker cover in place and insert the white plastic 3 pronged clip though the the hole so that the prongs match the notches. Press down hard with two thumbs and it should snap into place.
Step 4: Replace the sponge and push the top speaker back into the cover. Replace the screws if you had them. Otherwise you can glue it again but the clips are quite solid if not damaged by the removal so you can save some effort the next time it happens by leaving it unglued, and just snapping the speaker into place.
Step 5: push the grille back on.
Posted on Dec 28, 2009
Small red clip appeared on rim after being off balance. spring attached.
There is a small red clip that holds a stabilizing spring (notice items 7 & 8 in the graphic) which attaches to the top of the tub cover at the front, left side. You might be able to push the tub assembly to the back, right corner to better see this, but it is easiest to reinstall with the top of the machine removed. If the clip is broken or the spring stretched they will need to be replaced. The unit can work without these parts, but is more likely to experience out of balance problems.
Mar 11, 2015 | Fisher & Paykel Paykel White WashSmart Top...
Bose acoustimas double cube speaker
what the exact model # of the unit..?
Jun 17, 2008 | Bose Acoustimass 16 Speaker
Iphone 4s sleep button, speaker, microphone, headset jack are not working
It probably fell onto the headphone jack and something got messed up there. That's a problem that you could maybe fix by taking it apart and reseating the button actuator. If it fell onto the button, it may have pushed the actuator farther into the phone. The button pushes down on another button inside that is part of the actuator module, so may have been pushed around.
Mar 27, 2014 | Cell Phones
1995 Lincoln Mark VIII radio on/off button sometimes pops up
the spring loaded retention clip is probbably broken in the radio...toothpick.quick fix... replacement....expensive fix!
Apr 10, 2013 | 1995 Lincoln Mark VIII
I can only get crushed Ice when the Cube Button is pushed. it seem the Cube Buton has failed. What can I do to solve this problem
Pretty easy fix if you are somewhat handy with a screw driver. Remove the tray holding ice, on the side of that tray should be a metal rod that activates the crushed/cubed function. There is a motor on that activates a lever that will push the end of the rod down or pull it up depending on what you have selected.
Motor could have been frozen, since it is in the freezer, but you need to remove the mounting bracket and spiral rod assembly. To remove this there are two small bolts on the bottom of that bracket, remove those and lift up on the entire bracket assembly. This will remove from the mounting bracket at rear of freezer. Now for the hard part, you need to unplug the wire connection that runs into the back of the freezer. There are two plastic clips on each side of that connector. You need to push the top of those clips on both sides and pull the connector apart. All at the same time. The wire also is connected to the ice maker itself, so you also need to disconnect that connector, much easier to disconnect that, squeeze the clips on each side and pull apart.
Now you should be able to remove the entire ice tray and spiral gear assembly. Be careful as the light bulb is on the bottom back side and it is probably pretty hot as it has been on now for several minutes while you were trying to get all of this done. Now you need to take the back plastic cover off, by removing the two silver screws from the bottom rail. By removing the plastic cover you can gain access to the spiral gear motor and most importantly the cubed/crushed actuator motor. If it is anything like mine, it will be covered in ice crystals, let that melt or use a hair dryer to speed it up.
Once that is unfrozen, you should be able to move the metal rod (shaft) back and forth. There is a spring on the opposite end of the shaft from the motor and that will push or pull up the lever that in turn moves the rod to allow for cubes instead of crushed ice.
Once you have that shaft moving freely, reassemble the unit by replacing the rear cover with the two metal screws and place the assembly back in the freezer. Plug the harness back into the connector, it only fits on the female end one way, but you can look at the orientation of the round holes and square holes and get it lined up correctly. It goes together much easier than it came apart. The light bulb will turn back on once you have it connected correctly, don't forget to also connect pigtail connector to the ice maker itself. Now if you hold the door open/closed switch in and push the ice dispenser lever on front of door, you should see the motor push down the actuator that in turn will push down the end of the brass rod which then opens the latch at the dispenser end to allow cubed ice with out going through the crusher.
Make sure you have the cubed button on front activated before you test this. You will not see any difference by just pushing the cubed or crushed buttons on the front of freezer. You will only see a difference in that actuator once the ice dispenser lever is pushed. As long as that is working, make sure to replace the two metal bolts on the bottom of the mounting bracket. Replace the ice tray and enjoy your cubed ice. Hope this helps
Sep 09, 2010 | Frigidaire FSC23F7D Side by Side...
I can't figure out how to open it to fix the basin it fell off the frame and I am trying to put it back on. I have had this problem before and fixed but cannot remember how to get it open
There are two spring clips, one each in line with the left and right edge of the lid, where the top meets the front of the cabinet. Insert a putty knife at these points and push in to release the clips. Lift the panel from the bottom clips.
May 02, 2010 | GE WBSE3120B Top Load Washer
Bose 'Double' Cube Speaker Came Apart
Carefully unsnap the speaker cover you may want to use a jewelers screwdriver or a small flat tip to assist with getting it off. Once its off unscrew the 4 screws completely and then carefully wiggle the speaker from he cube. Once the speaker is out of the way reach in the cube and reset the plastic coupling so its flush with the inside top of the cube. With both cubes on there sides and the rubber washer and swivel ring in place press the bottom cube, with your finger(s) inside the cube on the plastic couping, up into th top cube until you here or feel it snap into place. Once it snaps into place, adjust the insulation in the speaker then wiggle the speaker back into the cube and carefully put the screws back in. Once this is accomplished snap the speaker coverback on and that's it. It takes ten minutes once you get the speaker cover off.
Jun 08, 2009 | Bose Lifestyle 12 System
Mar 16, 2009 | Bose Acoustimass 3 IV System
Bottom won't come back out after pushing in for connection .
sometimes when you push the cable in i have seen folks get the cable into to far and then the conduit part is inside the connector also and the button will not come back down, make sure you only have the striped part inside the hole. if that does not work you might have to take a jewelers flat screwdriver and pry it down a little, either one should work. if not then either take speaker back to factory if under warranty or remove speaker and change the button. try the first one then the next one them the two common ones. good luck and let me know.
Mar 03, 2009 | Sony Audio Players & Recorders
Detached cube speaker
Mar 26, 2006 | Bose Acoustimass 15 System
Bose Acoustimass 5 Series III Speaker System Logo
156 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
