Question about LG Heating & Cooling
I have a Lg Multi v heat pump. we had a freon leak, evacuated system and recharged but now can't get any heat or cool out of it. It runs continuously and shows no codes. pipe is really hot ne
I have a Lg Multi v heat pump. we had a freon leak, evacuated system and recharged but now can't get any heat or cool out of it. It runs continuously and shows no codes. pipe is really hot next to inside coil up to EEV. 12 indoor units are connected to the outdoor unit and all are doing the same thing. This unit was functioning before the leak but would sometimes show code 32. any suggestions what to try next? The Hvac company may have put sealant in the unit
    Scholar:
  • 40 Answers
I'm a retired and certified HVAC&R Technician. You only indicate that you "evacuated the system and recharged it." If that is all you did, then you have problems. Where was the Freon leak? What was done to repair the Freon leak? When you evacuated the system, did you then pull it down to 28 inches of vacuum? If so, did you ensure it held 28 inches of vacuum for a minimum of 30 minutes? Then, did you charge the system with 250 psi of Nitrogen and ensure it held for 30 minutes? If so, did you then release the Nitrogen and pull another 28 inches of vacuum prior to filling the system with Freon? These are the steps I used EACH AND EVERY TIME I EVACUATED A SYSTEM; and I only had a problem ONCE where the copper tubing got extremely HOT and the system would not HEAT or COOL. Found out the reversing valve was stuck half way. Had to replace the reversing valve. Good luck.
Posted on Nov 22, 2014
  • 124 Answers
SOURCE: MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Posted on Nov 10, 2008
  • 14 Answers
SOURCE: System will not start up.
This is a signal fault between the indoor and outdoor first make sure the dip switches are set start with the unit closest to the condensor set as unit 1 then next unit as 2 and so on the dip switches are inside the indoor unit on the pc board if you check the manual it will tell you which swithes to set, if this wasnt done when the units where installed they would have never worked i would also check the signal wiring between the wallmount and the splitter box / bc box and make sure there isnt a loose connection when you have ruled this out id say more than likely it is a faulty indoor board on the wallmounted unt
Posted on Apr 08, 2009
greenspan
  • 1734 Answers
SOURCE: LG split (3 indoor) LMU360CE
The LED #2 is only flashing while in disconnection or short in Thermistor (3 sec off / 0.5 sec on). If you want to change it, note: this is not an easy job to do! You will need to remove the top panel, then remove the control paneland then the front panel to gain access to the thermistor. The part isnot available to the public and requires an authorized service techfrom LG to take care of this problem. You will need a special tool toremove the front door seal spring clamp.
But you can call customer service @ 800 243 000 and see if theycan transfer you over to parts. Just give them the model and serial #and see if they would be willing to sell you the thermistor part. Youwill also need the door seal spring clamp removal tool to make the jobeasier.
Posted on Aug 02, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
  • 12 Answers
SOURCE: eo error code
You need a professional here. Once this has been repaired, I would suggest running the wiring to the outdoor unit inside some sort of piping to protect it.
Posted on Jul 21, 2010
2000 ford explorer air cinditioning blowing low cool air added freon clutch working properly condenser is not iceing, but sweating still no changein cooling. not cold air, but low cool air, why is this...
If you attempted to add to the system, you most likely
added some air into it also
Unless you have a vacuum pump & can leak test,
evacuate the system & recharge yourself,you will
have to pay someone to fix things
Jul 04, 2012 | 2000 Ford Explorer
Were able to fill the a/c with freon but it would run out in a day or two. Tried putting stop seal in it, but the freon cylinder wouldn't puncture, so we could not put freon in right away like it...
The system at this point is shot. The dryer is contaminated with oil and will not function correctly even if the leak were sealed. The system will have to be evacuated , flushed and leak tested, repaired and recharged.
Oct 04, 2017 | 1998 Ford Mustang
If i am changing out a ac compressor at home. after i am done replacing it what is the best thing to do to recharge the system. i dont have a ac recovery machine an dont have the money to bring it to a...
Well, If you want to do the job correctly, you need to properly recover the freon and then evacuate the system before recharging. Failure to do so is ILLEGAL for the recovery part. EPA laws forbid knowingly releasing freon into the atmosphere. There are some hefty fines to pay if the authorities were to find out. Not to mention that I really don't appreciate people who knowingly and willingly pollute the air that I breath. - take that as you will.
For the evacuation part, failure to properly evacuate your system before recharging will leave moisture in the system that can destroy your new compressor. If that happens, you won't be saving any money!The air that is left in the system will take up room in the system that is needed for a proper freon charge and can adversely affect how well your system cools when you are finished.
Here is a possible alternative. Take it to a shop just for recovery and evacuation. The labor charges will not be that much. In fact, some shops will do the recovery for free if you tell them they can just keep any freon that is recovered. You need to do a recovery to remove the freon from the system anyway so nothing blows up in your face when you disconnect system components. Then you can return to the shop after replacing the compressor and drier fo an evacuation. This is a good idea also because the system can be checked for leaks by evacuating and seing if the system holds vacuum. That way you won't be wasting any freon dumping it into a leaking system.
Then you can recharge the system yourself using one of the kits available at your local parts store.
Aug 18, 2011 | 2000 Saturn SL
My air conditioner works but does not cool . i have added freon the last two years and fixed the problem ,did the same thing this year but did not help .
When self adding freon after it leaks out you get air trapped in the system. After adding freon a couple of times the air expands not leaving room for the needed freon. To continue adding freon with air tapped will knock the compressor out pretty quickly, there's not enough room for both & the air is keeping the freon from being able to cool properly give the false indication of being low on freon. The freon you are adding has the dye added to assist in finding the leak since freon does not evaporate nor dissipate it its being leaked out. A black light will assist locating the leak. The best thing is to have the unit checked & serviced by a mechanic...he'll charge about $ 150.00 to check for leaks, remove the old freon...his machine will tell him how much air its trapped in the system by how little freon is removed. For the service fee he will replace valves & gaskets, where needed, correcting most leaks. After sucking the system down & recharging the problem should be corrected.
Jul 19, 2011 | 2001 Dodge Ram 2500 Truck
My air conditioner needs freon how many do i need to put in it
Freon does not evaporate nor dissipate. If you're low on freon there's a leak. If it is low by 50% or more you will end up with air pockets in the system & air will keep the system from cooling correctly & dramatically shorten the life of the compressor. A local mechanic will check the system for leaks, remove the existing freon, examine the fittings, expansion valves & seals, replacing worn ones, **** the system down & recharge it...the going price for this service is $ 150.00 compared to $ 1000.00 up to replace the unit, if you make a mistake trying it yourself.
Jul 16, 2011 | Mitsubishi Montero Cars & Trucks
The in gine works but it is not cooling no freon mayby? what can i do
Freon is no longer approved by the EPA. R134a refrigerant is now used in it's place. Because it does require specialized equipment to evacuate and capture any remaining Freon in the system, as well as recharge the high & low sides of the compressor. It's best left to the pros.
Jul 13, 2011 | Windchaser PAC8 Air Conditioner
The ac blows but it dosent blow kool fan works and its full of freon what should i do and if it blows kool it only blows kool at night
You have the system leak tested
Then have it evacuated & leaks repaired
& recharged
It only cools at night because it is low on refrigerant
& during the day it is so hot in the condensor
that it boils off refrigerant before the expansion valve
& doesn't cool the evaporator
No -- you can not add & polute the atmoshpere
I would think there may be air in there also
Can not work on it yourself
Jun 30, 2011 | 1995 Mercury Grand Marquis
AC air is only cool, how do you recharge the compressor?
You can buy a can or,refil kit of R-134-A at walmart however only put the freon in on the low side (read the directions) if the freon gas will not go in; run an 18 gauge wire from the battery to the compressor clutch switch to run the compressor if the freon gas still won't go in it must be evacuated and, recharged by a shop. only put in enough freon to get the system cold any more than that and, you will lose cooling again (over charge)
Jun 11, 2009 | 1997 Cadillac DeVille
Dometic duo therm does not cool or heat...
it should never have to be recharged unless there is a leak. so you should isolate the leak with dye injectable into the system w/ the freon and correct it, then fully recharge system.
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
I'm having trouble recharging the airconditioning on my 2004 savana van.I've put freon in with switch jumped out so compressor runs,still is'nt getting real cold.
the problem is that you have air in the system, reon leaked out so there is a leak somewhere,you need to evacuate the system using a sreial vacuum pump, suggest you find a certified A/C technician to check and recharege the system
May 13, 2009 | 2004 GMC Savana
Heating & Cooling Logo
89 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
