Question about HP Officejet 4315v All-In-One InkJet Printer
How can I reset my printer
I trying to reset my printer
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
Resetting an OfficeJet X-series Printer
Since this printer has no physical buttons, but a touch screen display there is a special way to get into service mode
Right after applying the latest firmware upgrade on a brand new HP X476 printer, All of the admin functions displayed a padlock icon, they were locked and requested an admin password. Since I had just gotten the printer, got it networked, and all the preferences set, I had not created an admin password. The update assumes you had set it and locks all of the admin functions. So I had no password set, therefore there was no password after the update. So I could not do a reset as it is protected.
After over and hour with HP Support (his name was "Bob" with a very heavy Indian accent) I got them to "give up" the way to get into the service mode to do a hardware factory reset.
Warning: There are functions in this mode that are meant for service technicians and can cause major damage. We all like to "tinker" but I strongly suggest you stick to the reset functions only.
Start from the home menu on the printer's screen. Press the "return" icon. It is not illuminated at this point. You can display it by pressing one of the main icons (copy, scan, fax, apps) and mark where it is. Press it 4 times. The servfce menu appears. press down until you get the reset menu. Select the partial reset. That should reset the printer to factory defaults.
Posted on Jan 16, 2015
    Sergeant:
  • HP Expert
  • 224 Answers
After you have cleared the jam, make sure you
press the control panel back into place. You may also need to remove any jammed
paper from the rear access door or from inside the device.
Posted on Nov 24, 2014
Oce cs2224 error code?
Try to reset your printer by pressing the "RESET" button... then try to reinstall the printer's driver in your PC or Laptop.
#NZ
Jul 28, 2014 | Cannon Office Equipment & Supplies
Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
Hi
Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
Daniel
May 28, 2011 | Office Equipment & Supplies
Cannot get black ink to print new ink cartraridge. Aliened and cleaned
try powercycling the printer or resetting it. If you unplug the printer it should reset by itself. If this does not work go into the menu and reset the printer. If none of these work, try reinstalling the printer
Mar 05, 2011 | HP Photosmart C8180 InkJet Printer
My laserjet 1020 has a paper jam output message, i followed the instruction that appeared on the screen, but still, the message appear when i tried to print, there is also a red blinking light
Try to press the reset button on your printer if did not works just try to download the reseter of your printer in HP Laserjet 1020 at the HP website. Because your printer have a lifespan printing; example if your printer have a 100,000 copies to be print so you have aloud to print not more than 100,000 copies. That's why need to reset your printer using the reseter program by HP.
May 26, 2010 | HP LaserJet 1020 Printer
Repeated message that printer cartridges are not aligned - seems to be the black mostly
clean the contacts of your cartridge and as well as the contacts inside of the printer for the cartridge.then try to print again. if it does not work try resetting the printer. to reset the printer unplug the power cord at the back of the printer and before you plug it in press and hold # and 6 at the same time which is the semi-full nvram reset keys.once you plug the power cord back in wait for the printer to say semi-full nvram reset or reset.make sure that you did not turn off the printer before you unplug it.
Oct 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
When trying to print it says
HP LaserJets - Cold Reset Instructions Cold resetting a printer resets the printer to factory defaults.Please note: Any settings you make at the printers control panel will be reset to factory defaults, including the IP address if you have a JetDirect card installed. Remove the JetDirect card while you cold reset the printer if you don't want to erase the JetDirect card's settings.
You can also reset the NVRAM. Resetting the NVRAM will clear the page count and reset the service mode settings to factory defaults. On printers with a display panel you need to enter service mode to manually change the information stored in NVRAM. On printers that don't have a display panel, such as a 5P, 6P, 2100, 2200 there is a different procedure outlined below.
"Older" printers with a display panel. (e.g. 4000, 4100, 5si, 8000, etc.)
Cold resetting the printer is simply a matter of turning the power off, holding down the GO or Online button while turning the printer on.
Resetting NVRAM settings must be done manually through service mode. See entering service mode.
"Newer" printers with a display panel. (e.g. 2300, 2400, 4200, 4250/4350, 4300, etc.)
Turn the printer off and then on. When the printer begins its memory count, press and hold down the Checkmark button until all the main LED signal lights illuminate and stay illuminated. Then release the Checkmark button, and use the Up/Down arrow keys to find the Cold Reset option, then press the Checkmark button again to choose that option.
Printers with no display panel.
HP 1100, 1200 - While the printer is on, press and hold the Go button for 5 seconds. This will reset the printer.
To reset the NVRAM. Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer.
HP 2100 - To perform a cold reset, turn the printer power off, then press and hold the JOB CANCEL button. Turn the printer power back on and after all the LEDs come on release the JOB CANCEL button. A cold reset changes most system parameters in NVRAM to the factory defaults. The JOB CANCEL button must be released within 20 seconds after all of the LEDs come on; otherwise, an NVRAM initialization is performed instead of a cold reset.
HP 2200 -
Cold reset:
1. Turn the printer power off.
2. Press and hold GO.
3. Turn the printer power back on and continue to hold GO until the Attention light turns on.
4. Release GO.
5. The device lights will begin cycling from front to rear. The cold-reset process will run until completion and the device will go to the ready state.
NVRAM Reset:
3. Turn the printer power back on and continue to hold GO until the Attention, Ready, and Go lights turn on.
4. Release GO.
5. The device lights will begin cycling from font to rear. The NVRAM initialization will run until completion and the device will go to the ready state.
HP 5P & 6P
Cold reset:
Turn the power off and hold the reset button (button closest to the back of the printer) for LESS than 20 seconds while turning the printer on.
Reset the NVRAM:
Turn the power off and hold the reset button for MORE than 20 seconds while turning the printer on..
Aug 30, 2009 | HP LaserJet 3015 All-In-One Printer
HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
Dec 15, 2008 | HP LaserJet 4000 Printer
Help Urgent
Hi Natasha,
If the button settings didn't help, then try resetting the printer.I have mentioned all 3 kinds of resetting, try and let me know.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the Ink Cartridges, then unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds then release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks n Regards
Rizwan
rizwan84tx@gmail.com
Dec 07, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Printer head porblem?
Hi , if you have printer reseter try to reset , if donot have try to visit canon web site to download reseter .
Feb 10, 2008 | Canon BubbleJet i560 InkJet Printer
Error 0xd05d010d on hp 5610
UNPLUG PRINTER FROM WALL SOCKET PRESS # AND 9 AS YOU PLUG PRINTER BACK IN TO DO A FULL RESET
Jan 18, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 4315v All-In-One InkJet Printer Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
