Question about Vanguard GH-300T Pistol Grip Ball Head with Shutter Release Trigger
My shutter release is not working.
All attempts to make it active have failed. I have another shutter release which activates without a problem.
What does the code p1d73 mean on a 2013 dodge dart sxt
P1D73-AGS PERFORMANCE
These are the possible causes.
1. ACTIVE GRILL SHUTTER ACTUATOR FUSED B+ CIRCUIT OPEN/HIGH RESISTANCE
2. ACTIVE GRILL SHUTTER ACTUATOR GROUND CIRCUIT OPEN/HIGH RESISTANCE
3. ACTIVE GRILL SHUTTER OBSTRUCTED/BINDING
4. ACTIVE GRILL SHUTTER ACTUATOR
Feb 18, 2015 | Dodge Cars & Trucks
Shutter does not operate.
hiwhen you say shutter does not operate, it mean too general to answer. could you provide more detail?I will give how does shutter work. First, you press shutter button, it will activate two switchs (one is focus and meter and the other is release ) Second, mirror goes up and opening shutter curtain move up. Third, closing shutter curtain down and mirror down and picture come out. Of course there is also aperture control unit sequence.
Jun 04, 2011 | Nikon D40x Digital Camera
My chainsaw brake broke. I have a new one, but I am unsure if I have installed the brake activator handle on correctly: I cannot release or open up the brake even though I have hit the handle fairly hard...
Remove it from the machine and secure it in a vice. Attempt to activate/ deactivate it and look to see what is causing it not to release. a bit difficult to advise without being able to see what's been done.
Jun 06, 2010 | Husqvarna Chain Saw 20" Bar
The self timer lever is stuck in the activated position of my Yashica-D. Is there an easy solution?
If the shutter release does not activate your timer and release the shutter, it probly needs taken apart by a repair guy. They can free the timer, clean out the old dried up lubricant, put in fresh lubricant, adjust everything and return it to you...working.
lightspiritphotography.com
Oct 27, 2009 | Photography
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Mar 31, 2008 | Nikon D100 Digital Camera
Ricoh KR-5 SUPER II Shutter will not activate.
I doubt you still need help with this considering it's over 8 months later... but the same thing has been happening to me lately, I've had to force the self timer to start by giving it a little push, once it gets going it starts to work normally again.
Jan 19, 2008 | Ricoh KR-5 SUPER II 35mm SLR Camera
My X700's shutter isn't working when i press the shutter release
Check for dead batteries first - if not that, the magnet capacitors need to be replaced, or the release magnet cleaned.
Sep 04, 2006 | Minolta X-700 35mm SLR Camera
Vanguard GH-300T Pistol Grip Ball Head with Shutter Release Trigger Logo
55 people viewed this question
Top Vanguard Photography Experts
Steve
mike t.
Tony Parsons
Tony Parsons
Are you a Vanguard Photography Expert? Answer questions, earn points and help others
