Question about Dewalt DCD970KL XRP HeavyDuty XRP 12" 18Volt Cordless PistolGrip Hammerdrill Drill Driver with NanoPhosphate Lithium Ion Battery
<!-- from fixya rte -->Should my drill light up inside on ignition - Dewalt DCD970KL XRP HeavyDuty XRP 12" 18Volt Cordless PistolGrip Hammerdrill Drill Driver with NanoPhosphate Lithium Ion Battery
What does that mean--inside on ignition ?
Only you know, if it came with or has a light
when you pull the trigger
Posted on Nov 21, 2014
Fix light chek air suspenssion
Have you disconnected the battery to reset the computer? That would be my first step. If that doesn't work, go to an auto supply (Auto Zone) and have them check for codes. Ask them to clear the codes.
Mar 09, 2016 | 1992 Lincoln Town Car
How do you drill out the ignition cylinder on a 1996 GMC sierra 2500 no key
You are better off taking it out from the inside of the steering column after removing the steering wheel. When the cylinder is rotated it moves a shaft that travels down the inside of the steering column that activates the ignition. There are on wires attached to the cylinder that will give you ignition. If you must drill it out you will need at least a 1/2 ins to 3/4 ins drill and that will butcher it.
Apr 11, 2015 | GMC Cars & Trucks
How do you switch out the tumbler in a key switch on a 87 Jeep Wrangler?
unfortunately without the key you cannot replace the tumbler without drilling. this damages the whole assemblywhich means that you do you have to replace the ignition key cylinder the procedure is to drill into the ignition key hole about an inch and a half with a 5/8 drill bit . make sure you drillr straight hole in the path of the key.after you drill the holethe whole cylinder will rotate and come outallowing you to replace it not sure if you can buy tumblers by themselves comes with the whole ignition cylinder with the tumblers inside of it
Jul 13, 2014 | Vehicle Parts & Accessories
How to get my ignition lock out
Instructions
Test fit a drill bit in the lock cylinder. You want a bit that is just smaller than the cylinder. You will be using hardened drill bits to cut through the cylinder, since ordinary bits may be damaged by drilling metal.
Lock the drill bit into the drill chuck and tighten the chuck.
production in very fast delivery! special threading taps, plug gauge
Drill a starter groove into the lock cylinder. Start the drill on a low speed and create a groove in the end of the lock cylinder. You don't need to create a deep hole, just enough of a groove so that the drill bit will not slip on a higher speed.
Increase the drill speed to the highest setting and drill out the lock cylinder. Let the drill do the work. If you force the drill into the lock cylinder, you could burn out the rotor inside the drill motor
Jul 10, 2012 | 1999 Pontiac Sunfire
1994 toyota camry key broke off in ignition and now need to replace it.
You must somehow get the ignition to the "on" position. Remove the cover around the steering column and there should be a hole below the ignition switch/key cylinder. Insert a drill bit (a size that can go into the hole), tap it with a hammer until the key cylinder can slide out. Remember in order to do this, the key must be set to "on". If you are unable to to get it to the "on" position. You must drill the lock pin inside that hole until the key cylinder can be removed.
Jul 26, 2011 | Toyota Camry Cars & Trucks
I need to remove the ignition cylinder but, i cannot get the key to turn to the "acc" position, so i cannot perform the straight forward method
in order for you to get the ignition out you are going to have to drill a small hole in the housing and press in the retaining pin manually. it will be hard for me to describe the exact drill point to you with words, but if you have the new ignition switch in your hand you will see where the pin is and you can estimate where on the housing to drill the hole. as soon as the hole is drilled - take a small metal punch and you will need to smack the pin up into the old switch,, this will allow you to remove the old ignition. now when you are putting the new ignition in, before you do you will need to use a flat blade screw driver and turn the inside gear to the accessory position so when you slide the ignition into place everything lines up right.
c...
Jan 02, 2011 | 1994 Toyota Camry
How do you replace the ignition cylinder on a 1997 toyota 4 runner
Here's what you need:
1) Drill
2) 5/32′ cobalt drill bit (use cobalt, it's for drilling hard metals and is necessary)
3) 10mm socket wrench
Here's what you do:
1) Remove panel underneath steering column (4 X 10mm bolts)
2) Remove plastic shield covering ignition (should just snap out)
3) On the underside of the ignition assembly, you'll see a small hole (~1/4′) about 2 inches back from where the key goes. Using the 5/32′ drill bit, drill up into the hole, trying to center the drill bit on the pin which is inside the hole. You can normally push this retaining pin in if the ignition is turned to the first position and slide the cylinder out.
4) When the pin is drilled out completely, the lock cylinder should be easy to pop out with a small flat head screwdriver pried just underneath where the key goes on the front of the ignition.
5) The new cylinder should slide right in (with the key inserted and turned to the first position - ACC)
Heres what it cost:
1) Ignition lock cylinder assembly from Toyota dealer ~ $115
2) 5/32′ cobalt drill bit ~$4
Oct 29, 2010 | Toyota 4Runner Cars & Trucks
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
93 Ford Ranger Ignition Cylinder
Hi..
On 1993 Ford ranger to remove the ignition lock cylinder switch
You need to remove the Steering wheel.
Remove trim shrounds.
Set ignition switch to Run position.
If your vehicle is A/T trans. put the selector lever in Park.
You will see retaining pin. Push retaining pin inward and pull out the lock cylinder.
Unplug wire from lock cylinder.
To install reverse remove procedure.
NOTE'' If you don't have the key or the cylinder is locked.
Instead of push the retaining pin you will need to Drill with a
1/8 in ( 3.17mm) Bit to drill out the retaining pin.
Be careful DO NOT drill more than 1/2 in deep.
After you need a chisel to break away the cylinder cap.
You need a 3/8in (9.52mm) bit to Drill in center of the cylinder.
Drill aprox. 1 3/4 in( 44mm) Deep.
REmove metal shavings. And remove the cylinder.
Clean and lubricate the gear inside. and install the new cylinder.
OK............I hope this information work for you.
Thank's for use fixya.
Jul 13, 2008 | 1993 Ford Ranger SuperCab
Dewalt DCD970KL XRP HeavyDuty XRP 12" 18Volt Cordless PistolGrip Hammerdrill  Drill  Driver with NanoPhosphate Lithium Ion Battery Logo
67 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
