Question about Toshiba REGZA 32RV530U LCD TV
Toshiba regza 32rv530u powers on runs fine for a while then powers off?
    Top Expert:
  • Toshiba Master
  • 74,211 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 22, 2014
2 Suggested Answers
KingDWS
  • 1606 Answers
SOURCE: Regza 32RV530U HD TV, dead,
Generally when you see no life at all the problem will be in the main power section or the power source.
The cheap things to try are just to try another outlet as well as reconnecting the power cord. Sometimes those will be just loose enough. If you are very lucky this is all it is.
Normally when the tv is dead the problem is in the main power section or an internal fuse has popped. The power section requires replacement as there are no easy to fix parts on it. The fuses can be replaced but that may just pop again as the cause may still exist. As an example the power supply could have a problem that popped the fuse so if you replace the fuse it will work just long enough to go out again.
What you need to do is check to see if you have any warranty. This might be Toshiba or perhaps a extended store warranty. If you have warranty then you just need to talk to the store or Toshiba or drop it off to a repair depot or authorized service centre. To find out if you have warrenty you need to dig out your sales receipt and call the store. They will tell you if you are covered and by who. If you are not covered then this becomes a bit trickier. This is not a cheap repair so you need to get a estimate only. You also want to know what the price is of a replacement tv. The repair for a main power board can be over $500 (and more) depending on the model. So there isn't any sense to repair it if it's a hundred or so cheaper to just get a new one. Wish I had a better fix than this for you but there really isn't one.
Posted on Nov 09, 2010
Where is the inverter board in the back of the Toshiba 32RV530U
For some models of Toshiba set; uses a Samsung display panel; the the inverter board will be inside the pane [built in type]. There is no repair to this type of display panel; other than replacement. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 21, 2015 | Toshiba REGZA 32RV530U LCD TV
Toshiba 32RV530U picture comes on for a while disappears for a few seconds and comes back then disappears again and does not come back, but there is sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 20, 2015 | Toshiba 32" regza 32rv530u 1080p...
My toshiba tv 32rv530u wont turn on
Replace the damaged capacitor and check first. If it do not help you, replace the power supply regulator board as card. It will be best, rather than trying to make the present one get repaired.
Jan 09, 2013 | Toshiba 32" regza 32rv530u 1080p...
My girlfriend has a toshiba 32rv530u TV. when she first connected it to her time warner cable everything worked fine. since then time warner has added free hd channels for the local commercial stations...
After u deleted all the HD channels u don't want.Tries unplug,replug the cable box back like about an hour.For the box to upgrade it softwares,should be deleted all the HD channels u deleted.
Feb 06, 2011 | Toshiba REGZA 32RV530U LCD TV
What is regza on toshiba tvs and how do i activate it
Check this link to find more info on how regza works. The user's guide should have more on page # 51.
Jun 28, 2010 | Toshiba REGZA 32RV530U LCD TV
Tv runs for a while and then the picture goes black
Either the sleep timer is set, or the power supply unit is faulty.
Sep 13, 2009 | Toshiba REGZA 32RV530U LCD TV
Goes on and off on and off permantly
your backlight is going out.. get it replaced
Feb 01, 2009 | Toshiba REGZA 32RV530U LCD TV
Toshiba REGZA 32RV530U LCD TV Logo
52 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
