Fisher and paykel mw511 need to no where to plug the wires to mother board
JULIANFIX
  • 975 Answers
SOURCE: fisher & paykel (mw511)
check out the DRAIN MOTOR PUMP , its a small motor with 2 hoses connected to it , it could be clogged , need to remove it , inspect inside the impellers for any debri , clean it , re install and try again , hope this helpful AJ
Posted on May 20, 2008
  • 14 Answers
SOURCE: fisher and paykel mw511
temp sensor is bad or dirty with hard water deposits
Posted on Feb 22, 2009
HansPP
  • 2510 Answers
SOURCE: fisher and paykel mw511 washes
If it smells during the spin cycle the belt could be slipping and burning in the pulley. You may need to replace the belt.
Posted on Feb 08, 2011
  • 6277 Answers
SOURCE: Fisher and Paykel Pride MW511 does not spin. Three
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Feb 19, 2011
  • 251 Answers
SOURCE: Hi. I need some info on the fisher and paykel
Hi - I will need the product number found on the sticker in the rear of the machine - the controls has been changed so it needs to be programmed to a 5Kg machine.
I cant help you without that information as there are about 6 methods of doing this, the product number will tell me which is the correct way.
Posted on Jun 27, 2011
Fisher and paykel washing machine, mw511.fault error of 3,4 and 8. How do I fix it?
If you are counting from left to right that is error 49 which means the control board is getting a bad reading from the cold water valve. That can be caused by a bad inlet valve or a bad connection on the wiring to the inlet valve or the control board itself is faulty. Unfortunately most times it is usually the control board needing to be replaced. Best get a technician out to test it.
Jul 31, 2016 | Fisher and Paykel Washing Machines
Why won't my Fisher & Paykel washing machine complete its cycle?
it appears to be a control module problem
have it checked by an authorised F&P technician
Jun 06, 2015 | Fisher and Paykel Washing Machines
Can some one tell me where the earth wires go and the rest of the plugs on a fisher and paykel washing machine mw511
If you are not sure of the wiring contact an electrician!
Connect each wire to the correct terminal. Slacken the screw and push the bare wire into the hole. Re-tighten the screw. Make sure the terminals are tight and that there is no bare wires or loose strands of wire showing. It is often easier to push the pins up slightly when connecting the wires.
  • Brown - Live
  • Blue - Neutral
  • Yellow and green - Earth
Older appliances may have different colours:
  • Red - Live
  • Black - Neutral
  • Green - Earth
Nov 23, 2014 | Fisher and Paykel Washing Machines
Fisher and paykel mw511 pride wont turn on
Your pump could have blown the in the 4 amp in the board
Check your pump should be 34 Ohms
or higher, but not less then 28 Ohms if so replace pump and the fuse
The 4A fuse is near the AC plug on the board.
Apr 18, 2013 | Fisher and Paykel Washing Machines
Fisher & Paykel MW511 error code lights 1 and 7 lighting up and beeping
Error code 130 is rotor position sensor faulty or wiring to it.
sensors sell for $25 to $50 on Ebay.
Jan 28, 2013 | Fisher and Paykel GWL11 Top Load Washer
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
Need to replace the memory board on: f&p mw511 pride 5.5 washer, where can i purchase this from and how much
Hi just read your posting.What country are you in?Is your control module faulty?Have you checked why the control module became faulty?Please reply for further assistance.Looking forward to your reply.
Sep 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
