Question about SCOSCHE Fd1444b 10-up Ford Transit Radio Install Kit
Hi my 10plate transit tippers radio turns on but I get no sound at all can anyone help thanks mick
Checked all wiring ok,checked if speakers are connected ok too.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 112 Answers
Check the speakers by checking if they have impedance with a multimeter or connect another head unit to prove they are working if they are working you'll need to get the head unit checked by an engineer .
Posted on Nov 30, 2014
2007 lexus is250 radio turns on pop in speaker and then no sound
have blown speaker some one turn it up to high and blew it replace it and what the volumne
Apr 19, 2016 | Lexus IS 250 Cars & Trucks
I have a 2001 GMC Yukon XL and several months ago, I started having a problem with the OEM radio. The radio evolved to the point where it was in constant state of resetting itself on and off. The clock...
Initially, pls verify the splicing/wiring:
If verified and still no sound, either:
  • setting configuration (menu); or
  • internal fault of the Pioneer unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 26, 2008 | GMC Yukon XL Cars & Trucks
My dips and full beam are not working on my 04 transit tipper van, I've checked the fuses and it's not that can anyone help please
check for power at the bulb/s holders , if ok then check for power from switch , if ok then must be a relay , usually in the engine compartment fuse box , cover lists location etc
Nov 26, 2014 | Cars & Trucks
Hi there I have alpine cda 9856 cd player and it turns on and does every normal however it won't output and sound on either radio or cd. I have checked for any bad connections and can't seem t
Did you make sure you have no shorted or grounded speakers or speaker wires? Make sure you don't have a bad speaker also. If everything checks out, you may have a bad internal output ic.
Jan 15, 2013 | Alpine CDA-9856 CD Player
MY REAR SPEAKERS ON FOCUS 2007 HVE STOPPED WORKING DOES ANYONE KNOW WHAT FUSE COVERS THEM SO I CAN CHECK IF BLOWN ?
There is no fuse to the speakers your rear speaker wires should run under the kick plateon drivers side broken or disconnected wire or burned out channel in radio.
Oct 21, 2012 | Cars & Trucks
Radio no audio 1990 bmw 535i
What happens if you turn the VOLUME to MAXIMUM?
If still no sound , then suspect problem with the speaker , connections or wiring
If loud hissing etc. then speakers appear OK so suspect a radio fault
Jun 15, 2010 | 1990 BMW 5 Series
Installing a new radio
first of all u need a test light hook one end to ground check for positive power with the other end of the test light. One of the wires comming from the vehicle will show power with ignition on and light switch on this is dimmer wire for speaker location get a nine volt battery put two wires to it {not your power or ground wires} you should hear a buzzing noise this would tell you speaker location .
Feb 14, 2009 | 1995-1997 Chevy Suburban Ignition Starter...
99 cherokee radio problem
Either the radio's output ICs are fried or speaker/wires needs to be checked.
Incidentally, there are some higher end versions that has an Infinity Amplifier (P/N: 56038407AD) powering the speakers and not the radio (alone). If so, this amp needs a trigger on from the head unit to work and therefore, the trigger wire/connection must be checked. Otherwise, it may likewise require an internal check.
Jul 12, 2008 | 1999 Jeep Cherokee
Wiring for echo chamber to uniden 300
Mick, check out this site, they talk about some of the same equip. as your asking about. It's a very good site.
http://www.radiomods.co.nz/forum/viewtopic.php?p=5303
hope this helps you with your search, Mechanic
Nov 18, 2007 | Radio Communications
SCOSCHE Fd1444b 10-up Ford Transit Radio Install Kit Logo
71 people viewed this question
Top SCOSCHE Car Audio & Video Experts
ray gallant
Your Consultant
Jerry Kramer
Jerry Kramer
Are you a SCOSCHE Car Audio and Video Expert? Answer questions, earn points and help others
