Question about Car Audio & Video
How do I enable the speakerphone on a aclatel idol x phone
  • 88 Answers
Hi . If its anything like the Samsung Galaxy S3 you just go into the phone mode and it should show with a speaker symbol .my Galaxy S3 has it on the bottom left . I take it that its a touch screen phone you have
Posted on Nov 21, 2014
Change language to English
You can change settings on your speakerphone. To do
this, turn off your speakerphone, then press and hold the call button and move the power switch to the "e" position
until you hear "welcome to setup".
Follow the voice prompts to change settings for:
Language
Enable/disable voice prompts
Enable/disable Name/Number Caller ID feature
Size of favorite contact list (10 or 25)
Mar 10, 2014 | Motorola Mobility T325 Bluetooth Speaker...
No volume on parrot ck3100
check the settings on your phone first. turn it up on your phone and then go to settings and move up the phone setting volume.
Aug 25, 2012 | Parrot Hands-Free Car Kit with LCD Display...
When i make a call my bold doesnt even give me a speakerphone option, it gives me headset instead, what do i do?
Try clicking on the Speakerphone button ($) while on call and see if it's going to enable your speakerphone capability
Apr 26, 2011 | RIM BlackBerry Bold 9700 Smartphone
The speaker phone will not work
If you have the speakerphone option enabled in system programming, you may just have the mic turned off. Try pressing Feature then 1 while the phone is idle. The mic light should light up if it wasn't already lit.
Apr 13, 2011 | NEC DTH-8D-1 Corded Phone
How do I use the loud speaker on a Blackberry pearl?
Hi there
Although the Blackberry pearl does not come with a speakerphone, you can still set up this function by using a Bluetooth device.
HERE IS WHAT YOU SHOULD DO
Power on your Blackberry using the On/Off button in the lower right-hand corner of the device
Turn on Bluetooth
Find the Bluetooth option. In the main menu, select "device options."
Enable Bluetooth radio. Click on the trackwheel to scroll down until you see the option "Enable Bluetooth". Select this function (click the trackwheel) to turn on Bluetooth compatibility. If you have completed this step correctly, you will now see a "Bluetooth icon" on your Blackberry screen. If you want, you can later turn off Bluetooth by repeating Steps 1 to 3 and then selecting "disable Bluetooth".
Pair your Blackberry with a Bluetooth speakerphone
Power on your Bluetooth speakerphone device using its On/Off switch or button.
Find the Bluetooth option in the main menu by again selecting "device options" and then using the trackwheel to scroll down until you see Bluetooth. Select this by clicking the trackwheel.
Add your Bluetooth device. Click on the trackwheel to scroll down until you see "Add Device." Then click on the trackwheel to select this function.
Enter the name and passkey of your Bluetooth device. When prompted, scroll down with the track wheel until you see the name of your Bluetooth device. Your Blackberry automatically detect your Bluetooth speakerphone if it is within 10 meters. If it does not, enter the name of the device, then type in the passkey provided by the manufacturer of the speakerphone.
Enter the passkey on your Bluetooth speakerphone. Your Blackberry and Bluetooth speakerphone can now communicate with one another.
To use the speaker during a call all you need to do is;
Dial a number and hit the send key. Make sure that your Bluetooth speakerphone is on, and that you have already set your Blackberry to "Enable Bluetooth." If you see the "Bluetooth icon" you have already done this step.
Activate your Bluetooth device. When the call has connected, click on the trackwheel until you see the option "Bluetooth Device". Then click on the trackwheel to activate the Bluetooth function. Your Blackberry will now route your call to the Bluetooth Speakerphone.
Turn on the speakerphone. Depending on which Bluetooth Speakerphone you have purchased, you may need to click on the "speakerphone" button to enable this function. Once the speakerphone is on, you may continue with your phone call.
Sep 19, 2010 | Cell Phones
Keep getting message "incomplete data" when a call comes thru
You've probably enabled caller id CLI on your phone but don't have it enabled as a feature on your phone line.
Hope that helps
Jan 14, 2010 | RCA ViSYS 2-Line Speakerphone
Speakerphone when answering blackberry pearl 8100
After taking out the battery for a couple of minutes, fixed this on my Pearl
Jan 20, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cant get speakerphone to work on samsung sgh-c416
Here is how you activate the speaker phone:
  1. During a call, press the Options soft key to access the following: Loud Spkr ON/OFF: Allows you to enable the speakerphone option.
  2. Also, During a call, use the speakerphone key in conjunction with the left soft key to activate the speakerphone operation.
For both options use the volume keys (located on the left side
of your phone) to adjust the volume.
If neither of these methods work, then there is a problem with your phone.
Good Luck!
Aug 11, 2008 | Samsung Lands Phones
Cannot diable hands free
Reset ur phone setting then ur phone will come in default settings, after that u can u can set it according to ur choice.
Oct 15, 2007 | LG KG320 Cellular Phone
Car Audio & Video Logo
388 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
