Question about Uniden Lands Phones
My uniden IGO430 said it was out of memory and did I want to restore to factory setting. I press yes but nothing happens, just a small black square were the message was.
Pressed the reset button
  • 4 Answers
SOURCE: how do i set the time setting for panasonic kxt7456 black digital super hybrid system anyone has the manual? or set of instructions?
ok, the link isn't working properly, so I'll try to explain:
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
Fixe_You
  • 1800 Answers
SOURCE: Resetting phones and restoring to full factory default.
okay i will fix the prob but i need model name
and fix ya rate after giving the solution okay??
Posted on Aug 19, 2008
SOURCE: voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Posted on Oct 03, 2008
OldLinuxGeek
SOURCE: uniden cordless phones
Okay, this solved it for me, so maybe it'll help others.
Basically, you just need to re-register the phones by placing each one on the base unit and leaving it there for at least five seconds after the charge/in use LED light stops flashing.
According to the manual, it's necessary to re-register each phone after a power failure or if the batteries get very low or die. If you're experiencing the "connecting..." problem, this will probably fix it!
Posted on Oct 23, 2008
rockitman187
  • 2559 Answers
SOURCE: i am desperately trying to
Have you tried F8 instead?
Posted on Jan 07, 2009
How to reset a uniden bc346xt to factory settings iwould like to program my local police
Scanner Reset to initialize the scanner's memory, turn off the scanner. Then press 2, 9, and Hold while turning it on (It helps if you can lay it flat). The scanner will give you the option 'Restore Preprogram List? "Yes"=E/No="."', if you press 'E/Yes', the scanner reloads the preprogrammed systems. Important! This deletes all programmed data. Easier to Read BC346XT Scanner Manual
here is link to manual
Jul 19, 2017 | Uniden Radio Communications
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
May 21, 2014 | Xerox 3300MFP/X new 3300mfpx [a51t732]...
Ds5000 problems
PLEASE READ ALL FIRST. From any phone in the system: 1. press transfer button then 800. 2. enter password 4321. 3. press volume up button to enable. 4. press speaker button. 5. press 811. 6. press the volume up button to get CLEAR ALL MEMORY. 7. press the square button to the left of the round scroll button to move the cursor under the word NO. 8. press the volume up button to YES. 9. press the square button to the left of the round scroll button. 10. the system will now DEFAULT to the original "OUT OF BOX" condition. BE ABSOLUTELY POSITIVE THIS IS WHAT YOU WANT TO HAPPEN.
Jan 23, 2014 | Samsung Lands Phones
I forgot my keypad lock password. is ther any way i can reset it or something
hi this is the steps how to reset your phone
REMEMBER:All User Data such as contacts, messages, pictures, videos, and music will be permanently deleted. Ensure that the microSD memory card is also removed as it will be erased with the Restore Phone option. To reset the handset, to the factory default settings
  • From the standby screen, press Menu
  • Then Press Settings
  • Press Phone and Press Reset Phone
  • Press Yes to Reset the handset's settings to the factory defaults and Enter the Password then press on OK (Default is last 4 digits of the phone number
To restore the handset, to the factory default settings and delete all data
  • Press Settings and Press Phone
  • And Press Restore Phone
  • Press Yes to Reset the handset's settings to the factory defaults and Enter the Password then press on OK (Default is last 4 digits of the phone number)
  • If prompted, re-enter the Password to confirm then press on OK
thank!
Apr 17, 2011 | Samsung Solstice SGHa887
When i click on the messenging button it says "message storage memory not ready"so I cant get into my messages. What must I do
It cam be deduced from your problem that the operating memory of your phone is distorted when you click on your message,hence its unable to open the message application.
The solution goes thus;
1.switch off your phone and remove the battery(for at least 1hr)
2.Replace the battery and put on the phone again.
3.Conduct a hard reset which restores the factory settings on your phone,here is how you perform the hard reset; -Press the menu>tools>settings>general>factory settings,(a disclaimer appears),
-Click on yes to restore factory settings.
4.After reseting,the problem is solved.
Thanks for using fixya.
Dec 10, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
When I turn my netbook on it starts but goes straight to black screen and nothing happens, I went to safe mode but whenever I press Entre it reboots and goes to black screen again, I have no cd-rom ... so...
It appears that the computer is infected with virus and may need full system recovery. You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key
& keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on
the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical
support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 25, 2010 | Acer Aspire One PC Notebook
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
My phone is very slow and freezing alot. also two messages pop up one says "memory full" two says "system error"even though I have upgraded the software and formated the phone like 5 times, making sure...
memory full-it is caused because the phone uses some internal memeory for ram like bluethooth connectio,wifi so please reset your phone to factory settings
system error-this is due to the firmware plz upgrade it to the latest version by connection to the pcsuit and plz do have an antivirus in your mobile
Soft Reset
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones.
Hard reset
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
Sep 30, 2009 | Nokia N97 Cell Phone
Lands Phones Logo
23 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
