Question about Refrigerators
Westinghouse two door fride freezer. The two blue lights are whis is between the first and second shelf is never happened before. They were both on but every time you open the door its stopped but when you close it it's like the motor is on . What is the problem pls?
    New Friend:
  • 31 Answers
Frankly not sure unless something else going on. Some ice makers have a cut off light that when you open it lights up so ice won't kick out at your door while door open. Could also be a feature : https://www.masters.com.au/product/100399477/westinghouse-side-by-side-fridge-700l-wse7000sf
Motor kick on could be the compressor kicking on because the door is open and all that cold air is coming out and it is now turning on to cool again.
Posted on Nov 28, 2014
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
Please help me to locate the model number on my 2 door Westinghouse refrigerator. Bar code id from frige back appears below. Meanwhile, the part I'd like to replace (a door shelf) has the following id:...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Jun 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Light in smeg fridge freezer broken
if you replaced three bulbs and same thing happens then it is wiring or electrical.
Nov 29, 2009 | Freezers
Just stopped working: plugged in,light on,fan blows in freezer-
defrost timer probably failed in defrost mode go online search for defrost timer location and manually advancing or initiating a defrost cycle , it may pop into run mode and tell you thats what it is , 90% of the time thats it and they are cheap !
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
