Question about Golden Technologies Avenger 4 Wheel Electric Scooter
Chair wont charge lights not comeing on but still has 1/2 power according to lights
    Master:
  • 455 Answers
Depending on age of unit batteries can get bad just like in a car and won't charge. auto parts store can check batteries for you, or garage
Posted on Nov 21, 2014
Hi I have a Jazzy 614 HD. I charge my chair with (new charger) and it turns off when fully charged and my Joy stick reads fully charged (New Joystick and new batteries) but within three to four hour
perhaps since your chair is over 2.5 years old you have underlaying problems such as motorheatup or excessive drag per a locked bearing or a bushingtrhat is out of lube.somebody needs to at everything that moves thathas to do withload carry,or powertrain.
Jan 12, 2013 | Pride Mobility Jazzy 614 HD Power...
My uncle left my hoveround chair out in the rain is this the end of my chair? when i plug in the charger the light on the charger lights up green but the chair wont come on
Angel the charger light should only turn green when the chair is fully charged. If you know the chair isn't fully charged then there is a problem with the charging system. if the circuit board in the joystick got wet then that is a serious problem. If you have a voltmeter you can check the battery voltage thru the charging port located under the front of your joystick Set the meter to 200 volts dc and plug the leads into the 2 outter holes of the charger port. Fully charged you should read 27-30 volts if you aren't getting any reading then the batteries are completly dead or there is a problem with the charging circuit (the reason you are getting a green light on the charger) The joystick will have to be replaced sorry If Medicare paid for your chair then they will pay 80% of the repair costs to get your chair working again If they did contact Roadrunner Mobility @ 1-800-467-2668 to get it fixed thru Medicare Hope this helps
Apr 27, 2011 | NRS Hoveround MPV 5 - Used Power...
JAZZY 1113 AFTER CHARGING 10 HOURS SHOWS ALL LIGHTS, THEN AFTER AN HOUR OF USE IT SHOWS 1 RED BLINKING. BATTERIES ARE ABOUT 1 YEAR, IT READS 26 VOLTS AT THE PINS ON CONTROLLER. ANY SUGGESTIONS?
Mary yep Even though the batteries are charging they are not holding the charge to provide enough power for the chair. Usually you have one battery that is weak and causing the problem but both batteries must be replaced. If Medicare paid for your chair then they will pay for 80% of the new batteries. You can contact the provider that sold you your chair and ask if they can replace your batteries. If not, you can contact Repair Express @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have tech come out and repair the chair for you and they will bill Medicare for the cost of repair. Hope this helps
Feb 28, 2011 | Pride Jazzy 1113 ATS Indoor Power...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
My husband's powered wheelchair has not been used for sometime due to illness. I had charged it up without using it, but the last time the power appears to be going through the charger -green light on, but...
Nick yes I would say that the batteries are too low for the charger to pick up and charge thats why you are getting the green light. If Medicare purchased the chair then they will pay for repair you can contact the provider that sold you the chair and ask them to come out and repair the chair or you can call Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 to have it repaired Hope this helps you
Sep 10, 2010 | Electric Health & Beauty
Not sure if jet 3 is charging
Does all your lights on the joystick come on after charging? If you can have someone look behind your chair while still plugged in for charging, the green light on the charger will be lit if the batteries are fully charged. They will have to kneel and look under the shroud to locate the charger they will see the light if it is on. Also check the meter on the rear of the chair the meter should read zero when the chair is plugged in and fully charged. I fyour chrger is working then if the chair does not stay with power for what was normal then new batteries are probably needed
Aug 21, 2010 | Jet 3 Ultra Power Chair
Battery doesn't charge
When you connect the charger, if the light goes to red to green within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced. This can happen if the power chair has not been charged in a while or has been stored. Having the chair on or off while charging will not affect the charging process, but you ususally want it to be OFF.
Mar 11, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
MY CHAIR WILL NOT CHANGE SPEEDS IT IS VERY SLOW AND WILL NOT INCREASE SPEED AT ALL. LIGHTS ON POWER LIGHT INDICATOR FLASHES CONTINUOULSLY
Your batteries are bad or not charged up is it only 1 red light flashing or is it all power lights flashing 1 red means not enough charge. all means internal problem with joy stick
Mar 05, 2010 | Pride Jazzy 1103 Ultra Standard Power...
My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
May 17, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Golden Technologies Avenger 4 Wheel Electric Scooter Logo
90 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
