Question about Samsung Computers & Internet
What to do to rectify water coming from the base of the washing machine?
After loading the machine, water comes out from the base. The water connection is okay
    Problem Solver:
  • 25 Answers
The water will be from either the incoming mains water supply or the drainage system or the door seal etc.
check to see if its clean and clear, mains cold water.
or
grey soapy, waste water.
3 of the most common leaks are on the waste system.
1. the door seal.
2. the ribbed grey waste hose can leak when water is being pumped out, usually at the ribs of the hose.
3 the inspection port on the bottom front of the machine, which usually collects 5p's, 1p's, underwire from underwear etc.
Posted on Nov 21, 2014
Hi, i have an MW511. All of a sudden it keeps stopping mid cycle with 2 red lights coming on and beeping like crazy. I have re packed the machine, a few times, so its not un balanced, also reduced the...
Hi just read your posting.Now the lights that are on when the machine beeps will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 2nd and 5th or the 3rd and 7th ---etc---?Now to fix the water coming out of the hot hose as the machine is filling just fold the hot hose in half and tape it in this position.This will stop the water coming out of the hose.Please reply with additional information on the lights and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have water leaking into the washer when it is turned off. It is a steady drip that is coming from the water hose. What do I need to do to fix this?
Hi just read your posting.If the water is coming into the machine when it is not being used then one of the water valves is faulty.There are 2 ways to rectify this. The first is to turn your taps off to the machine after use and this will stop any water going into the machine until you turn the taps on again when you are about to use the machine for washing and the second way to fix this fault is to change the water valve or valves.If you turn the taps off it will save you money but if you decide to change the valve, reply back and I will guide you step by step in the replacement of the valve.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Cold water not coming in. Hot wash is fine with hot water only. Cold or warm wash pulls no cold water. Water pressure is fine, no pipe kinks. Could inlet valve be stuck? Any other possibilities?
Hi just read your posting.Now have you removed the cold water hose from the machine end and checked to see if there is water coming from the hose?Do any fault codes appear on your machine when the cold water is not coming in?Have you or can you borrow an electrical test meter to test the coils of the valves to see if they are faulty?Please reply with additional information on these questions and I am sure I can help you rectify this fault.
Aug 10, 2010 | Fisher and Paykel IWL12 Top Load Washer
Not getting enough water
Hi just read your posting.Now what water temp are you using for you wash cycle?Is it cold , warm or hot?Problem could be your cold water valve not opening enough or your motor controller.If you selected a COLD wash how fast does your cold water come in to the machine?Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
2nd 3rd and 5th lights on. washer stopped in the spin cycle and water won't drain. washer won.t come back on
Hi just read your posting.Do you still require help ?Please reply and I can help you rectify this fault.
Jul 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water pumping in very slowly and uneven flow
The washer filling so slowly can get very irritating and frustrating..most of the time the fix is very simple. The hoses have a screen in them to catch any dirt that may come in the water and this screen plugs up.
Simply unhook the hoses at the washer and clean the screens.
This tip will explain this in more detail for you..
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
May 05, 2010 | Fisher and Paykel WL37T26D Top Load Washer
Whirlpool washing machine, extra large capacity Plus. Water drips from the top back of the washing tub into the spun-dry clothes after doing a load. Dripping water source is higher and slightly to the...
it sounds is if you have a possible crack in the water supply area. if the hoses are good, tight and dry, inspect the housing base they screw into.
Aug 16, 2008 | Washing Machines
Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Oct 07, 2007 | Washing Machines
Computers & Internet Logo
62 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
