Question about Husqvarna 3300 PSI 3.2 GPM Gas Pressure Washer 020524
I have the 3300 husquavarna pressure washer model# 020524 It has an adjustable pressure knob. The knob will not turn in either direction. Called husquavarna. One guy said he never heard of a pressure
Can't turn the knob. It's brand new out of box. Used channel locks and still would not move. How hard should I turn and in what direction?
    New Friend:
    Problem Solver:
  • 17 Answers
Some knobs lock and you have to pull up before they turn
and push back down to lock..this helpps prevent the pressure changing due to vibration
Posted on Nov 22, 2014
Why does the engine crank but it will not turn over?
you question makes no sense...if it's cranking then it's "turning over" you may mean not start which would be an engine problem
Jun 07, 2015 | Husqvarna 3300 PSI 3.2 GPM Gas Pressure...
Starter cord want pull on husqvarna model 020524 pressure washer, not even with pressure of water off
hold the trigger down on the spray gun and then try, the pressure is built up in the pump - the pump can't turn against the back pressure.
Dec 27, 2014 | Husqvarna 3300 PSI 3.2 GPM Gas Pressure...
Why do i have low pressure?
Maybe sucking air in through a chemical valve (if it has one)
maybe new pump seals
a valve suck open in pump.
worn lance jet.
www.Flowjet.co.uk http://www.flowjet.co.uk/
Jul 22, 2014 | Husqvarna 3300 PSI 3.2 GPM Gas Pressure...
I just got a refurbished pressure washer and after a week of it working i went to use it today and it works there is just no pressure from the knozzle can u help ?
Im not sure you have replaced on the mechine and you say it worked for a weak so it sounds like a new problem . But i owen a few powerwashers and wash houses as part of my bussiness. The most likely things that will stop the pressure are eighter the valves in the water pump witch under the caps on the pump the cages are sometimes made out of plastic and peices of the cage can break of and stop the valve to not seal all it takes is one of them but if you remove the peice the mechine will work again . However it could be what is called the unloader valve . This is a valve located under the water pressure control knob it adjusts the pressure at the tip but also allows the water inside the water pump to recurilate in side the pump when the trigger is not pulled so the mechine won't over build inside the pump if its stuck in recuriculate you will have no pressure at the tip . Most of the unloader are not rebuildable but i fine if you remove them and turn the knob while spraying WD40 into them most of the time you can free them by turning the pressure control knob You have to play with it good luck
May 23, 2011 | Garden
The timer on the washer of my Kenmore laundry center model 98702 is not working. After putting clothes in and turningthe knob to the size load needed and pulling the knob out the washer will fill and then...
YES IT IS A FAIRLY EASY FIX AND SOUNDS LIKE you have diagnosed correctly... go to a site called
www.sears.com then click the parts direct link up top as they sale everything...
once on the parts direct link type in your model number in the upper left box and pull down the menu in the right box and click model numer if you got the correct model number a part diagram will come up and click on the box that has your timer and scroll down to timer it will give you availabilty as well as a price to order online.... good luck to you
Jan 06, 2011 | Kenmore 98702 Stacked Washer/Dryer
How do I adjust the pressure on an old Northstar Pressure washer. Honda 18.0 HP, GX610 V-Twin
The following link will give you great troubleshooting for all pressurewashers. http://www.pressurewasherservice.ca/serv02.htm
There are several way to increase pressure. Primary way is to turn the pressure regulator knob in the direction to increase tension on the spring. Pressure regulator is located on the pump (or very neer) and usually has a large spring. Sometimes the spring is hidden under a twist knob. If the adjuster seems to be already turned to max then you may need to just change the pressure tip. The tip/nozzle is actually where the pressure is created by restricting the flow of water thru a very small opening. Use a new tip of the same gpm flow that is required by your machine. 18 hp machine has potential for very high pressure and high gallons per minute. Use trouble shooting guide above for more information. Good luck
Sep 30, 2010 | Northstar Garden
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
Husqvarna 3300 PSI 3.2 GPM Gas Pressure Washer 020524 Logo
109 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
