Question about Nokia Cell Phones
Remove double tap to unlock message on nokia gt 55300
Nothing not sure where to start
Nokia e63 netwark unlock code
Hello. Do you want to unlock your Nokia E63 from network restriction? If so, you can unlock it safer and easier using unique unlock code. You can get the unique unlock code for a Nokia E63 from ClassicUnlocking.com at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
1 - Switch on your Nokia E63 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E63.
3 - Compose #pw+CODE+1#.
4 - The Nokia E63 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E63 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia E63
Nov 19, 2014 | Cell Phones
My e63 is being barred frm service provider and it keep saying insert sim
When you have a sim in the phone, it could inserted the wrong way around, be defect, or could have dirty or oxidised contacts.
Try to eliminate all causes, and if you are sure the sim is defect just goto your provider with the phone and let them insert a new sim and put your number on that side.
Nov 04, 2014 | Cell Phones
How to unlock Nokia 97 with the unlock code?
Hello. Are you asking the unlock code for a Nokia N97? if so, you can get the accurate unlock code from ClassicUnlocking.com at affordable cost. Good luck.
1 - Switch on your Nokia N97 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N97.
4 - The Nokia N97 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia N97 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia N97
Sep 23, 2014 | Nokia 97 Mini 8 Gb Unlocked Phone Gps...
How do I unlock the screen on the nokia 635
Set the keys and screen to lock automatically
On the start screen, swipe down from the top of the screen, tap ALL SETTINGS > lock screen > Screen
times out after, and select the length of time after which the keys and screen are locked
automatically.
Sep 21, 2014 | Microsoft Windows Phone: 5" Unlocked Nokia...
Sir how do I unlock my nokia e51
Hello. You can unlock your Nokia E51 safer and easier using unlock code, You can get the accurate unlock code for a Nokia E51 from ProUnlocking.com at affordable cost with an easy unlocking guide. Good luck.
1 - Switch on your Nokia E51 without any sim card.
2 - Don't bother as to what is displayed on your Nokia E51.
4 - The Nokia E51 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia E51 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia E51
Sep 13, 2014 | Cell Phones
Nokia lumia 710 should be unlocked
Hello. What kind of unlock are you asking for your Nokia Lumia 710? If it is a network lock, you can visit TheUnlockSpot.com and get the accurate unlock code at affordable cost to get it unlocked. Good luck.
1 - Switch on your Nokia Lumia 710 without any sim card.
2 - Don't bother as to what is displayed on your Nokia Lumia 710.
4 - The Nokia Lumia 710 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia Lumia 710 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia Lumia 710
Sep 03, 2014 | Nokia Lumia 710 Smartphone Unlocked
Restriction code
Are you sure that your Nokia 5300 Xpress Music is completely unlocked from network restriction? If you have unlocked it, you can definitely use any other GSM SIM card with it. If you are not able to access any SIM card with it, it seems to be you have made some mistake in unlocking. The safest and easiest way to unlock a Nokia 5300 Xpress Music is using unlock code. You can get the accurate unlock code for a Nokia 5300 Xpress Music from OnlineGSMUnlock.com at affordable cost. Good luck.
1 - Switch on your Nokia 5300 XPRESSMUSIC without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5300 XPRESSMUSIC.
4 - The Nokia 5300 XPRESSMUSIC would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5300 XPRESSMUSIC mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 5300 XPRESSMUSIC
Aug 30, 2014 | Nokia 5300 XpressMusic
Unlockanyphone co cc
Hello. You can unlock your Nokia 6303i safer and easier using unlock code. You can get the accurate unlock code for your Nokia 6303i from Mobile-Unlocker.com at affordable cost. Good luck.
~<()>~_<()>_~<()>~_<()>_~<()>~_<()>_~<()>~
................UNLOCKING INSTRUCTIONS................
1 - Switch on your Nokia 6303i Classic without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6303i Classic.
4 - The Nokia 6303i Classic would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6303i Classic mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
The CODE you need to enter is the unique unlock code for your Nokia 6303i Classic
Aug 25, 2014 | Nokia 6303i Cell Phone
How I remove double tap to unlock samsung galaxy?
HI I want to remove double tap to unlock please advice how i can remove
Aug 17, 2013 | Cell Phones
How to unlock samsung gt-s5300?
how to solve double tap to unlock problem in samsung gt-s5300
Aug 04, 2012 | Samsung GT-S5300 Galaxy Pocket
Cell Phones Logo
35 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
