Question about Ricoh Aficio MP C3501 Multifunction Color Copier
How do I prevent envelopes from getting creased on a Ricoh MP c3500?
I have been printing on envelopes, but they come out creased and wrinkled. Someone once showed me a trick, but I can't remember what it was because it has been so long, but it involved lifting a roller? Or opening a lever??
  • paulfvincent Nov 25, 2014
    There is no lever. Your best bet is to download the Operator's Manual from Ricoh-USA.com and it will show you the options for printing on envelopes from the bypass tray.
    Champion:
  • Ricoh Expert
  • 208 Answers
Hopefully you are using the bypass when printing them. Creasing is only caused by two things. Moisture in the paper and uneven fusing. Make sure when you are printing them you select thick 2 in the printer properties pull down menu. If the problem continues switch the feed direction and possibly the brand of envelopes. The same thing applies to printing labels (the thick 2 setting will provide the necessary heat to properly fuse the toner). But when copying, push the # key and select thick paper from the menu there.
Posted on Nov 23, 2014
Testimonial: "I am using the bypass tray. Unfortunately, we can't change envelopes. I had it set to thick 2 as well. I can try to change the direction, but I remember our repair guy showing me a lever to move to an open position so it does not crease. Does that sound remotely familiar?"
3 Suggested Answers
  • 95 Answers
SOURCE: Ricoh Aficio MP C3500 Error Code SC529
It would help to know the code. Like SCxxx.
Posted on Mar 27, 2009
  • 903 Answers
SOURCE: how to print envelopes aficio ricio mp c4500
On an MP-C4500, envelopes must be printed using the bypass tray (the fold-out tray on the right hand side). Put the envelope in face-down and tighten the two fences so the envelope is snug.
When printing the envelope, make sure the print driver is set for the correct envelope size. If envelopes tend to jam in the printer, try setting the bypass paper type for thick paper.
Posted on May 29, 2010
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
Envelope printing error - envelope prints wrinkled from MP tray
sorry buddy but mfps wrinkle envelopes he have tried many things on many models they all wrinkle the best thing you can do is try to reduce the wrinkle we tuck the flap inside and that helps a little other than that sorry
When I try to print #10 envelopes on my HP Laserjet 4 Plus printer through the MP tray, they come ou with wrinkles, smudges and creases. And they are hot! ideas?
Make sure that if you have a setting for paper type you have it set for envelope. This would be found in the setup menus, I just don't remember if this model has that setting, they are getting to be rare now. The other common cause of print problems is the envelopes themselves, if they are old or have been stored where they have been allowed to absorb moisture, you will have a very hard time printing on them. Try some different envelopes if you have them.
Jul 11, 2011 | HP LaserJet 4 plus Printer
How do I print envelopes in the printer Samsung SCX 4824fn? thanks
• Successful printing on envelopes depends upon the
quality of the envelopes. When selecting envelopes,
consider the following factors:
- Weight: The weight of the envelope paper should
not exceed 90 g/m2 or jamming may occur.
- Construction: Prior to printing, envelopes should
lie flat with less than 6 mm curl, and should not
contain air.
- Condition: Envelopes should not be wrinkled,
nicked, or otherwise damaged.
- Temperature: You should use envelopes that are
compatible with the heat and pressure of the
machine during operation.
• Use only well-constructed envelopes with sharp and
well creased folds.
• Do not use stamped envelopes.
• Do not use envelopes with clasps, snaps, windows,
coated lining, self-adhesive seals, or other synthetic
materials.
• Do not use damaged or poorly made envelopes.
• Be sure the seam at both ends of the envelope
extends all the way to the corner of the envelope.
Envelopes with a peel-off adhesive strip or with
more than one flap that folds over to seal must use
adhesives compatible with the machine's fusing
temperature for 0.1 second. Check your machine's
specification to view the fusing temperature, see
page 82. The extra flaps and strips might cause
wrinkling, creasing, or jams, and may even damage
the fuser.
• For the best print quality, position margins no closer
than 15 mm from the edges of the envelope.
• Avoid printing over the area where the envelope's
seams meet.
Place the side to be printed facing up.
Envelope Preprinted paper Transparency
Punched paper Card stock Letterhead paper
Labe
open the direct paper try on top of your A4 paper try by pushing it!
Apr 22, 2011 | Samsung SCX-4828FN All-In-One Laser...
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
Envelopes
Make sure the paper type for the tray from which you print envelope is set to Envelope. If the printer doesn't know that an envelope is being printed, it will not turn on the "Envelope Enhance" feature. The Envelope Enhance feature pumps air out of the envelope before it enters the fuser and can prevent creasing in the envelope. However, keep in mind that any envelopes larger than a US Size 10 will most likely crinkle, with or without the Envelope Enhance
Dec 19, 2008 | Lexmark T644 Laser Printer
How to print envelopes aficio ricio mp c4500
Nov 19, 2008 | Ricoh Aficio GX5050 GelSprinter InkJet
Lexmark t640 noise
Lexmark says that this is a feature called Envelope Enhance. Two rollers 'thump' to remove air pockets in the envelopes to prevent creasing and wrinkling. The "feature" can be turned off in the Paper Menu.
Apr 11, 2008 | Office Equipment & Supplies
Printing Address on Envelops
E-mailing you the info I am finding
Apr 04, 2008 | Xerox Phaser 7300DN Laser Printer
Ricoh Aficio MP C3501 Multifunction Color Copier Logo
113 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
