Question about Sunbeam Blenders
I own a sunbeam multiblend platinum PB 7610. Over time smoothie liquid has collected under the glass base. It has rotted and smells really bad. I know how to remove the blades using the cap from the t
I own a sunbeam multiblend platinum PB 7610. Over time smoothie liquid has collected under the glass base. It has rotted and smells really bad. I know how to remove the blades using the cap from the top- this is not the problem. I cannot remove the black base to clean away the moldy liquid. How do I remove this black base from the glass jug to clean it properly? Again I emphasise I know how to remove the blades with the cap.
SOURCE: Blade not spinning
My Vitamix 3600 plus has same problem. Result of detachment of rubber coupling between lower splined socket from blade shaft. This is a tough rubber molding that takes tremendous punishment through years of smoothies. Mine showed some rust on the bottom of the blade shaft, where it parted. I tried gluing back together with super glue and tried to eyeball it. Of course it was off by a few degrees. When I reassembled and turned it on, what a racket of vibration! But it held. Amazing. Obviously not good to go though. So I took assembly all apart and redid it, chucking the shaft and the lower nut in the lathe. This time, all true on axis. Glue held for about a week. Right now I am regluing, this time with epoxy. We'll see how it holds up. And meanwhilst, I'm researching replacement parts! I'm not too optimistic about the epoxy.
Posted on Jun 15, 2008
SOURCE: The plastic base of the glass jug is broken, need repacement.
I used a 4" stainless steel hose clamp as ours was cracked but not in pieces. So far it has worked.
Posted on Jun 16, 2008
SOURCE: Any idea where we can get a new jug for a breville blender?
This happened to me recently. Go to this site and order it directly from Breville. They were very fast and customer service very helpful.
http://www.brevilleusa.com/home.do
Posted on Jan 21, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Back to Basics Smoothie Plus 600
Order a new blade assembly - $7.00 -
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4154&linkon=subsection&linkid=112&secid=53
-Tha Mp3 Doctor
Posted on Mar 25, 2009
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
Smoothie pro 600 manual
It means it's working very hard,
I suggest to put items that are thick in first and blend them then add the other ingredients after , the smell is the coating on the motor getting hot , if you see smoke coming out, drink your smoothie wash it out and take it back for a new one.
Jan 06, 2014 | Blenders
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
When I use the blender it is difficult to get it tight enough on the bottom so that the liquid does not pour out from the bottom. The ring is not cracked. I have had this problem for a long time and it...
Try tightening the ring by (unplugged), align and tighten the base ring, rubber touching glass, then the blade plate assembly, then the ring....Then place on the machine, press down and tighten more...
I find that you cannot sometimes get enough tighening by hand, due to the dimention of the ring and the human hand...
Oct 27, 2010 | Back to Basics Smoothie Elite Work Top...
Blenders Logo
178 people viewed this question
Top Sunbeam Blenders Experts
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sunbeam Blender Expert? Answer questions, earn points and help others
