My thermostat shows like a wifi symbol and I can't find in the user guide what means. Any help, please?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
I think your assumption that the problem is related to temperature isn't well supported. Most electronics are quite happy with temperatures far below freezing, and it doesn't make sense for it to be programmed to disconnect below a certain temperature. I think the question you should be asking is "Why does my thermostat stop talking to my router?" It's possible that the problem has nothing to do with the thermostat, but with the router. I'd wager that when you turn the thermostat off... it turns off... in which case it stops doing much of anything, including communicating with the router. Maybe u aren't aware but its a WiFi thermostat be more specific please
Posted on Dec 05, 2014
What does the following symbol which shows up at unanswered phone calls mean?
Hi clark I have a galaxy trend and I know the blue circle with a slash through it means somebody with a blocked phone number has tried to ring you.... The "A" I have no idea.
Below is a link to a download for the galaxy s4....CHEERS..
http://support.bell.ca/_web/Guides/User-Guides/Mobile/Samsung/Samsung-EN/Samsung-Galaxy-S4-user-guide.pdf
Mar 22, 2016 | Samsung GALAXY S4
Isnt showing wifi set up
The WiFi has to be on. to get to the main programming, press fan & the up arrow @ the same time for about 5 seconds. Now that you are in the programming mode, you need to scroll through to, I believe level 39 and turn it ON. This will enable the WiFi. Then press done to get out of programming mode. Your thermostat should start searching now as long as there is WiFi to connect to. Then you need to register the stat.
Nov 30, 2013 | Honeywell RTH8580WF WiFi Thermostat
Please explain your problem in full detailI have an AT&T HTC Inspire 4G, I unlocked it, I use T-mobile and only my wifi is working. The interent signal on the phone is showing an E with a check mark,...
I suppose that what you mean is that you can access your wifi networks but not your service provider's network.
If that's what you mean, check the user's manual CLICK HERE page 122.
Oct 25, 2012 | HTC Inspire 4G Smartphone
It has wifi or not?
Yes, it does! In order to download its user guide, go to this page, slide down to 'MANUALS & DOWNLOADS', 'MANUALS & DOCUMENTS' tab, and click over 'AT&T(USA)_en'. You'll be prompted to download it in pdf format.
Hope it is what you've been after.
Anyway, please, let me know if you need further informations.
Regards,
Carlos
Sep 15, 2012 | LG Xenon GR500 Cell Phone
Getting F 5 error on upper oven
Do you have turbochef tornado oven. F5 is related to magnetron thermostat circuit. Note :-oven contain 5000 volts if you know to discharge capacitors then only open the microwave otherwise call tech. When you open right side panel you will see two magnetrons mounted on the two wave guides. On the rear side of the magnetron you will see two thermostat each. It's very big job to open everything and check. Insted. I will show easy fix. You will see two connectors under the middle of two wave guides( at the same vertical location where vertical support rod is present). Use DMM and check the connectivity between two terminals.it should show some resistance. If it shows OL then it means it's bad. Tell me if you reached upto here. I will guide you to replace magnetron thermostat. Thanks Please rate my work
Sep 18, 2011 | Ovens
Flame symbol showing on theremostat
It's not your thermostat. Go to where your heating system is and give us a make and model number so we may help you.
Feb 11, 2010 | Honeywell Programmable Thermostat Heater
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
Just want to know what the symbols mean so i can settle them , where i can see the discription of the symbols so i can choose
Iam glad to be of help. please download the user manual for your camera at:
http://files.canon-europe.com/files/soft24284/software/A520A510_CUG_EN.pdf
pages 12 and 13 of the user manual will show you the description of all the symbols.
Oct 26, 2009 | Canon PowerShot A520 Digital Camera
Need a users manual
Hello, You will get the reference guide for your Symbol PPT 8800 scanner in the following link. http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5809304apdf&sliceId=&dialogID=108884644&stateId=1%200%20108882281 Hope it helps, Good luck! ~regards, Jegan
Jun 03, 2009 | Symbol PPT 8800 Wireless Barcode Scanner
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
