Question about Remington Garden
AUTOAMTIC OILER NOT WORKING ON MY REMINGTON RODEO PRO
CLEANING OIL TANK
  • Remington Master
  • 1,169 Answers
You probably will find the driven gear on the oil pump bad. There are plastic and gets damaged fairly easily when trash get into pump drive area.
Posted on Nov 21, 2014
  • 211 Answers
SOURCE: Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Posted on Dec 23, 2008
dontbother10
  • 2220 Answers
SOURCE: chainsaw chain oiler not working
There is probably a filter on the bottom of a hose within the oil tank. Go through the tank fill cap with a blunted rod. Move it slowly you should find the hose. Draw it gently toward the opening. You can probably find a new filter at a Husqvarna (parent company) dealer if you don't have a Jonsered dealer handy. Oil pump replacement is complicated. Any good chainsaw mechanic can replace it regardless of what saw they sell. Arboristsite dot com is a buch of chainsaw nuts (Eye r 1). They will give you better guidance. Please do a searh in the chainsaw forum before asking "how do I fix my saw", the answer has almost certainly been asked. Spike60 is a Jonsered dealer and is always helpful. HTH Lou
Posted on Sep 02, 2009
dontbother10
  • 2220 Answers
SOURCE: husqvarna 340 oiler not working cleaned tank and
I opened the 2008 "Operator's Manual" and was pleasantly surprised to find an oiler adjustment. I think you are aware of it and it did not solve your problem.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
If my thinking is correct the next most logical problem is the oil pump or worm gear.
Detail B here: (May not be your saw)
http://weborder.husqvarna.com/order_static/doc/USA/2007/I07000/I0701021.pdf
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Behind the Outboard clutch.
View this to help with removal:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
Lou
If I can be of more help please add comments below or repost.
Posted on Dec 16, 2009
Testimonial: "Turned out the gear has a bad spot in it Part no. 503932101 I actually found it before i read this answer. But the answer was very good."
  • 4088 Answers
SOURCE: My saw is not oiling enough. It only uses
Release the chain brake and remove the bar and chain. Clean the engine area where the bar fits to, then start the engine--oil should ooze out of the side port. In that case, clean the bar drive-end small oil passages that run from the large holes out to the chain groove on each edge. These passages commonly plug with sawdust/dirt over time and cause greatly reduced oil to the chain/bar. When all is back together, run the saw at speed with the bar tip near some cardboard--it should throw off a thin line of oil after a moment or two of running. Adjust the oil volume screw to achieve that result. Hope this helps!
Posted on Dec 10, 2010
johndoe541
  • 784 Answers
SOURCE: I have a 180 Sthil
hello, hawe you checked oil tank cap. Is ther air inlet free?
Posted on Mar 23, 2011
Oiler not oiling
If you have not already done so remove the bar and clean out the the oil delivery hole, drain the oil tank, fill with a suitable cleaning fluid and rinse the tank out, this may clean any blockage in the tank filter, if still no better you will have to remove the oil pump, clean and check the worm gear, the pump is normally behind the clutch and sprocket, this will mean removing these components to gain acess to the pump,
Apr 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain oiler does not seem to be putting out enough oil,what can i do to increase the flow?
This model does not have an adjustable oiler. If the ports are clean and the pickup is clean, you may need to replace the pump. This is generally an inexpensive repair.
Feb 20, 2011 | Poulan Pro PP4620AVX 46cc Gas Chainsaw...
Oiler is not working on 450e.
Remowe right cap and cutting blade clean the oiler. If dont help check oil tank and clean it check oil tank cap teher must be air inlet is it clean.
Nov 10, 2010 | Husqvarna 450 e-series 18" Chain Saw
My Poulan Pro PP4620AVHD bar oiler is not working at all. I have cleaned out the oil holes on the bar, but still no oil on bar. Is the pump located inside the oiler tank?
The pump should be located just behind the clutch assembly which needs to be removed to access the pump. Have you run the engine with the bar and chain removed? The oil should ooze out of the engine side port where the bar fits up to. If not, then the pump is certainly suspect. There is a filter in the oil tank which might be plugged. The clutch has left-hand threads and can be difficult to remove. Don't try to use an impact wrench with adapter as it will cause the flywheel key to shear. Hope this helps!
Oct 23, 2010 | Garden
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
3.0 Peak HP 16'/41 cm remington
You might actually have the chain too tight. With the saw off you should be able to lift the chain until the gear tooth (tooth on inside of chain) almost lifts out of the chain bar.
I've never used an electric chain saw but if it has a chain oiler you should also check your chain oiler to make sure you're getting enough oil on the chain, if you run the saw with the chain aim at a clean surface you should see oil on the surface almost immediately.
May 26, 2010 | Remington Electric Chain Saw
Chain oiler is leaking out oil to quickly, how do you stop this problem
Hello Paul;
I do not trust the headings, is this a Poulan PP4218(something)? I did not see an oil adjustment mentioned in your OM so I hope there is a split or disconnected hose. If all is working properly (1 tank of oil for 1 tank of fuel) perhaps we can place a restriction in a hose if excessive. If it oils your bench when oil left in the tank when stored they all do. I think your manual recommends the tank be drained.
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com/CurrentModels
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
I know it is to much oil but the required action is the same.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 27, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Automatic oilernot working
Basics to check:
1) pick-up filter in tank clean
2) oil feed hole in bar clean
3) oil feed line from pump not cracked
4) pump worm gear and drive from under clutch (clutch removal needed)
Nov 11, 2009 | Poulan Pro Chain Saw 46cc 20"
I have a Poulan Pro 380 that is leaking bar oil.I can fill it with oil and it will leak out during the night.
I have 7 chainsaws. 6 of them if I forget to drain the oil reservoir will oil the surface of what they are sitting on. What you are seeing is normal.
IMO; use of the oiler creates a siphon. Any oil left in the tank will continue to siphon until the reservoir is empty. I could be wrong, I have been before.
Draining the tank works, nothing else I've tried does. HTH
Lou
Nov 06, 2009 | Poulan Pro Chain Saw 46cc 20"
Remington mighty mite chain saw
hi Wayne
Oiling has nothing to do with compression.It has conection only with engine rotation(rpm).More rpm results more oil and viceverse.Check the oil filter,the oil line,the holes from the bar,the oiler,the wormgear and the oil hose.
wish you all the best savumihai71
May 14, 2008 | Remington Polesaw Wizard
Garden Logo
133 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
