Question about Fujitsu Office Equipment & Supplies
Fijitsu fi 6000 ns. When powering the scanner on it has a long beep that repeats over and over. A blank screen and never gets past that state.
Fi 6000 ns. Part # PA03544-B005. Ser # 000809. Mfg Date 2007-8. When trying to power on the scanner the unit beeps a long solid beep that will repeat over and over. The screen is also blank and will not get past that state.
    New Friend:
In case anyone else encounters this issue the long beep means the memory in the scanner is bad. I just completed a teardown/repair on our unit so I'm attaching my notes in hopes they help the next person... or that they help me if I have to do this again. ;)
The scanner is made up of four distinct components sharing one case: USB keyboard, touchscreen monitor, the actual scanning hardware and a micro-ATX computer on the bottom. The computer uses an Itox G5G330-P-G motherboard which takes up to two PC2700U DIMMs (one 512 MB stick is in there already) and, depending where you check, can also take PC3200U. Itox's official spec sheet doesn't specify PC3200U as an option but based on another source and components I had available I installed 2 x 512 sticks of PC3200 without issue.
You may be able to change the order of the first few steps but this is the way I did things. Disconnect/move external cables out of the way as necessary. Take pictures as you go. This will save you headaches.
The first step is to unplug everything from the back. Not just power, the USB cables too. Once those cables are disconnected you'll have to unscrew and remove the back plate.
Next, tilt the scanner component (not the whole unit) forward to reveal two plastic tracks on which it slides. Remove the screw from the top of each track and lift the scanner component straight up. Set it somewhere safe.
The tray is attached to the top of the computer by two screws. Remove the two screws securing the plate and pull it out backwards. It might snag a USB cable on the way out so be careful.
Each side plate is attached with plastic clips and four screws: three screws are on the underside of the scanner and one is on the inside of the unit, just under the keyboard. Remove all four screws and carefully pop the plate off. Repeat on the other side.
Unscrew and lift up the front plate.
After all that's done you should have access to all the screws on top of the case housing the computer. Remove all the screws from the top of the computer case and slide the plate off.
Because it's a standard Micro-ATX motherboard you just need to remove the memory as you would on any desktop.
Install your replacement memory, maybe a little extra (I upgraded it to 1 GB) and repeat all the steps in reverse to reassemble the unit.
You'll probably get a CMOS error on first boot. Just hit F1.
If the unit complains about being unable to initialize the scanner it's because you didn't reconnect it. Same goes for no video but appearing to function otherwise.
microATX G5G330 spec sheet. I started with a Cnet article that mentioned PC3200 and as I said, it functions correctly.
Posted on Oct 15, 2015
    New Friend:
Just went through this. Unit is a mini-ITX pc w/ custom pwr supply, screen, and a cute little USB keyboard. Not going to get into into the disassembly w/ this answer, but the bottom line is a bad RAM stick. Uses PC2700U 333 Class 2.5 DDR, 512MB. Replace that, the beep stops, the machine will POST and pwr up.
Posted on Aug 04, 2015
    New Friend:
    Problem Solver:
  • 18 Answers
Printer hardware problem. so contact your nearest hardware mechanic
Posted on Nov 23, 2014
5 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: Scanner does not work at all - no power now to the device
u could try new adpter how much are they online compare dto new lexmark flat bed scaner
Posted on Jan 21, 2008
SOURCE: Cr-180 Won't Detect Checks
Embarassingly enough, a reboot took care of the issue! Duh.....
Posted on Apr 07, 2008
tommya300
  • 724 Answers
SOURCE: my epson 3200 photo scanner won't initialize. the
Loock for the transport locking device
Posted on Jul 28, 2009
SOURCE: Power & ReadyLight come on scanner. Scanner
Hi, well I have seen this type of thing countless times in my shop, and it has to do with the CCD & main circuit board in the device. The only "Fix"is board/CCD replacement.
I am not too sure if this would be an economic repair? if you wish to repair, you would need to obtain a "Quote" first, and see exactly how much it may cost? As the cost of repair may indeed approach or exceed the cost of a new unit. most of my customers have opted to replace the unit with a new more up to date one with a warranty.
Posted on Jul 06, 2011
I got a insignia tablet flex 8 that has windows that is locked.
PDF]USER GUIDE Insignia Flex™ Android Tablet
www.insigniaproducts.com/.../NS-14T002_13-0622_WEB_V1_ENG_Fi...
Oct 11, 2013 - 8. NS-14T002 Insignia Flex™ Android Tabletwww.insigniaproducts.com. Setting up your .... Unlocking and relocking your tablet. When you turn ...
NS-13T001 Insignia Flex™ Android Tablet
www.insigniaproducts.com/cms/documents/manuals/tablets/.../help.html
Creating a screen unlock pattern ... Your Insignia Flex Tablet represents the state of the art in Android tablet ... Your tablet's internal storage capacity is 8 GB.
Insignia (Bestbuy) Flex 10.1 Tablet unlock - XDA Developers
forum.xda-developers.com > General discussion > Questions and Answers
Jan 17, 2014 - 3 posts - ‎3 authors
Insignia (Bestbuy) Flex 10.1 Tablet unlock Questions and Answers. ... UnlockBootloader, Install TWRP and Root the Huawei Mate 8 ... the tablets bootloader isUNLOCKED already, I tried the OEM unlock command in adb and ...
Creating A Screen Unlock Pattern - Insignia NS-14T004 ...
www.manualslib.com > ... > Tablet > NS-14T004 > User manual
You can increase the security of your tablet by creating a screen unlock ... 101. NS-14T004 Insignia Flex™ Android Tablet ... Wi-fi windows 8" tablet (86 pages).
Jan 31, 2016 | Insignia - Flex 8 inch Tablet with 8GB...
Fi 6000ns beeping
Oct 21, 2013 | Fujitsu fi 6000NS Flatbed Scanner
3 beeps on startup
Below are IBM BIOS Beep codes that can occur. However, because of the wide variety of models shipping with this BIOS, the beep codes may vary. Beep Code Description Document No Beeps No Power, Loose Card, or Short. CH000312 1 Short Beep Normal POST, computer is ok. No problem 2 Short Beep POST error, review screen for error code. See screen Continuous Beep No Power, Loose Card, or Short. CH000607 Repeating Short Beep No Power, Loose Card, or Short. CH000607 One Long and one Short Beep Motherboard issue. CH000607 One Long and Two Short Beeps Video (Mono/CGA Display Circuitry) issue. CH000607 One Long and Three Short Beeps. Video (EGA) Display Circuitry. CH000607 Three Long Beeps Keyboard / Keyboard card error. CH000304 One Beep, Blank or Incorrect Display Video Display Circuitry. CH000607
Mar 26, 2013 | IBM ThinkPad Computers & Internet
Hello, I work for a doctor's office and we scan a lot of documents. Lately we are getting a code ds42003 on a fijitsu scanner, what should i do this code is on the fi-4010cu, we also have a fi-5120c...
it is logical that in an office where document scanning is important and vital, you would call in the service technicians to fix it so that the interruption is minimal
Nov 28, 2017 | Fujitsu fi-5120C
Blank screen; Unresponsive computer, & three beeps in succession
2 short beeps and 1 long beep (repeats 5 times) = Unable to initialize video or video card required but not installed. Sounds like the card may have gone down
Jun 19, 2009 | Intel Desktop Board D845GLVA...
My satallite pro 6000 wont boot up
This error code most likely refers to the RAM.
The RAM module/s may only need reseating to make proper electrical connection.
If this doesn't work the the RAM module/s is possibly faulty. Take it to your friendly computer shop the get it tested or insert it into another laptop to test the RAM.
May 07, 2009 | Toshiba Satellite Pro 6000 Notebook
Computer beeps when I try to start up
No Beeps
1 Short Beep
2 Short Beep
Continuous Beep
Motherboard issue.
Three Long Beeps
Jan 05, 2009 | HP Computers & Internet
Multi scan
it is only made and set up for a single scan at a time. i thought the same thing when i had one.
Jun 27, 2008 | Fujitsu fi-5120C
Insignia NS-8PDVD blank screen...
There is a switch on the side of the DVD player that reads "in / out".  Switch it to out and you should get the blue screen back.  It's a strange set up but this is how it works.
Dec 08, 2007 | Insignia NS-8PDVD
392 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Smidler
Level 1 Expert
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
