Question about Samsung Main Board Washer Dc92-00301e Wf210anw/xaa
I need to fix my front load washer
It is not spinning the water out of the clothes, has a sound in the back, thought maybe drum is loose?
    Master:
  • 487 Answers
Drums don't get loose, their bearings wear out. if it is old most likely it is toast, if newer then may be worth repair
Posted on Nov 21, 2014
I have a Frigidaire affinity front load washer (fafs4474lwo) it doesn't do the final spin to get the water out of the clothes. I was getting an E52 and E58 codes. I replaced the drive motor and the motor...
Just a thought. If the drum spins when washer is empty that tells me your belt could be shot and just slips when there is a load in it. Check and see if the belt wiggles or appears loose when you squeeze it by hand with the plug pulled of course. If the belt is tight it could be a pulley is spinning on the shaft.
Jul 19, 2017 | Frigidaire Washing Machines
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
Clothes too damp after spin cycle
Front loading washers are notorious for not spinning the water out of a small load of clothes. This is because there is not enough clothes in the washer to balance the tub during the spin cycle.
Try washing a slightly larger load with a minimum of six items or more. This is one of the downsides to front load models and no specific brand is immune to the problem.
Mar 17, 2013 | Washing Machines
I have a frigidaire gallery front load washer need help
Run the machine on a cycle with no load in it (no soap powder either)
If it makes the same noise when there are no clothes in it then the suspension legs have given way or the counterweight has come loose.
You will need someone who knows what they are doing to repair it
May 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
When the washer finishes the spin cycle and I open it up to remove the cloths, the water continues to drip into the drum. What do I need to do to repair this problem.
It sound's like the water inlet valve is stuck open, it's located at the back of the washer, the cold and hot water hose's connect to it, you may need to replace it with a new one to fix the drip.
Apr 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sounds like a loose screw/bolt/nut during the spin cycle
There is nothing wrong with your machine. Don'f bother with the sound , You said you threw 2 pair of jeans, so its bottons are causing the sound against the drum during cycle. Finished your laundry and worry no more. To make sure, throw some another clothing asides form jeans, like shirts, and feel the normal silent of your machine.
Good Luck,
Eriez
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Samsung Main Board Washer Dc92-00301e Wf210anw/xaa Logo
83 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
