Question about Water Heaters
You need to get 7 gallins of water, you have a 3 gallon can and a 5 gallon can. How do u get 7 gallons?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Water Heaters Master
  • 102,366 Answers
Fill the five-gallon can from the creek. Pour three gallons into the three-gallon can, leaving two gallons in the five-gallon can. Empty the three-gallon can, then pour the two gallons from the five-gallon can into the three-gallon can. Fill the five-gallon can from the creek. You now have two gallons in the three-gallon can and five gallons in the five-gallon can for a total of seven gallons.
Posted on Nov 21, 2014
  • 2692 Answers
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Posted on Jan 31, 2009
  • 2976 Answers
SOURCE: takes a long time to heat water
If you are using a 3/8" copper line for your gas, get it replaced ASAP. It will fail. 1/2" Black Iron is required with natural gas. 50 gallons is a lot of water to heat. Look on the heater label for the recovery rate.
Posted on Feb 27, 2009
SOURCE: We have a Reliance 501 (40 gallon) natural gas
Your Reliance serial number shows your water heater was made in July 1994.
Except for the Marathon water heaters, and copper-tank water heaters, all tank-type water heaters are made of steel. That steel has an enamel coating which people call a glass liner.
So in that sense, there is a glass liner.
See a photo of the liner:
http://waterheatertimer.org/images/Enamel-coated-steel-290.jpg
Also inside the tank is an anode rode.
The anode is made to protect the steel tank.
Anode is made from lower noble metal than steel, so water reacts with the lower noble metal first.
The water eats away the anode rod instead of rusting the tank.
Once the anode rod is gone, the water begins rusting the tank.
The enamel coating does not protect the steel from rusting.
The tank rusts away and begins to leak.
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Posted on Nov 01, 2010
heatman101
  • 43501 Answers
SOURCE: I have a 5 ft height 2 ft width [501] 50 gallons
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
heatman101
Posted on Jan 12, 2011
  • 23 Answers
SOURCE: I have a rheemglas standard electric 40 gallon
You should have two panels on the front of your water heater most likely painted blue. Each of these panels contains a heating element. The top panel contains the reset switch. Unscrew and remove the top panel and you'll see the reset switch - it is the red button. Press it to see if it clicks. If so, your hot water should last longer.
If it does not last longer than you stated, then you most likely have a bad heating element. The problem is that unless you remove both elements, you won't know which one is bad. If you don't feel comfortable turning off the water valve to the heater, turning off the power to your water heater at the circuit breaker box, draining the heater of it's water using a garden hose, removing the wires from the elements, removing the elements and installing new ones from your home improvement store then you may want to hire a plumber to do it.
The process is fairly easy but time consuming. The most time is draining the water heater. If you do choose to do it yourself, you will need to get a special "wrench" from your home improvement store to remove the heating elements first. The store can help you with the element(s) you need once you take them in.
Regards
Posted on Apr 05, 2011
How do I compare gallons of water to a cubic foot?
1 cubic foot = 7.48051948 US gallons
1 cubic foot = 6.22883545 Imperial gallons
Mar 02, 2015 | Water Water Heaters
Your father sends tou to the creek to get 7 gaf water. You have a 3 gallin can, and a 5 gallon can. How do tou come away with 7 agllons?
Nov 21, 2014 | Water Heaters
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Is a 80 gallon hot water heater legal for a 7 apt. building?
You probably need commercial 150gallon gas water heater.
Or three 80 gallon tanks, depending on number of people.
80 gallon residential gas heater is rated for low-demand 6-8 person household.
80 gallon residential electric is rated for low-demand 5 person household
80 gallon is not correct for 14-28 people in 7 apartments
http://waterheatertimer.org/Whatsize2.html
http://waterheatertimer.org/Two-water-heaters.html
Call local plumber, or local code department.
Apr 10, 2013 | Water Heaters
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
Sep 13, 2011 | Rheem Water Heaters
What is proper vent size for my hot water heater
go to 4 better to big than finding 3 was to small
Nov 19, 2009 | Water Heaters
Not really a problem, I wanted to know if I have one installed in my hair salon will it be as good as adding a Tankless water heater?
it depends how much water you use. you may want a 5 gallon model. the tanklwss heat the water as needed and the tank kind heat justr the 2 1/2 gallon so if you use alot of water go with tankless most of the tankless are gas so you would need a supply and exhaust
Oct 17, 2009 | Emerson InSinkErator 2-1/2 Gallon...
Code LC, I cleaned the filter, won't stop beeping
you need to flush out the rinnai. to do this you will need 4 gallons of white viniger & a circulating pump. #1 disconnect the power. #2 close both incoming & outgoing water valves under the unit. #3 conect a drain hose to the out going flush valve ( flush valves are under the unit & have brass caps) #4 connect pump outlet hose to ingoing flush valve. #5 put pump incoming hose & drain hose from outgoing flush valve in a 5 gallon bucket. #6 pour 4 gallons of vinager into the bucket. #7 open both flush valves. #8 turn on the circulating pump & let viniger pump in the incoming flush valve through the rinnai & out the outgoing flush valve back into the bucket for 45 min. #9 disconct pump from incoming side & close incoming flush valve.( don,t close outgoing vaves at this time) #10 put out going hose in empty bucket. #11 open incoming water to flush viniger out of unit. # 12 disconct outgoing hose , close outgoing flush valve & open outgoing water valve. #13 clean filter & turn on power.
Jul 08, 2009 | Rinnai Water Heaters
Can a insinkerator hot1 be hooked into a low
there shouldn't be a proble it actually would work less if you are getting low pressure,, but how did you come to the conclusion that it is low pressure,, do yo have a guage, you should not loose that much pressure on any fixture
Mar 27, 2009 | Emerson Insinkerator 2.5 Gallon Water...
Water Heaters Logo
101 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
