AO5 keeps flashing with a click sound
Plugging n unpluging
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 102 Answers
Check room sensor and coil sensor
Posted on Nov 26, 2014
A05 on screen. Will not let me change temperature. Will not come on.
turn on heater ao5 comes on hit temp switch clicks but goes back and forth from ao5 to temp degree is it the printed circuit board please email at archieholdsworth@yahoo.com
Jan 08, 2016 | Comfort Zone CZ1500WC Infra-Red...
Error code AOS
its show flashing AO5 code and than shut off
Nov 18, 2013 | Comfort Zone CZ1500WC Infra-Red...
Sony TV model KDL-46Z4100, standby light flashes 14 times, no picture, no sound
14 blinks to Sony Brand LCDs indicates a 'Backend error'. It means that, the main board to this TV should be checked for fault. In most cases the main board might need replacement, and a software update too. If you wish to know more details about this blinking code, check this link. It has details of blinking codes to several brands of TVs including Sony. Actually the work is a skilled one, need experience.
Jan 20, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Flashing AO5
if the relays are clicking there are 2 1000uf capacitors on the main board that will be bad. If you know how to work on electronics you can unsolder and then replace them problem solved I just fixed my dads heater today cost about 2.00 bucks :). The capacitors have to be 1000uf 105c google them.
Jan 04, 2013 | Comfort Zone CZ1500WC Infra-Red...
TV will not turn on. I press power and it sounds like it's coming on and then clicks and the stand by light flashes 7 times. Have already tried unplugging and then plugging back in after a minute
When I called a tv repair company the rep said this usually indicates that the "lamp" for this model needs to be replaced. Since he TV is so heavy he suggested that I access the trap door in back of the console and detach the "lamp" myself and bring the lamp to his shop for replacement. Approximate cost for the lamp is $200.00. Wish me luck.
Dec 01, 2011 | Sony FD Trinitron KD-34XS955 34" TV
Mouse quits working, have to keep unplugging and plugging in
It sounds like a short in the mouse's wiring. Best to get a wireless mouse if you use it alot
Jul 15, 2010 | Dell U0636 Mouse
I have a 46in. Samsung LCD TV. It worked lastnight now I tryed to turn it back on and all it does is the power light flashes and it make's a clicking sound can you help thank's very much.
The clicking noise indicates that its a power supply related issue. When the relay switches turn themselves off you will hear that sound. The first thing you should try is to unplug the set and hold for 5 minutes before plugging it back in and turning it on? Why? Because a power surge may have triggered these relays and unplugging them will reset them so that you can see if the set turns on. Otherwise we will proceed accordingly and troubleshoot the components provided you can follow a schematic.
Sai.
Mar 23, 2010 | Samsung 46IN LCD 1200:1 460DX BLACK 8MS...
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
