Question about The Times ROYAL TC100 TimeMaster Time Clock
How do I fix the control knob when it won't advance past the first out on day 5?
I have tried rolling it back to day one and then going forward to day 5 again, but it seems blocked. I can't see if anything is blocking the belts or not.
    Problem Solver:
  • 18 Answers
Main function problem created in it. main function part will change
Posted on Nov 23, 2014
Continuous clicking from an igniter in the off position. I have to slightly turn the control knob towards the hi position to stop the clicking and for the light on the control knob to go off
sounds like it was turned a little past the stop point.
Pull two knobs off and examine the back side that slides onto the shaft.
Switch them and try again.
If the problem is on the same burner, the shaft may be turned past its normal stop position.
You can try turning it until it stops in the opposite direction and force it just a tiny bit more.
That was how I fixed mine.
Nov 06, 2013 | DCS 36 in. CP-366 Gas Cooktop
W117-95809151012
Well, I had the same question, since i just advanced my watch past June 31 (since June has 30 days) but now my weekday is ahead by a day. So I started messing with it and found that you advance the date by advancing the time forward. But if you go backwards, the date won't change, only the day of the week... does that make since?
May 07, 2013 | Disney Watches
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
In standby mode:
Enter Menu mode:
Press the [MENU] button for at least 1 second.
"Menu" is displayed.
Step 2:
Select Clock Adjustment mode:
Push the Control knob to [FM] or [AM].
Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:
Press the Control knob for at least 1 second.
The clock display blinks
Step 4:
Adjust the hours:
Adjust the minutes:
Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment mode
Press the [MENU] button.
Step 6:
Date Adjustment...
Select Date Adjust mode
Push the knob to [FM] or [AM].
Select the "Date Adjust" display
Step 7:
Enter Date Adjust mode
The date display blinks.
Step 8:
Selecting the item (day, month, or year) to
adjust
The items that are blinking are items that can be
adjusted.
Step 9:
Adjust each item
Step 10:
Repeat step 8 and 9 operation and adjust the
date
Step 11:
Exit Date adjustment mode
Step 12:
Setting the date format.
Select Date Mode
Select the "Date Mode" display.
Step 13:
Select the date format
Step 14:
Exit Menu mode
Hope this helps.
Cheers,
Scott
Jan 14, 2013 | Kenwood KDC-MP628 CD Player
Mazda 6 passenger window won't go up!!!
It sounds like it could be the window solenoid, or the window motor. It's unlikely the switches on both doors are bad. Check the solenoids and motors...
Oct 16, 2012 | Mazda Cars & Trucks
I don't know how to set the date properly on my Tag Heuer formula 1 watch. Is there a time of the day that I should do it?
If you go to http://www.tagheuer.com/the-collection/tag-heuer-formula-1/men/quartz-chronograph/index.lbl?w=CAH1110.BA0850 , you will see a menu on the right of the screen.
Clcik on "user manual" to download the manual for your watch.
There are no instructions about setting the date apart from saying the date changes at midnight but you can advance the date by winding it past midnight. If you want to advance it more than one day, wind it back and then forward past midnight again. Repeat as many times as required until you reach the date you need.
How far back you need to wind the watch you will have to find by eaperimenting and observing when the date changes. You might hear a soft "click" when winding it backward, you can the wind it forward again.
Feb 01, 2011 | Tag Heuer Formula One
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
I have an old lucerne windup day date watch but the crown only pulls out 1 notch only to set the time. how do i set the day date or do i have to sit there and advance it manually
The date changes hen the hour hand passes midnight (more or less).
To change the date for more than one day wind it past midnight and when the date has changed, turn the time back past midnight and then forward again.
You may have to experiment to find out how far back before midnight you have to go before going forward again, but at least you don't have to wind it 24 hours for each day!
Feb 16, 2010 | Watches
Timer knob
HI. the timer mechanism has failed. these timer control modules will run about 134.00. simply replacing this timer will fix your issue.
May 28, 2009 | GE Washing Machines
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
The Times ROYAL TC100 TimeMaster Time Clock Logo
78 people viewed this question
Top The Times Office Equipment & Supplies Experts
jasbo
jasbo
Are you a The Times Office Equipment and Supply Expert? Answer questions, earn points and help others
