Question about Refrigerators
Hotpoint quadrio fridge bulb not working - Refrigerators
  • Refrigerators Master
  • 744 Answers
Hello Donna;
My name is Peter. I am a retired field service refrigeration technician.
Ok, lets fix the problem:
1.) The light bulb is a special bulb designed to operated in cold temperatures. Some food markets carry them. They cost $10.00-$12.00 each. A normal household bulb will fail.
2.) Assuming you have the correct light bulb. With the refrigerator door open, is the light on? Push the light switch, does the light go off? Light switches either have a small whit plunger or a curved actuator.
3.) Ok, before we assume a bad switch. Unplug the refrigerator. Remove the light bulb. With a flat head screw driver, lift the copper contact in the bulb socket just a little bit, to make sure the copper contact is not depressed and not making contact with the bulb. Put the bulb back in, plug your refrigerator back in. Does the bulb light?
4.) Now we have narrowed the problem down to the light switch. The light switch is normally mounted on the inside wall. It may also be part of the top door hinge assembly (Push pin). If it is in a bottom freezer it is located on the inside top liner in the middle. These switched have pop in retaining clips. With a small flat head screw drive or a peeling knife gradually pry the switch out. You will see either two or three connectors. Remove the connectors noting how the wire leads are attached, The wire leads are short. Be carful not to let they fall down into the liner wall. Lets check the switch, if you have a multi-meter, set your meter to the lowest Ohms. With one meter lead on one switch contact and the other meter lead on the other switch contact, you should get a reading of '0' Ohms. Anything else then the switch is bad.
Oh, you do not have a multi-meter, rest assured if you check the above you have a contact switch problem. Get the model number of your unit. Usually located on the fresh food section wall. Call you local appliance parts supplier and get a new switch.
If you have a push pin switch in the top door hinge, there are either 1 or 2 screws to be removed to remove the hinge cover access the switch.
Samsung has magnetic contact switches. In the door gasket, as with all door gaskets there is a flexible magnet strip. This strip makes contact at the top of the refrigerator front frame. In this case the magnet door gasket strip may be broken and had slipped out of position. In the case you must replace the door gasket. You can physically feel this magnet strip.
Posted on Nov 22, 2014
4 Suggested Answers
SOURCE: my hotpoint quadrio amber lights at the top of the
my hotpoint quadrio is causing problems the fidge part is no longer cooling the light is coming on but thast is all what can cause this. can anyone help
Posted on Jun 06, 2010
heatman101
  • 43501 Answers
SOURCE: hotpoint quadrio fridge isnt cooling
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on May 11, 2011
SOURCE: user manual for hotpoint quadrio
Trips mains when turned on
Posted on Jun 28, 2011
Where is the fuse on hotpoint quadrio fridge freezer
Hello Donna;
Refrigerators do not have fuses. They have independent component (Part) failures that act like a fuse.
If you can provide me with a model number and some detail of what the issue is, I would be more than happy to help you.
Nov 21, 2014 | Refrigerators
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring).
Dado
Apr 26, 2014 | Zanussi Freezers
Sounds like the switch that controls the light is disconnected.
Gently pry the switch out(power off) and see that both wires are connected to the switch.
Feb 11, 2014 | Kitchen Ranges
It's a 2 pin lcd bulb, remove plastic cover, pull kight out, replace same, try not to touch glass area of new one.
Nov 19, 2013 | Refrigerators
Hotpoint quadrio fridge isnt cooling but freezer is can i start its defrost cycle manually?
heatman101
May 10, 2011 | Hotpoint Refrigerators
My hotpoint quadrio amber lights at the top of the fridge door are flashing is this anything to worry about - they are indicated with the words ''super cool'' and ''super freeze'' (sorry but cant find...
Feb 20, 2010 | Refrigerators
Refrigerators Logo
90 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
