Question about Pool & Spa
2 black wires from pump, which is pos. or does it matter
    New Friend:
  • 35 Answers
You should connect the pump with 3 wires: one is phase, one is zero and one is earth. It does not matter which is phase or which is zero. when there is a square sign on the pump this means the pump is double isolated and you only have two wires, and it does not matter how to connect to mains.
Posted on Nov 21, 2014
What colors are the Speaker Wired for a 1993 gmc 1500 van
    1. OK,GMC/GM are wired as such. White/Black wire, front left -[neg] White, front left +[pos]. Grey/Black wire, front rt -[neg], Grey wire, front rt +[pos]....Green/Black wire, left rear [neg], Green, left rear [pos]....Violet/,Black , Rt rear [neg],...Violet, Rt.rear [pos]........You will also have a Blue/Red wire that goes to antenna. ..A Blue wire for Power Remote....Red goes to IGNITION.....Yellow goes to Battery[for clock].....And finally a Black goes to Ground.......I hope that you have good luck and everything works out for you. `
Sep 07, 2015 | GMC Cars & Trucks
How i do may my power acoustik play in my truck.power go off and on ?
red pos key on, yellow always pos,blue sends pos to external amp or power antennae if none tape up- black wire neg. the rest pretty much speakers.
Feb 03, 2015 | 1994-1998 Chevy C2500 Truck 10 Piece...
Trying to install kenwood kcd mp238 cd player into a 1996 Ford Expedition. I need to know wiring data to connect the wires of cd player to harness, which colors should I match wires up to, so I can just...
Black Ground, yellow, battery, red switch battery, blue not used, blue white power antennea/amp, brown tel mute, white black front left neg, white front left pos, gray black front right neg, gray front right pos, green black rear left neg, green rear left pos, purple black rear right neg, purple rear right pos
Oct 24, 2012 | Car Audio & Video
How to re-wire the flashlight Makita BML185
You have a battery a globe and a switch. It really only matters matter if you keep the circuit board(CB). Here's how mine was wired.
Red - Battery pos to switch to bottom of CB (BT+)
Red - top of CB (BU+) to pos contact pivot
Black - neg contact pivot to top of CB (BU-)
Black - bottom to CB (BT-) to battery neg
Or you could just bypass the CB altogether, wire the black to the black, and the red to the red. done.
Jul 31, 2012 | Makita 18V Lxt Lithium Ion Rechargeable...
Need to know which is pos and neg. L1 or l2?
Pos and negative are DC voltage terms. And that pump is a 220 VAC pump. L1 and L2 are the two HOT terminals - so you will have 110 VAC on one leg and 110 VAC on the other leg and it doesn't really matter which HOT you put on which leg.
Jun 07, 2011 | Waterway Executive 56 Spa Pump 2hp 2" 2spd...
If you are replacing a 2 hp pump with a Hayward 2 hp super pump on a 220 line is L1 white and L2 black
Shouldn't be a white line on a 220 circuit but some people use them. Red and Black is the standard. If you are sure they supply 220 VAC, which I would verify, it doesn't matter which one goes to which terminal. 120 or 3 phase matters. If you have a multi meter, put the red lead on the black wire and the black lead on the white wire. If you read 220, good. If you read 120, it will make a difference.
Jun 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
Problems wiring Flotec sprinkler pump
L1- L2 doesn't care if blk or red. Make sure there is 220vac (240vac) on the supply wires. If there is there is something amiss with the pump. Eric
Jun 21, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
8 wires on my subwoofer??
"One has positive and negative input, another positive and negative output (red and black on each)"
Just from your description, it sounds like pos/neg input are the 12 volt pos neg supply for the amp inside the subwoofer. Red is pos, black is neg.
"positive and negative output (red and black on each)"
This sounds like it's used if you want to proved 12 volt pos/neg to another component.
"and a third wire with left input right input positive and negative (blue, red, yellow and black)"
This is for the cables coming from the "subwoofer out" on the amp. This is 4 wires altogether -- correct?
May 08, 2009 | Audio Players & Recorders
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Jan 01, 2009 | Car Audio & Video
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
