Question about Dryers
The coil is heating up but the flame won't start. I don't hear a clicking either.
  • rip314 Nov 21, 2014
    79272000 model number
    Master:
  • 487 Answers
You need an experienced technician, not good to fool around with gas, you could blow up your house
Posted on Nov 21, 2014
Diagram for speed queen model ags17awf
If you hear the click that means the ignitor is working and the flame sensor is working also because you hear the click of the bimetal inside the flame sensor. The sensor kills power to the ignitor and that allows the solenoid coils to open the gas valve. Them solenoid coils get weak with age. They work a little bit when cool the get hot and quit sometimes they simply go on out.
Oct 21, 2011 | Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
Drum rotates no heat,igniter dosent start
While the drum is rotating you should hear the CLICK associated with the gas valve assembly powering up to give out a blast of heat. If ya don't hear no click check the duct fuse. Right next to the control thermostat. If it is blown it kills the circuit to the gas valve assembly. If that fuse is good and the control is also good, then check the flame sensor for continuity, If it is open then the ignitor won't glow. The ignitor must glow and change in resistance then the flame sensor must open up and kill power to the ignitor so that power will be shifted to them coils on the gas valve.
Sep 03, 2011 | Maytag MDG2706A Gas Dryer
I have a Kenmore gas dryer Model 74812200. It is no longer heating up. When I turn it on, I hear a clicking sound for about 30 seconds then it goes off. Then about a minute later I hear the clicking sound...
You would not hear the click if the ignitor was bad. It won't click until the flame sensor get heated up by the ignitor. So that tells me the thermal fuse ain't melted. I would say them coils on the gas valve are the problem. themobilian_2943.jpg
Aug 30, 2011 | Kenmore 74812 Gas Dryer
Heats but wont stay heated
If the flame come on to start with, but then goes out and won't come back on I would suspect you have a bad coil on the gas valve.
If you see the flame cycle on and off, but the flame does come back on again this is normal. The flame needs to cycle on and off and not be on steady or the dryer would get to hot.
If the flame is cycling ok and the cloths just don't get dry then you need to check your dryer and vent for lint build up.
Aug 02, 2011 | Roper RGX4634KQ Gas Dryer
Hi, I have a Kenmore gas dryer model 417. I can't
Sounds like the coils on the gas valve are bad.
May 26, 2011 | Kenmore Dryers
Frigidaire crown gas dryer runs fine but after about 10 minutes it turns itself off and i cant turn it back on for about an hour
From the description you give the most likely cause of this problem are bad gas coils or a bad gas valve.
You say you see the flames for 10 minutes before it stops heating but you don't mention if the igniter is continuing to glow. One thing we need to know is if the igniter continues to cycle on and off when the dryer stops heating.
There is a small square plug on the front panel you can remove to try and visually check if the igniter is glowing.
The problem won't be the thermal fuse or one of the thermostats. Once the fuse is open the dryer won't heat but it won't start to heat after 20 minutes.
After the dryer runs ten minutes and stops heating then check if the igniter is still cycling on and off. This is important because if the igniter is working then the thermostats and igniter are okay.
When the igniter glows at some point you might hear a click and the igniter would stop glowing. The click is from the flame sensor and after the click and the voltage is removed from the igniter at the same instant the voltage is applied to the gas coils and you should get a flame.
You might hear a hum, buzz or vibration from the coils when this happens. If the coils seem to react to the voltage but there is no flame then most likely the gas valve is bad. If the coils don't do anything then most likely the coils are the problem. The gas valve and gas coils can work for 10-15 minutes and then heat up and stop working till everything cools down.
One other thing I must tell you about the gas coils. Here is a link to the gas coils you will need. These are the new style that will last quite a bit longer the the older one. The coils are like the spark plugs in your car. The will need replacing in time due to wear. Below is a video to walk you thru the repair process.
utube.png You-Tube video "RjonjNitfVk" placeholder
Jan 09, 2011 | Frigidaire GLGR642A Gas Dryer
Kenmore gas dryer 110.97278100 won't heat
there's a thermal fuse that usually is the problem. when you push the start button; listen for 2 clicks. The motor centrifugal switch & than the coil on your valve. If you only hear 1 click, replace t-fuse. if you hear 2 clicks than ck for problems in the flate sensor,ignitor,gas valve
Nov 10, 2009 | Washing Machines
Dryer starts, heat up than the goes out
Faulty gas valve coils are the typical cause of this type of "cycling". These electrical coils are right above the gas valves and when energized, these solenoids open the gas valves and permit the burner to light. If any gas valve coils are suspected of being faulty, it is recommended that both (all) be replaced at the same time. Hope this helped and best wishes.
Sep 02, 2009 | Dryers
Dryers Logo
Top Dryers Experts
