Question about OfficeMax 10-Sheet Micro-Cut Shredder Om02750
WHAT DO I DO WHEN THE OVERHEAT LIGHT COMES ON
IT HAS COMPLETELY SHUT DOWN ON ME
  • 3,287 Answers
Hi Mary. Many of these devices are for home use only. Commercial devices expect to get significantly heavier usage and are built to handle it.
Your device has likely been used so much at one time that it has begun to overheat and shut off to protect it from permanent failure. Given enough time to cool off - it should start functioning again. There may be an issue with the volume of paper that has been inserted at once time - that resulted in a jam. The jam may have to be cleared before the unit will work properly again. Some shredders have a reverse switch that can help back out a jam. If you must poke the jammed paper with an object, you should unplug it first.
Posted on Nov 21, 2014
    Sergeant:
  • 266 Answers
It means you overheated it and you probably fried it if it doesn't come back on after it cooled down.
Dv209aew/xaa therm
u may have a bad motor windings problem, usually will rund for about 25 minutes to an hour then shut off, wait an hour and can run again then shuts off ? also check ur venting inside machine and to the wall a build up can cause it to overheat and then shut down? u may have to remove cabinet to see inside condition? which thermostats did u change, u may have bad hi-lo limit and cycleling thermostat
Jul 28, 2014 | Samsung Dryers
Invacare m51 runs out of power to soon. Green power light never goes to amber just runs out of power to soon warning light never goes to amber. just runs out of power
This is most likely a case that the controller/computer(the box that the joystick plugs into down inside the chair)is placing the chair into what is called a "limp-home" mode. It automatically senses something seriously wrong with the chair and starts cutting the power to the motors, such as overheating. If they are still getting hot, it will shut itself down completely, and you can restart after all cools down, but you have a serious problem on your hands. This usually happens when a chair is loaded near or past its maximum weight, and say you try to drive it up a long incline....motors will overheat and it will slow down, then shut down. If it is doing it on a flat surface without being heavily loaded, you have motor problems or controller problems.
Apr 21, 2014 | Invacare Pronto M51 Power Wheelchair
Auto shut off hot
A faulty transistor or IC that has failed, it probably overheats before any other device. You should shut the amp down when it happens, then feel carefully around for the hottest part. I would replace that. Or you can power the amp back up wait till it acts up, then spray that hot part with Servisol Freezer spray. If it comes back on, then you know it's faulty. If not try another part, with the spray, only one at a time.
Nov 18, 2013 | Peavey Audio Players & Recorders
Cat or exhaust light comes on as soon as you turn on motor
INCORRECT PRODUCT CATEGORY
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Jul 25, 2012 | Cars & Trucks
I have an Ativia 6000 shredder. The red light comes on and the shredder stops, after only shredding a few papers..why?
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
Jul 03, 2012 | Computers & Internet
It makes a clicking noise when i turn it on and nothing comes up on the screen then it stops and the power light flickers.
something is obstructing the fan. if it doesn't spin up to speed, it'll shut down so it doesn't overheat. check your fans, and replace it if necessary.
Jan 27, 2010 | Panasonic PT L720U Multimedia Projector
Flashing red and green light
You are going to need to call Sony for repairs to this unit. Their number is:
globe.gif 1-800-345-7669
Nov 16, 2009 | Sony PlayStation 2 (PS2) Console
The overload light comes on after I cleared the majority of paper that was stuck in the shredder. I cannot get it to work
Most shredders have an overheat safety shutoff. Once hot, it'll shut off and can be used after a few minutes of cooling down.
Jul 01, 2009 | Office Equipment & Supplies
Dryer making loud noise
the humming noise is most likely your motor. does it overheat or shut down on you? do you smell anykind of burning? Joe
Nov 14, 2008 | Maytag Neptune MDE5500AY Electric Dryer
OfficeMax 10-Sheet Micro-Cut Shredder Om02750 Logo
170 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
