Question about Okidata 62435901 - MC361 MFP Multifunction Laser Printer,
How do I reset 134 error code in an okidata mc361?
How to fix okidata c 711 error code 134
Error code 134 on the OKI C711 refers to the white ribbon cable that plugs into the Black LED head. If it has come out of the head then check that the silver contacts are in good condition and none are touching each other. If any of them are touching each other then its a certainty that fuse F12 on the main board will have blown. If they are good then push it back in but this must only be done with the power off. I cant remember whether the 711 has a plug on the end of the cable or just has silver contacts. If F12 has blown then you cant replace it as its part of the board. Only a pcb repairer can change it or fitting a new board.
Dec 08, 2016 | OKI Office Equipment & Supplies
5650c not scanned. making paper jam. rollers replaced. making big noise.document page stop halfway through
PDF]fi-5650C Image Scanner Operator's Guide P3PC ... - Fujitsu
www.fujitsu.com/downloads/.../scanners/.../fi-5650c_ops-guide.pd...
FujitsuThank you for purchasing the fi-5650C fi-5650C duplex color scanner product. ... 6.1 Removing jammed documents ..... store where you purchased the scanner or an authorized FUJITSU Image Scanner service provider to make repairs to this .... It is adjusted to the width of the paper in order not to scanned skewed pages. 5.
Okidata User's Guide OKIFAX 5650 Error Messagesmy.okidata.com/man-OF5650.../006B738F6240C3BF8525678500678C...Make sure a new drum is available, and replace the drum ... to be faxed or scanned hasjammed in the scanner. Refer to the "Problem Solving, Clearing aTroubleshooting - Oki Printing Solutions in New Zealandwww.oki.co.nz/support/printer/.../index.aspxOki Electric Industry... MB491 ES4191. FAQ: Paper Jam Clearing MB451 MB471 MB491 ES4191 ...MC361 MC362 MC561 MC562 How to setup scan to email. Open the attached ..... Can I disable Colour Copying and make only B+W Copying available? No, it not possible to disable Color Mode when copying via the Scanner Operator Panel.
Jan 29, 2016 | Office Equipment & Supplies
En la pantallade la impresora oki B4350 me marca error 134
Tengo una Oki mc361/mc561 me da error 134 como puedo solucionarlo
Aug 26, 2011 | OKI B4350 Laser Printer
On oki mfp mc 361 i tried to enable the user authentication I enabled it but i forgot to register the user name and password now the machine is prompting on its UI for user name and password is ther any...
the folllowing is there manual..http://my.okidata.com/mandown.nsf/6ab08f978f492b7c85257706006167ea/3e7abc5f05cd0f23852577f1006d038f/$FILE/MC361%20MC561%20CX2731MFP%20Adv%20User%20Guide.pdf
the default pasword is"aaaaaa" without the quotes
GL
Jammer
May 04, 2011 | Office Equipment & Supplies
Hi everyone, I have just bought an OKIDATA MC361 and changed the administrator password. I have copied it from an excel sheet, but when I want to login with this password, it can't.. So there must have...
How To:
Reset the admin password on the unit. Action:
Follow these steps to reset the password:
1) Go into settings -
2) Press the following, on the number keypad: # 0 1 0 3 *
3) The printer will ask for a password, the password is 000000
4) Once in the maintenance menu, go to System Maintenance -> Reset Admin Password -> Execute -> Yes
5) This will reset the password.
Mar 30, 2011 | Office Equipment & Supplies
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
Fatal Error
unplug and plug back in.
Jan 15, 2008 | OKI C5150n Led Printer
Okidata 62435901 - MC361 MFP Multifunction Laser Printer, Logo
550 people viewed this question
Top Okidata Computers & Internet Experts
David Payne
David Payne
Are you an Okidata Computer and Internet Expert? Answer questions, earn points and help others
