Question about OKI C5400 Laser Printer
OKI c5400 error 0x000000aa port comfig
I recently had the xfinity x1 system installed. My oki printer is not connect to the network. i did not have this problem with the previous xfinity system that used Netscape wireless router. All connection have be checked and double checked. Cables have been changed. other ports have been tried. Can any one help.... The Xfinity tech had no idea. I also have a HP Laserjet Pro 200 that work perfectly fine regardless of the network connection.
  • 3 Answers
Hi Fixya
The error you mentioned is related to the Microsoft operating system.
Please find the below article for your reference
http://winwiki.org/port-configuration-error-0x000000aa/
Hope it will solve your issue.
BR
Ganesh
Posted on Nov 25, 2014
  • 186 Answers
SOURCE: Double Printing
check the printer drvier properties and make sur the defaulf is not set to print 2 copies.
Posted on Jun 21, 2007
  • 32 Answers
SOURCE: oki c5400
Drum life for C5400 is roughly 15000 pages
Posted on Feb 12, 2008
keithd2704
  • 56 Answers
SOURCE: Connecting a Oki C5300N as a 2:nd printer in my Mac-network..
Good Day Joromich,
Sounds like your problem is just an IP address conflict. The easiest way to fix this is going to be through the front panel of the printer. You will need to configure the NIC to DHCP AUTO. This will allow the switch/router to configure the printer to the IP address schema your network is using.
You should also check you switch/router settings to ensure if you are using MAC address filtering (this has nothing to do with your Mac computer). The MAC address is the physical hardware address of any NIC device. It is the "permanent" device identifier that the manufacturer has assigned to the NIC. If your switch/router is configured to use MAC address filtering you will need to know this address. It will be a series of HEX values similar to this:
AE:02:4F:3B:55:2F
And is usually located on a sticker on the outside of the NIC adapter, if not you might need to remove the card from the printer to check it, however you should be able to obtain a NIC configuration page from the printer through the control panel. If you are using this additional level of network security (helps to prevent rogue devices from attaching to the network), you will need to add the MAC address to the switch/router filtering table. Most home network users do not use this additional layering of security, but when using wireless access points/routers, every extra bit of network security helps.
Once you have reconfigured the printer for you network IP schema through the use of DHCP, the network should now see the device. If you are configuring your printer drivers to print to the IP address of the device, you should disable the DHCP AUTO setting once everything is working. Otherwise the switch/router will replace the printer IP address once the lease is expired then causing your printer not to be accessible again.
Once the switch/router has provided the new printer with an IP address, you will be able to access the internal web page of the printer through your Internet browser. At this point you can then change the IP address configuration to DHCP OFF. This will prevent the printer NIC from making an IP address request and keep the IP address that has been assigned as a STATIC address.
Configuring the printer driver on the Mac is easy, once the device has been added to the network, the Mac Add Printer Utility will see the IP address of the printer and you can use this to print directly to it rather than using AppleTalk. As for problem of not having the orignal install CD, not a problem as the printer is listed within the Mac OS printer table. If you want to use the Oki OEM driver follow the link listed here:
http://my.okidata.com/pp-C5300n.nsf/openingdrivermenu?OpenFrameSet
Select the one you want and install it as usual. Hope this helps get you going.
Cheers, Happy New Year!
Keith
USA
Posted on Jan 02, 2009
57 varieties
  • 1653 Answers
SOURCE: Okie C5400 giving 162: Fatal Error
This is a Toner Sensor Error, Color:Cyan
and can be corrected by checking that the Cyan toner lock lever is correctly in position.
Posted on Sep 11, 2009
pagebor
  • 2785 Answers
SOURCE: unable to get oki c5510 on network. Doesn't seem
plz enable the dhcp on printer and try
Posted on Nov 13, 2009
How to fix error 491: Tray Empty on Oki c5400
printer oki b411dn put out of the balcony, unsatisfied by his work, too many error codes, to lost time, to failed
Feb 27, 2012 | OKI C5400 Laser Printer
Can i make the oki c5400 duplex
REQUIRES THE INSTALLATION OF A C5400 DUPLEX UNIT WHICH JUST SLIDES IN FROM THE REAR OF THE UNIT
Oct 05, 2010 | OKI C5400 Laser Printer
Fatal error 020: oki c5450
As far as 020 error is concerned it is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Aug 18, 2010 | OKI C5400 Laser Printer
Is it easy to change the belt on an OKI C5400 printer?
Do you mean the image transfer belt? If yes, then it is easy. Instructions are in with the new belt.
Dec 30, 2009 | OKI C5400 Laser Printer
Magenta toner sensor error. Reseat drum unit. check toner cart. Take out the key that prevents you from putting drums in wrong slot and swap the whole drum and toner assy with another color, if it follows the magenta unit then that is the problem somehow.
Mar 19, 2009 | OKI C5400 Laser Printer
Mar 19, 2009 | OKI C5400n Led Printer
Oki c5400 communication error
This means that the interface type settings are incorrect in the Printer Menu and might be due to trying to use half duplex comms instead of full duplex, you are trying to use TCP/IP when the printer has this option turned off. It could even be as simple as something wrong with the interface cable being used or a mismatch in USB1.1 to V2.
Nov 08, 2008 | OKI C5400 Laser Printer
Reset Counters
There is no known way to do this!
Nov 05, 2008 | OKI C5400 Laser Printer
Oki c5400
Feb 09, 2008 | OKI C7350hdn Led Printer
OKI C5400 Laser Printer Logo
177 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
