Question about Microwave Ovens
I have a Panasonic 1250w microwave and the door won't close and latch and when it does the light stays on then once you do finally shut it and press start, the timer starts but microwave does not turn on! This is the SECOND microwave with the exact same problem! First one did it after a year this new one is 6 months old and started after 2 months and got worse and worse until now it won't close or start unless you try several times until it finally closes and starts but takes MANY tries to do it! Taking it back but am expecting the same thing from this model once replaced AGAIN!!!
  • 45 Answers
Sounds like an alignment problem with the door itself and/or the interlock switches which operate as the door is opened/closed. Recommend a factory authorized service center. You don't want to take the chance of a leaky door.
Posted on Nov 26, 2014
  • 3 Answers
The problem is an engineering defect. The mechanism that engages the door latch is mounted to a steel plate that is "L" shaped and when you close the door it pushes against and bends this plate out of position. After a while the metal plate fatigues and stays bend out of position and the door stops engaging and locking so the two safety switches inside don't get depressed. Result door won't lock and light stays on. I had to re-engineer it by cutting the tube of a pen to size and placing it in as a support bracket to put pressure on the plate so it won't bend anymore. My wife was going to throw it in the trash. Note of caution: I did cut my hand in several places trying to get the bottom cover on and off the microwave as the metal edges are razor sharp!!! I love this microwave it is my second one.
Posted on Jan 06, 2015
5 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JE1860 microwave won't turn off sometimes
You probably have a sticking relay on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details of our service, plus *critical* safety, disassembly, and troubleshooting info at our site.
You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
It is possible that you might have a bad door switch but I don't think so. In case you or a friend want to check that first, here are some links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 30, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Apr 18, 2008
SOURCE: Microwave auto-starts when door is closed
the buttons recently stopped working sporadically and now everytime I open the door, the unit turns on. The only solution was unplugging.. Is there a fix short of replacing it?
Posted on Jun 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Panasonic Sensor 1250W Microwave cycles off after only 5 seconds.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector.
If so, see http://www.microwavedisplay.com/safety.txt , http://www.microwavedisplay.com/disassembly.txt and http://www.microwavedisplay.com/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find many Panasonic owner's manuals for free download here.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US, see Panasonic.net.
Posted on Dec 26, 2009
Testimonial: "Extraordinarily helpful, comprehensive advice within 24 hours of posting my question. Thank you so much!"
My Panasonic microwave nn-t945sfx. Door is hard to shut and is not latching correctly. I inspected the spring and latch and it appears to be working correctly. I noticed the two holes where the latch
Common problem. Apply a small dab of lithium grease to the tips of the door hooks. You might also have to adt. the door latch switch assembly inside the oven as it could be bent out of shape from the hard to close door.
Nov 19, 2014 | Panasonic Microwave Ovens
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
NN-T994SFR. Inclosed light stays on and the indicator states the door is open.
It is micro switch when you close the door, the door latch push in a button on the micro switch take lid off open and close the door and see if you can spot a button not popping out properly or the latch not in line with the switch
Oct 04, 2013 | Panasonic NN-T994SF Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
Hi I have a new Kenmore microwave model 721.8503 - it is a month old and wont turn on.. I close the door and the light stays on and it wont work..the door is completely shut
It sounds like the light switch isn't being deactivated which is preventing the microwave from operating (a failsafe).
Look to see that the buttons inside the microwave (where the latches are inserted when you close the door) are actually being pressed.
They may be out of place, obstructed, or your latches on the door may be damaged.
If you don't see anything wrong, try pressing the buttons yourself (with a pen bottom) to see if the light goes off.
Dec 18, 2010 | Kenmore Microwave Ovens
1200 watt panasonic, power on but will not perform
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
best regards .
please don't forget to rate !
Apr 04, 2010 | Panasonic NN-S262SF Microwave Oven
My Panasonic Inverter Genius Sensor 1250W Lights
microwave is in lock mode. How do you unlock to use?
Feb 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I cannot open the door of my Panasonic NN-T543W microwave
Well do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door closed. Anyway that is where your problem is. Let me know if you need more hlep.
Feb 09, 2009 | Panasonic NN-S251 Microwave Oven
Door does not secure when closed
Hi , Either you have a faulty door interlock switch(es), or the door latches (on the door) have been damaged and will not activate the interlocks. either way, you have to be conversant with adjusting microwave latch assemblies once the repair has been effected AND THE USE OF AN OVEN LEAK DETECTOR IS IMPERATIVE for final testing or the end user will be subjected to harmful levels of microwave radiation.
Jan 05, 2009 | Panasonic NN-S753 Microwave Oven
Microwave Ovens Logo
96 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
